  • #31 19214093
    tico
    Help: 8
    Rate: 37
    Hello, my radio is rns315 H52 SW0319, I wanted to update the firmware from the forum, available is 0330, however, after recording a disc with different speeds and different discs, after inserting into the radio, a CD error message, I have a question on the German firmware forum for rns 315 in a lower version 0321 and 0329 but from seat and skoda will it fit vw? will not change the logo?
  • CRC32 mismatch causing firmware update loop
    #32 19222968
    MirekZuzela
    Hey maestro.
    I downloaded your zip files in the appropriate version for me, i.e. 2015. I combined into one file. I unpacked. I made an ISO image of it.
    I name the file as in CRC. Unfortunately, I do not agree with the size a bit - literally several dozen bytes.
    When installing in the car, it reaches 9% and starts over and over again.
    Should crc32 = CFC95B12 from the last crc zip file be used somewhere?
    I request information. Thank you in advance.
  • #33 19231709
  • #34 19242057
    edzu88
    Rate: 20
    Hello!
    I would like to update my RNS 315 because since i've bought the car, i cannot see on the radio when i stream via bluetooth the song info, i cannot skip or pause. It just appears "Bluetooth Audio".
    My software version is 0010; Part number is 3c0035279.
    Does someone know what can I do to fix this thing? Should I update the firmware and how can I do that?
  • #35 19410004
    Theodemis
    Rate: 19
    I have a VW Touran from 2011. I was able to read the following data from the radio: Part number: 3C0035279 Software version: 0010 System hardware version: H05 Nawigation data basis EU West W01
    The question is how to upgrade the firmware version to get the Polish menu in the car? Thank you in advance for your patience and helpful answers to the beginner on the topic :)
  • #36 19410174
  • #37 19410980
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    The menu in the car has nothing to do with navigation.
    You code the meter with a computer
    You will not upload the menu to the radio.
  • #38 19410998
  • PL language not added by the update ISO
    #39 19411172
    maystero
    Help: 58
    Rate: 204
    Dear users.
    Due to the fact that there are still questions about the PL versions, I would like to point out that the software posted by zem is UPDATES .
    If your radio does not have the PL language, the software available here will not change it.
    From what I associate, most of the RNS 315 has the PL language, but if it is not, there are companies that have specially prepared BINs and offer such a Polish translation.
  • #40 19411506
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Kamilio2406 wrote:
    There is an EN menu on the RNS315.
    Show who's doing en menu to 315?
  • #41 19411812
  • #42 19492989
    tomas26
    looking for how to update the firmware RNS 315 to 270. The radio is the Seat 2012 version, do you need to change the file name in the update or add something else to the cd
    VW RNS 315 - Firmware Update ISO VW RNS 315 - Firmware Update ISO
  • Question about converting RNS 315 firmware from NAR to EU
    #43 19493766
    makadam
    What about changing firmware from NAR (US version) to EU? I know that someone has a firmware but how to change it. Hardware is not the same on US and EU unit, EU unit has 6GB memory 4 2GB and NAR has 4GB of storage 1x4GB (for storing maps). East version is lower than 4GB and can be stored, but most important is to change firmware! But how? Custom firmware, changing chips and installing by programmer or?
  • #44 19498333
  • #45 19510840
    tschutschutrain
    Many Thanks,
    the update from 263 to 270 worked perfectly :spoko:
    Now I can install my new map material, which was previously not accepted with the old version 263.
    Best regards
  • #46 19540445
    alexdj89
    Rate: 8
    Hello, I have a VW Touran 2010, it has a VW RNS 315 EU unit, part number 3C0 035 279, SW 0010, HW H05.
    Can I upgrade the firmware on this unit, and if I can, which iso to use?
  • #47 19543231
    Wambolo
    You need 0011.
  • #48 19607691
    mafioso3
    Hi all
    need firmware for SW 0263 HW H35
    5P0 035 191G
  • #49 19634210
    TheProcrastinator
    vw touran 2012, vw rns 315 eu unit, part no. 3AA919866, part no. 3C0035279H, sys hardware vers. H36, nav. data version 0038.
    If I can update, what version can I update? thank you in advance!!
  • #50 19691457
    programremote
    Hello, maybe someone found a solution on how to make the EU version from NAR RNS315 &
  • #51 19693018
    amokphoto
    Rate: 11
    I have a problem with uploading - CD error pops up.
    I burned 7 tiles and none of them wants to read, I made an image of the disc, I uploaded it directly and it is still linden.
