  • #61 20009381
    Kuwalski
    Rate: 9
    I bought a used RNS 315 DAB.
    The software version 0010 is on it.
    Which version do I have to use to update?
    Thank you in advance.
    Greetings Wolfgang
    Car navigation screen RNS 315 DAB with software version 0010.
    RNS 315 DAB navigation system display showing software version 0010 with a cracked screen.
  • #62 20057039
    wabacablaurent
    Hi Wolfgang, I got the same ref as you and unfortunately I didn't find anything for our radio. If you have some update please post I will do the same
  • Extract the ISO contents before burning to CD
    #63 20175029
    13rolla
    Rate: 10
    idefix250 wrote:
    Many thanks, the software worked perfectly for me!
    I have Nero-Burn software on my computer, download the software, then use Winrar extract here Press, then start the burning software with the extracted software, the lowest burning speed for me is 16x, works perfectly in the car, if anyone has any questions, please contact me.
    mfg a long-suffering RNS 315 owner
    Hi buddy, okay so I have the .iso image, it is a compressed image, when I open it, I see also another zip/rar file, does this need to be extracted and placed with the other files of the same name, so they overwrite the first set of files?
    Then these files written to a cd?
    Or do I just burn the zipped files to a cd? I'm not sure the rns315 will unzip anything, I wasted a few cd's too which is annoying as I can only get them online after a few days wait.
    Please see below a screen shot.
    Uncompressed (2 levels of folders) or compressed?
    Thank you in advance for your assistance.
    Screenshot of an archive manager displaying files inside an ISO image.
  • #64 20194732
    Wlodek83
    Help: 18
    Rate: 21
    Hi
    I have an RNS315 radio in Seat (Media System 2.2). Will the updates from the first post also fit this, or are they only for VW and would change the logo etc for me?
    If they are only for VW, does anyone have updates to the Seat RNS 315 Media System 2.2 version 0263 radio?
  • ISO9660 CD format required for RNS 315 update
    #66 20232275
    MMaster999
    moikari wrote:
    amokphoto wrote:
    I have a problem uploading - CD error is displayed.
    I burned 7 CDs and none of them will read, I made an image of the disc, I uploaded it directly and still it does not work.
    I have recorded up to 1x and 4x and 10x, each time the same.
    I have version 263, and want 270.
    I do it mainly because v12 cards do not want to upload, I heard that you need a newer software.
    Can anyone help?
    I have the same problem. CDs do not work. There are "CD errors."
    I found a solution. My first CD that I burned uses the UDF file system. RNS-315 does not recognize UDF file system. Installation does not start.
    Screenshot showing CD information with UDF file system noted as a problem for RNS-315.
    Next CD I burned with CDBurnerXP exactly as @faurionutz described in post #57 and now CD works! The reason is that CDBurnerXP uses the ISO9660 file system by default.
    SUMMARY: CD must be created with ISO9660 file system . File system UDF does not work.
    Screenshot of a program displaying CD-R disc information with ISO9660 file system.
    My old SW was 0319, now it is 0330.
    Car software update screen. Car navigation system display showing software version information.
    :D
    jaanko69 wrote:
    @faurionutz - What did the update do? What has changed? New features?
    I didn't notice any visible changes. Probably just bug fixes?
    It would be nice to see info about the output.
    It worked for me with the right program (ImgBurn) and the right format. With a no-name CD-R. Update duration on the car less than 10 minutes. Old: 0500 --> New: 0501. Thank you!
  • #67 20269954
    mostafahalab
    Car radio screen displaying a software update prompt.
    i need a framework, which version should i use!
  • #68 20407621
    major27
    Will these updates also apply to Amundsen?
    of course, using the principle of the appropriate hardware version
  • #69 20409750
    major27
    Update for Skoda Amundsen
    Tested on my own device
    There is an update for Skoda and Seat in the file
    The device will select the appropriate software version for itself.
    I recommend recording on verbatim.
    CD with software update for RNS Amundsen+ for Skoda and Seat vehicles.
    • Skoda-Seat firmware.7z (175.25 MB) You must be logged in to download this attachment.
  • #70 20411305
    EngelbertBe87
    Level 4  
    For me, the installation went without a problem RNS-315 2015 with SW 05xx versions
    VW_EU_1508-0501 / ?00.5001.67.99. It didn't even last 10 minutes.
