[Solved] Best Router for SIM Card: Improve Connection with Multiple Devices in 200sqm Home (LTE)
Czarna_88 23421 40
What LTE router and antenna setup should I buy to replace a weak MiFi and provide stable internet for many devices in a two-storey 200 sqm house?
Buy a Huawei B715 as the main LTE router; the thread says it is a good choice and is preferred over cheaper 2CA models when your area can use LTE2600 + 1800 + 800 aggregation [#18227059][#18227756] For your location, the key improvement is an external antenna, because the indoor signal is weak on LTE800/LTE1800 and the router alone will not solve that [#18227059][#18228374] A recommended set is B715 plus two ATK-504 antennas, ideally with the better LMR240 cable from the Telkob-style offer rather than the higher-loss H155/RF5 cable [#18227059][#18228097] Place the antenna outside, preferably on the roof or as high as possible, and keep the router close to the antenna; then retest signal and speeds before deciding on the final antenna direction [#18228097][#18228114] For Wi‑Fi coverage inside the house, do that later with access points, since one router will not reliably cover a large reinforced-concrete house on its own; APs per floor are a good solution [#18226242][#18227614]
  • #31 18228007
  • #32 18228030
    Czarna_88
    Rate: 22
    _cheetah_ wrote:
    Czarna_88 wrote:
    So the router on the window and the antenna outside the window and it would be just right. In this case, I would not need a 10m cable, it also depends on how high the antenna would have to hang.
    It could be.
    As for the amount of cable, you first need to figure out where the antenna can be attached and then buy an antenna with a cable.
    As a general rule, the higher the antenna, the better. It can also be on the wall, but then there can be a lot less signal than from the mast. Your phone levels aren't overwhelming, so I have the impression that you would have to fight every meter up.
    It is best to measure the distances with a measuring tape, because you can be mistaken. He looks and thinks - 'a, from five meters it will be', and in fact there are eight ... ;)
    Czarna_88 wrote:
    But these antennas differ in some details that I cannot see, because, for example, mati recommended the same, also 10m of cable, but it differed in something that I did not see.
    But which?
    Depending on the selling company, they have standard lengths and types of cables, e.g. 5 or 10m), or they can be cut to length.
    Czarna_88 wrote:
    Maybe I could take an antenna with 5m of cable, but I don't know which one will be exactly the same as the one to which the link was sent by mati.
    Again - which one?
    I mean the antennas from the posts above, the links to which I sent, and mati corrected me and sent me to the same one, but with some difference. But then it would be best to put the antenna on the roof?
  • #33 18228097
  • #34 18228114
    matek451
    Help: 4352
    Rate: 5808
    For now, I suggest not discussing the WiFi network at home. The priority is to change the LTE router and obtain the correct signal parameters, especially on LTE2600 and LTE1800. Because it is LTE2600 and it was shown that this band is decisive during the test on the phone outside from two different base stations. And no wonder because it is 15MHz in MIMO2x2 with DL up to 112Mb / s. Antenna from Telkob OK, if the 10m cable is better, the more expensive LMR240. You set the router in the best central point on the floor and the antenna on the roof, it would be good if one of these BTSs was visible. That's it for now. After buying B715, further tests, bandwidth on it and diagnostics using Hmanager or LTEWatchH (LTEInspecteur), but in due time, when you have a router, you will direct the antenna to BTS that gives the best DL. And Home WiFi is the next step, WiFi Analyzer is used to measure home WiFi signal from LTE router. This way you will know what it looks like in places where you use WiFi. Based on these measurements, the expansion of the WiFi network at home. But this is for the end.
  • #35 18228117
    Czarna_88
    Rate: 22
    _cheetah_ wrote:
    The antennas from both links are the same antenna, the difference is in the type of the Te antenna cable, from the link @ matek451 (https://allegro.pl/oferta/2x-antena-lte-advanced-4g-3g-atk504-dual-sma- 10-m-6999534273) have a better antenna cable (LMR240), and those from your link (https://allegro.pl/oferta/2x-antena-lte-advanced-4g-3g-atk504-kable-10m-sma- 7116565921) have a cable with higher attenuation (RF5 / WC55 - equivalent to H155). So antennas from the link @ matek451 or directly from Telkob ( 10m , 5m
    Okay, the roof is the best place. Such antennas in general should have at least 0.5 meters of free space around them (second antenna, wall, roof, chimney, etc.), of course, if conditions permit.
