Why doesn't Shelly 2.5 show power consumption? Mounting slip-ups?
chrisjan 1515 3
  • #1 18204380
    chrisjan
    I have fitted a couple of Shelly relays at my place, including two Shelly 2.5 relays.
    One shows the current consumption and the other unfortunately does not.
    What could be the cause (maybe some mundane mounting mistake?).
    Greetings,
    Chrisjan
  • #2 18380049
    stasiekm
    Level 30  
    Help: 77
    Rate: 100
    The problem may be in the resolution -my 2.5 shows 10W for two LED lights and 0W for one light -maybe you have a current draw below the lowest measurable reading?
  • #3 18391770
    lukaszsbv
    Rate: 18
    chrisjan wrote:
    I have fitted a couple of Shelly relays to my house, including two Shelly 2.5 relays.
    Regards,
    Chrisjan
    Have you solved the problem? I have the same Shelly 2.5....
  • #4 18393578
    chrisjan
    I sent it back to the shop under warranty - they replaced it with a new one.