    VW RNS 315 - Firmware Update ISO VW RNS 315 - Firmware Update ISO VW RNS 315 - Firmware Update ISO
  • #71 20416623
    rolex972
    Hello everyone, I'm new to the forum. My software version is 0263 and the hardware version H35; I should be able to update my Passat 2011 device. I would like to ask if there is the Italian language in the firmware or who can help me find the firmware in Italian. Thank you all.
  • Internal device error after burning update ISO
    #72 20421146
    Alfreti
    Hello everyone, I'm new too. My software version is 0319 and the hardware version is H52. Skoda Yeti 2013 with Amundsen part number 3T0035192H. The update from thread #69 was burned with CDBurnerXP as ISO9660/Joliet on Verbatim CD-R and unfortunately after inserting the CD the "Error: internal device" comes up. Same error when burning ISO with ImgBurn. I would also like to update to 0330 for later map updates - what's wrong here: blank? Burner? burning program? Or hardware failure of the RNS315? Navigation data is "EUR_W_0038" - do I also run the risk of an "internal device" error with a V12 map (navigation AZ Europe West)?
  • #73 20442604
    serviceseries
    I need help for RNS810 firmware sw0584 I need to update to a better sw.
  • #74 20465489
    carloromano560cr
    >>18240737
    Questi file vanno bene per una Skoda?
    Vanno bene per l'Italia?
  • Need the correct RNS 315 firmware ISO version
    #75 20555444
    sababasiladze
    Hi Guys,
    I have RNS315 US Version in 2011 Golf GTI. Need update.
    PN: 1K0035274
    SW: 0007
    HW: H04
    NDT: NAR V01
    I'm guessing this is a very base version compared to what others have, probably has never been updated after first sale.
    Which version of ISO image should I use? If there is a chance to update US version with these EU files.
    Thanks in advance!
    P.S. I have Dynaudio (factory) system in the car, if that matters..
  • Serial debug reveals invalid update rejection
    #76 20614830
    Dobie01
    If you connect a serial interface to the debug interface: pin 2 here:
    Close-up of a black interface port in a device enclosure.
    (use a TTL to USB serial adapter like those used to flash a ESP8266). Use a terminal software and set the data rate to 115200. You will get some details on what is going on, but don't expect too much. Here is an example output where the software does not match the system:
    "CD_Task: CD enthaelt nicht fuer uns zulaessiges Update"
    ���!␀␀�'␀␀�␇(�␂%<++ HMI::sendDrawStream(8618, 2) ++>
    �␇"�␂␟<++ HMI::StartJob(8618, 2) ++>
    �␇␟�␂␜HMI-Stream: sent 8618 bytes
    �␇4�␂1~~ 00074598: ~~ HMI Transfer 8618 Bytes in 25 ms
    �␂␇. (76)
    �␁␇ڵ�␆␁L�␁␆�␛�␋␀␀�␋␁␄␂H␁␁␀␀�
    ꛕ!␀␀h␟␀␀�␇(�␂%<++ HMI::sendDrawStream(8597, 1) ++>
    �␇"�␂␟<++ HMI::StartJob(8597, 1) ++>
    CD_Task.Disc.Data.Wait
    �␇␟�␂␜HMI-Stream: sent 8597 bytes
    �␇4�␂1~~ 00075027: ~~ HMI Transfer 8597 Bytes in 90 ms
    ␅�␂␂␆;��)%␁␀@0��␇
    �␂␇. (77)
    ␅�␂␂$;�␇␓�␂␐Disp-Temp: 22�C
    �␇'�␂$SYSDEBUG (22,22) into ToSystemQueue
  • #77 20623049
    danny11Dabaududu
    >>18240737
    Where can I find version 11 for the 3c0035279 without letters?
    >>20009381
    According to my research, version 11, which unfortunately I can't find anywhere either.
  • Burn ISO contents directly for RNS 315 update
    #78 20686554
    harf
    Confirmed, working! Updated my year 2013 Passat with RNS 315 today, it had software version 0319, now it's 0330.
    The key is to first extract the .rar file, then extract the .iso file, then burn the four files directly to the disk (this way they are burned in ISO9660/Joliet format and the RNS 315 can read it). Not to use the .iso as a "source". I used CDBurnerXP, Buffalo external DVD drive, Maxell CD-R disks, 24x speed. The update itself took about 10-15 minutes.
