How do I make a notification of new mail in a mailbox with ESP and Supla module?
Brendy8606 1467 5
  • #1 18219940
    Brendy8606
    Rate: 58
    I would like to use the esp module and using wifi to make a notification that there is mail in the mailbox to be received in some simple and effective way to make a notification of new mail and connect this to the suple. I live in a block of flats the mailbox is quite small and there is no handle or arm to do this on a microstick. I was thinking more of a sensor which will detect the letter, switch on the esp and I will see in the supple application that something is in the box, power supply I was thinking of doing on rechargeable batteries e.g. 2pcs one 3.7v 3400mA. There are many different sensors out there, I just don't know which would be the most optimal for this project.
    • How do I make a notification of new mail in a mailbox with ESP and Supla module? Screenshot_20191015-091748~2.jpg (180.67 KB) You must be logged in to download this attachment.
    sp3ots
    Help: 524
    Rate: 674
    Hello !
    The mailbox is plastic ?
    Wi Fi through metal will not pass.
    Buy the module you have shown, mount the light sensitive elements perpendicular to the board and test, you have to start somewhere.
  • #3 18220959
    Brendy8606
    Rate: 58
    This is what I feared, that the metal would jam the signal. I'll keep trying, thanks for your help. Do I need to buy any more light sensitive components or is the sensor alone sufficient for detection?
    sp3ots
    Help: 524
    Rate: 674
    There are photosensitive elements on this board. If you haven't already bought this board then look for a similar board with photosensitive elements mounted perpendicular to the board.
  • #5 18221275
    Brendy8606
    Rate: 58
    Ok thanks for the info I will be looking for one. I am planning to order a few sensors of different operating principle and test this hopefully it will achieve its purpose.
  • #6 18228951
    Brendy8606
    Rate: 58
    Is it possible to get a range with such a transmitter and receiver, because with wifi I'm afraid the signal will interfere. I read somewhere on the forum that someone achieved such an effect even in a block of flats through reinforced concrete walls by attaching wires as antennas to a box I have two floors below.
    • How do I make a notification of new mail in a mailbox with ESP and Supla module? IMG_20191020_111010.jpg (297.74 KB) You must be logged in to download this attachment.