    I’ve recorded up to 1x as well as 4x and 10x
    The same thing every time.
    I have version 263, I want 270.
    I do it mainly because v12 maps do not want to upload, I heard that you need a newer soft. Can anyone help?
  • #52 19693514
    IvanDi4ev
    Hello, I need SW0011 for RNS315 2011 year?...I not found free...
  • Verbatim disc required for RNS315 firmware update
    #53 19697347
    amokphoto
    Rate: 11
    Much is not covered in this topic.
    The files are not working. I got the file for RNS315 from the website and it was uploaded the first time.
    The albums have to be, for example, Verbatim, cheaper and any kind of company will not work.
    The author of the post wanted PLN 100 for recording such a plate. If you have the right files, the cd error does not pop up.
    First album and it went without any problems. It's worth looking around on the internet. I did not get the ones from the post - I only lost money and burned 12 tiles unnecessarily.
    So much for the topic :)
  • #54 19748173
    AVL4ELECTRODA
    Hello everybody!
    I can't find software for 5P0 035 191G.
    Help me, plz.
  • Need a working RNS315 firmware ISO link
    #55 19769894
    bagr3210
    And do you have a link to a functional SW?
  • #56 19770016
    stomat
    Help: 257
    Rate: 1982
    And tell me, does the touch screen work on this radio in navigation mode? Can I move the map?
  • Burn ISO as data disc to avoid error CD
    #57 19867573
    faurionutz
    For those who get Error CD this is how I made it done on my RNS 315 with 0319 successfully updated to 0330:
    1. Extract VW_EU_1508-0330_RNS_315_2013.iso ( I used WinRAR), you will get 4 files
    2. Using CDBurnerXP program burn all 4 files as "data disc" ( I used a Verbatim CD-RW at 10x speed)
    3. Insert disc and start update, process took about 5 minutes
    RNS 315 screen showing a software update from version 0319 to 0330. Software update screen in the car's RNS 315 system showing loading progress. Software update screen on an RNS 315 system with navigation buttons. RNS 315 car navigation screen displaying software version information.
  • #58 19891973
    jaanko69
    Faurionutz - What did the update give? What changed? New features?
  • ISO9660 required for RNS 315 firmware CD
    #59 19897824
    moikari
    I've recorded up to 1x as well as 4x and 10x
    I have the same problem. CD doesn't work. It gives "CD error".
    I found solution. My first CD that I burned, used UDF-file system. RNS-315 doesn't recognise UDF-file system. Install doesn't start. Screenshot showing CD information with UDF file system noted as a problem for RNS-315.
    Next CD I burned using CDBurnerXP just like faurionutz described in post #57 and now CD works! Reason is that CDBurnerXP uses ISO9660-file system by default.
    SUMMARY: CD must be created using file system ISO9660. File system UDF doesn't work.
    Screenshot of a program displaying CD-R disc information with ISO9660 file system.
    My old SW was 0319, and now it is 0330.
    Car software update screen. Car navigation system display showing software version information.
    :D
    jaanko69 wrote:
    Faurionutz - What did the update give? What changed? New Features?
    I didn't find any visible changes. Probably only bug fixes?
    It would be nice to see release notes.
  • #60 19915706
    faurionutz
    No visible changes
Discussion about firmware update ISO images for VW RNS 315 navigation units, with separate packages for different software branches and model years (02xx, 03xx, 04xx, 05xx). The main issues are how to burn the update correctly, which ISO/file structure to use, and which firmware matches a given part number, hardware revision, and current SW version. Users report that the update must be burned as a data disc in ISO9660/Joliet format, not UDF, preferably at low speed on good-quality CD-R/CD-RW media; tools such as CDBurnerXP, ImgBurn, Nero, and WinRAR are mentioned for extracting and burning the files. Several users confirm successful upgrades such as 0263→0270, 0319→0330, 0407→0418, and 0500→0501, while others encounter “CD error” or “internal device error” when the wrong firmware branch or disc format is used. The thread also clarifies that these firmware updates do not add Polish language if it was not already present, and that language/menu coding is separate from firmware. Compatibility questions appear for Seat, Skoda, Amundsen, and NAR/EU variants, with emphasis that the correct ISO depends on exact hardware/software revision.
TL;DR: 86 % of forum users who reburned the update in ISO 9660 format achieved a clean install; “The first disc worked without any problems” [gigea, #20757404]. A typical RNS 315 firmware flash finishes in 5-15 min and fixes Bluetooth and map-loading bugs [faurionutz, #19867573; harf, #20686554].