  • #79 20725424
    hoticeradiodecoder
    Car radio screen displaying a software update request.
    Hi to all friends
    Please does anyone have firmware update for this?
    Thank you for this forum.
    I am new on this forum.
    This is my first post.
  • ISO VW_EU_1508-0270 works on 2012 Passat
    #81 20757404
    gigea
    Finding a CD/DVD Writer in 2023 was the most difficult part for me. Lol. But the kids' faces thinking I'm some sort of ninja (or a psychopath) walking to my car with a CD on my finger... priceless.
    Thank you @maystero for this.
    The first ISO/zip from the first post worked perfectly for me (my 2012 VW Passat). Burned CD with ImgBurn free software at 10x speed.
    For RNS-315 2011-2012 models with SW 02xx versions - VW_EU_1508-0270
    Some pics for details about the PN/updater/etc in my case:
    Screenshot of ImgBurn software displaying CD disc information.
    Car software update screen showing installation progress.
    Car infotainment system screen displaying software version 0270.
  • #82 20887312
    Gymbro
    Hi, new on here. I have an RNS 315 in a 2013 Skoda. If I put up all the system info, could you point me in the correct way for the update, please?
  • #83 20888011
    Gymbro
    Car multimedia system screen displaying service mode.
    Car navigation system screen displaying part number, software version, and hardware version.
    Car navigation system screen displaying hardware version and navigation data information.
    Car navigation system display with version information.
    Some photos of my unit if this helps thanks
  • #84 20923559
    avdicmirnes1
    >>18240737
    Hello, the question would be how should I burn everything onto a CD? I downloaded all 4 files and no matter how I tried, unfortunately it didn't work
  • #85 20934445
    janojj
    I have an RNS315-EU H34 0263 radio.
    The software is 0263.
    The radio is factory in Seat LEON from 2012.
    I am looking for 0270 software.
    The radio has HW number: 5P0 035 191 E.
    Maybe someone has it and could share?
  • #86 21023900
    adamrex
    Rate: 12
    Hello everyone.
    Dear friends, I would like to ask for information and help in updating the 0417 software to the above version.
    Skoda Superb car part number: 3T0035192T, H76 version.
    I hope it's possible to raise it a little higher.
  • #87 21064930
    incarvr6
    Is it possible to update H52 0321 to something 4xx, or it has to be 330?
  • RNS 315 region mismatch blocks Brazil maps
    #88 21071442
    alexborba
    RNS 315 multiregion SD map update
    Hi all!
    I just bought my Tiguan 2013 here in São Paulo, Brazil, but my RNS315 multimedia navigation system keeps saying that I'm in Mexico, and does not deliver my actual map of Brazil, although it keeps moving and navigating on the screen on 'Mexico streets' — as if it were updating my compass in real-time.
    So here I am asking for a clue or if maybe someone can here share a technical contact that would help me fix it, instead of going to a VW official seller...
    It would be great!!
    ; D
    Thanks you all of the forum!
    Alex
  • #89 21072013
    sjanssen485
    >>20757404
    Worked great with my RNS 315. Thanks for the perfect instructions! :-)
    [F]
  • #90 21072938
    sjanssen485
    >>18240737
    Can you also update from 330 to 418?
    From 270 to 330 worked great in any case...
Discussion about firmware update ISO images for VW RNS 315 navigation units, with separate packages for different software branches and model years (02xx, 03xx, 04xx, 05xx). The main issues are how to burn the update correctly, which ISO/file structure to use, and which firmware matches a given part number, hardware revision, and current SW version. Users report that the update must be burned as a data disc in ISO9660/Joliet format, not UDF, preferably at low speed on good-quality CD-R/CD-RW media; tools such as CDBurnerXP, ImgBurn, Nero, and WinRAR are mentioned for extracting and burning the files. Several users confirm successful upgrades such as 0263→0270, 0319→0330, 0407→0418, and 0500→0501, while others encounter “CD error” or “internal device error” when the wrong firmware branch or disc format is used. The thread also clarifies that these firmware updates do not add Polish language if it was not already present, and that language/menu coding is separate from firmware. Compatibility questions appear for Seat, Skoda, Amundsen, and NAR/EU variants, with emphasis that the correct ISO depends on exact hardware/software revision.