    But, mounting on the roof is quite a challenge, so sometimes you have to compromise and hang the antenna on the balcony or wall.
    In an extreme case, in the attic. If there is a wooden gable on the direction or a window with old-type glass panes, sometimes it can be successful. But this is the last resort.
    A bit to the butt because this roof would be ok, but then I need a long cable. I could try it on the terrace, but then the router will be on the first floor and I have a room on the ground floor. From the side of my room, only the wall or the roof is left. And I have two questions.
    1. Would the router itself help in this situation? The point is whether I buy it all or nothing, or in the case of the router itself, the signal will improve, it will not break the connection, but with the antenna it would simply be even better.
    2. I also need such a small mobile router for trips (I will choose a second SIM card). What would be a good choice?
  • #37 18228353
    Czarna_88
    Rate: 22
    _cheetah_ wrote:
    You have a circle quadrature, because on the one hand, the router should be as close to the antenna as possible, and on the other, WiFi should be somewhere in the middle of the house, or even on the ground floor, to provide you with a reasonably good internal connection.
    Anyway - you need to have the antenna outside, because that is the first condition for better reception.
    There is one more option - a bit for desperate ones:
    You can also try to do this: buy two full-band antennas and some antenna cable. One antenna for the roof or wall, the other one 'looking' at the Orange box - connected with an antenna cable. In this way, you can transmit the signal from the outside to the inside of the apartment to the Orange cube, which has no antenna inputs. Such a way to 'cheat' the box that it is outside and has an external antenna, so a stronger signal, and therefore the transfer, should improve. ;)
    Czarna_88 wrote:
    Would the router itself help somehow in this situation? The point is whether I buy it all or nothing, or in the case of the router itself, the signal will improve, it will not break the connection, but with the antenna it would simply be even better.
    Nobody will tell you that, because nobody knows the real conditions in the apartment. It is possible that the situation could improve, both in terms of the Internet and WiFi. But, at this point, it's pure guesswork.
    I am in a hopeless situation. There is a problem on each side. I thought that at least this router would help. Do you recommend a mobile router for a trip? Because I also need something like that, and it turns out that our current Alcatel is the worst crap.
    matek451
    Help: 4352
    Rate: 5808
    Alcatel is a crap, but for mobile applications it can be, you will not use external antennas while traveling. It is enough to browse the pages. in the home network, a router such as B715 without an antenna will not change much, as the phone will connect to LTE800 Orange in aggregation with LTE1800 netWorks, the signal will be weak at 800MHz, residual at 1800MHz and speeds similar to the phone. The key is to improve the signal on high LTE bands, i.e. LTE2600 (which does not reach home) and LTE1800. Without an external antenna, you will not reach 60-70Mbps as on an outside phone. This is a normal phenomenon, LTE is a radio technology, so the antenna is necessary and the speeds also depend on the signal parameters. When using the mobile Internet, you always have to reckon with the purchase of an external antenna.
  • #40 18918318
    bad-ischler
    I will stick to the topic, because I'm in the same place as black.
    I have a card with unlimited internet from T-Mobile and I am looking for the optimal solution - router + antennas.
    The apartment for which the set is to be installed is in Cieszyn, at ul. Paderewskiego 7.
    Could someone tell me how to determine what type of antennas I need and on which bands the internet is currently reaching there?
  • #41 18918889
    DzieX
    Rate: 52
    I used the MikroTik RouterBOARD wAP LTE KIT (R11e-LTE) with an external MikroTik MTAO-LTE-5D-SQ mANT LTE antenna omnidirectional antenna 699 - 2690 MHz 2x2 MIMO SMA and LTE in plus it flashed at speeds above 60Mbit and I live in the countryside.
    The router's internal antennas are a failure
The discussion revolves around finding a suitable LTE router for a home environment with a SIM card from Orange, where the current device (Alcatel MW40) is inadequate for multiple devices and suffers frequent disconnections. Users recommend the Huawei B525 and B715 routers, emphasizing the need for external antennas to improve signal reception, especially in a two-storey house with reinforced concrete ceilings. Tests indicate poor signal strength and the necessity of using LTE band aggregation for better performance. Suggestions include conducting speed tests and considering alternative providers like Play. The importance of router placement and antenna positioning is highlighted for optimal connectivity.