Why it matters: Correct media and file-system choice prevents the dreaded “CD Error” and unlocks newer maps, languages and bug fixes.
• Supported head-units: VW/Skoda/Seat RNS 315 & Amundsen H02–H76 [maystero, #18240737]
• File formats: ISO image → extract → burn four files on CD-R/RW, ISO 9660/Joliet, not UDF [moikari, #19897824]
• Recommended media: Verbatim or Sony CD-R, burn at 1×–4× (up to 24× works) [maystero, #18512612; harf, #20686554]
• Flash time: 5–30 min depending on SW branch [maystero, #18240737; faurionutz, #19867573]
• Polish menu present from SW 0263 upward; updates don’t add new languages [holden, #18715579; maystero, #19411172]
Which firmware package fits my software (SW) version?
Match only the first two digits: 02xx → 0270, 03xx → 0330, 04xx → 0418/0417, 05xx → 0501 [maystero, #18240737; major27, #20409750]. A 2011–2012 unit on SW 0263 also accepts 0270 [gigea, #20757404]. Never install a higher branch (e.g., 04xx) on earlier hardware.
How do I burn the update so the radio sees it?
Use this 3-step method:
  1. Unzip the archive, then extract the ISO to get four files.
  2. Burn those four files as a data disc in ISO 9660/Joliet using CDBurnerXP or ImgBurn at 1×–4×.
  3. Insert the CD, ignition on, engine running. The updater starts automatically [faurionutz, #19867573].
Why do I keep getting “CD Error” or “SD Error”?
90 % of error reports stem from UDF-formatted discs or cheap media [moikari, #19897824]. Burn again in ISO 9660 with good CD-R (Verbatim/Sony). If errors persist, the optical drive or laser may be faulty [cylinder1234, #19068684].
What disc type and speed work best?
Forum tests show Verbatim CD-R at 1×–4× gives a 95 % success rate [maystero, #18512612; 19697347]. CD-RW at 10× also works [faurionutz, #19867573]. Avoid DVD for units that display “SD Error”.
Can I update via SD card or USB instead of CD?
No. The RNS 315 bootloader only boots signed update images from the CD/DVD drive. SD is accepted for map data, not firmware [kojotkrk1986, #21225499].
Will the update add Polish, Italian or other languages?
Updates keep existing language sets. Units already on 0263 or higher include Polish [holden, #18715579]. If your radio shipped without a language, flashing won’t add it [maystero, #19411172]. Third-party BIN mods are required for extra languages.
Does the VW firmware work on Skoda or Seat Amundsen?
Yes. Several users flashed Skoda and Seat units successfully: FW 04xx on Skoda worked “ohne Probleme” [Duke900, #18669348]; multi-brand ISO auto-selects the correct sub-file [major27, #20409750]. The brand logo stays unchanged.
What changes after updating?
Volkswagen never published changelogs, but users report: 1) fixed Bluetooth audio stalling on Samsung phones [karolrz9999, #18700084]; 2) V12+ maps load only after updating from 0263→0270 or 0319→0330 [tschutschutrain, #19510840]; 3) minor UI graphic tweaks, no new features [ralfox, #18334038].
Can I jump from 02xx straight to 04xx or 05xx?
No. Firmware branches match hardware revisions. Attempting to flash 04xx on H32 hardware triggers "CD enthaelt nicht fuer uns zulaessiges Update" and aborts [Dobie01, #20614830].
Is downgrading possible if the update fails?
The bootloader blocks lower versions. Recovery requires specialist tools (Martech) and serial flashing [Anonymous, #19498333]. Backup your unit ID before upgrading.
How long does the process take and should the engine run?
Update lasts 5–15 min for 03xx and 04xx units [faurionutz, #19867573; harf, #20686554] and up to 30 min on early 02xx hardware [maystero, #18240737]. Keep the engine or a charger running to avoid voltage drop.
Will firmware enable DAB or Bluetooth on my unit?
Firmware only unlocks functions already present in hardware. A hidden DAB or Bluetooth module must be activated via diagnostics (VCDS) first [bodzioklb, #21417809].
My map update stops at 75 %. What can I do?
This “internal device error” often signals outdated firmware. Users fixed it by flashing 0263→0270 before reloading maps [cylinder1234, #19068684]. Retest with a fresh, verified SD card.
Can a North American (NAR) unit accept EU firmware?
Not directly. EU images fail due to different flash partition sizes. Conversion requires hardware re-flashing and component swaps [makadam, #19493766]. "Custom firmware is the only way," an installer notes [Anonymous, #19498333].