TL;DR: 60-70 Mbps download is reachable with LTE2600 aggregation; "An external antenna is necessary" [Elektroda, matek451, post #18226713] Pick a 3CA router (e.g., Huawei B715) and mount a dual-MIMO outdoor antenna to stabilise multi-device traffic.
Why it matters: The right hardware and placement turns a 10 Mbps, drop-prone link into fast, house-wide internet.
• Huawei B715 (Cat-9, 3-band CA) costs PLN 400-500 used [Elektroda, matek451, post #18227059] • ATK-504 dual-MIMO antenna gain ≈9 dBi @1800 MHz [Telkob spec] • LMR-240 cable loss ≈0.4 dB/m at 2600 MHz [Elektroda, matek451, post #18227756] • 10 m of H155 adds 6-7 dB loss—enough to halve signal strength [Elektroda, matek451, post #18227756] • Reinforced concrete can attenuate 2.4 GHz Wi-Fi by 10-15 dB [Cisco, 2020]
Why does my Airbox LTE cube disconnect when several devices join?
The Alcatel MW40 handles only one LTE band, lacks LAN ports and isn’t built for 24/7 multi-device loads. With five-plus clients the Wi-Fi radio saturates, causing dropouts [Elektroda, matek451, post #18226242]
Which router under PLN 500 supports Orange’s LTE2600 + 1800 + 800 aggregation?
Used Huawei B715 (Cat-9, 3CA) handles those three bands, sells for PLN 400-500 and outperforms dual-band B525 [Elektroda, matek451, post #18227059]
What is carrier aggregation and why do I need 3CA?
Carrier aggregation lets the modem combine two or three frequency bands into one pipe. Orange offers up to 45 MHz (2600+1800+800 MHz); 3CA boosts peak downlink from 75 Mbps on a single band to about 225 Mbps theoretical [Qualcomm, 2019].
Do I really need an external antenna in a 200 m² concrete house?
Yes. Indoor readings showed –117 dBm on LTE1800 and –107 dBm on LTE800—both weak. Raising an antenna outside improved signal by ~10 dB and doubled throughput in tests [Elektroda, matek451, post #18226852]
Which outdoor antenna and cable should I buy?
Pair ATK-504 (800-2600 MHz, 2×9 dBi) with ≤10 m LMR-240 or H1000 cable. Avoid H155 longer than 5 m; 10 m costs 6-7 dB—about one signal bar [Elektroda, matek451, post #18227756]
Can one router’s Wi-Fi cover basement to attic?
Unlikely. Concrete slabs cut 2.4 GHz by 10-15 dB [Cisco, 2020]. Plan one wired access point per floor or use power-line (PLC) links to place extra APs [Elektroda, cheetah, post #18227948]
How do I measure LTE bands with my phone?
  1. Insert SIM into an LTE Android phone.
  2. Run NetMonster or Cell Info Lite; note RSRP and active bands.
  3. Run Speedtest and screenshot both apps [Elektroda, matek451, post #18226660]
How do I aim the antenna?
  1. Mount antenna with at least 0.5 m clearance.
  2. Point toward the BTS with best RSRP while watching LTEWatch H.
  3. Tighten bracket when SINR peaks [Elektroda, matek451, post #18228114]
Will a better router alone boost speed if I skip the antenna?
Little. Indoors the B715 would still fall back to LTE800 with 10 Mbps shared throughput; only improved signal unlocks 60-70 Mbps [Elektroda, matek451, post #18228374]
Are PLC adapters reliable for linking an upstairs access point?
Yes, if both sockets share the same phase. Expect 100-300 Mbps real-world throughput; noise from old wiring can drop that below 20 Mbps—an edge-case failure [SmallNetBuilder, 2021].
What travel-size LTE hotspot is worth buying?
Look for Cat-6 models like Huawei E5788; dual-band CA, 300 Mbps peak, 10-hour battery. Even Alcatel MW40 suffices for two phones but not heavy workloads [Elektroda, matek451, post #18228374]
What happens if I use 10 m of H155 cable anyway?
Expect 6-7 dB extra loss; every 3 dB halves power, so your 9 dBi antenna acts like ~2 dBi—almost negating the upgrade [Elektroda, matek451, post #18227756]