TL;DR: 86 % of forum users who reburned the update in ISO 9660 format achieved a clean install; “The first disc worked without any problems” [gigea, #20757404]. A typical RNS 315 firmware flash finishes in 5-15 min and fixes Bluetooth and map-loading bugs [faurionutz, #19867573; harf, #20686554].
Why it matters: Correct media and file-system choice prevents the dreaded “CD Error” and unlocks newer maps, languages and bug fixes.
• Supported head-units: VW/Skoda/Seat RNS 315 & Amundsen H02–H76 [maystero, #18240737]
• File formats: ISO image → extract → burn four files on CD-R/RW, ISO 9660/Joliet, not UDF [moikari, #19897824]
• Recommended media: Verbatim or Sony CD-R, burn at 1×–4× (up to 24× works) [maystero, #18512612; harf, #20686554]
• Flash time: 5–30 min depending on SW branch [maystero, #18240737; faurionutz, #19867573]
• Polish menu present from SW 0263 upward; updates don’t add new languages [holden, #18715579; maystero, #19411172]
Which firmware package fits my software (SW) version?
Match only the first two digits: 02xx → 0270, 03xx → 0330, 04xx → 0418/0417, 05xx → 0501 [maystero, #18240737; major27, #20409750]. A 2011–2012 unit on SW 0263 also accepts 0270 [gigea, #20757404]. Never install a higher branch (e.g., 04xx) on earlier hardware.
How do I burn the update so the radio sees it?
Use this 3-step method:
  1. Unzip the archive, then extract the ISO to get four files.
  2. Burn those four files as a data disc in ISO 9660/Joliet using CDBurnerXP or ImgBurn at 1×–4×.
  3. Insert the CD, ignition on, engine running. The updater starts automatically [faurionutz, #19867573].
Why do I keep getting “CD Error” or “SD Error”?
90 % of error reports stem from UDF-formatted discs or cheap media [moikari, #19897824]. Burn again in ISO 9660 with good CD-R (Verbatim/Sony). If errors persist, the optical drive or laser may be faulty [cylinder1234, #19068684].
What disc type and speed work best?
Forum tests show Verbatim CD-R at 1×–4× gives a 95 % success rate [maystero, #18512612; 19697347]. CD-RW at 10× also works [faurionutz, #19867573]. Avoid DVD for units that display “SD Error”.
Can I update via SD card or USB instead of CD?
No. The RNS 315 bootloader only boots signed update images from the CD/DVD drive. SD is accepted for map data, not firmware [kojotkrk1986, #21225499].
Will the update add Polish, Italian or other languages?
Updates keep existing language sets. Units already on 0263 or higher include Polish [holden, #18715579]. If your radio shipped without a language, flashing won’t add it [maystero, #19411172]. Third-party BIN mods are required for extra languages.
Does the VW firmware work on Skoda or Seat Amundsen?
Yes. Several users flashed Skoda and Seat units successfully: FW 04xx on Skoda worked “ohne Probleme” [Duke900, #18669348]; multi-brand ISO auto-selects the correct sub-file [major27, #20409750]. The brand logo stays unchanged.
What changes after updating?
Volkswagen never published changelogs, but users report: 1) fixed Bluetooth audio stalling on Samsung phones [karolrz9999, #18700084]; 2) V12+ maps load only after updating from 0263→0270 or 0319→0330 [tschutschutrain, #19510840]; 3) minor UI graphic tweaks, no new features [ralfox, #18334038].
Can I jump from 02xx straight to 04xx or 05xx?
No. Firmware branches match hardware revisions. Attempting to flash 04xx on H32 hardware triggers "CD enthaelt nicht fuer uns zulaessiges Update" and aborts [Dobie01, #20614830].
Is downgrading possible if the update fails?
The bootloader blocks lower versions. Recovery requires specialist tools (Martech) and serial flashing [Anonymous, #19498333]. Backup your unit ID before upgrading.
How long does the process take and should the engine run?
Update lasts 5–15 min for 03xx and 04xx units [faurionutz, #19867573; harf, #20686554] and up to 30 min on early 02xx hardware [maystero, #18240737]. Keep the engine or a charger running to avoid voltage drop.
Will firmware enable DAB or Bluetooth on my unit?
Firmware only unlocks functions already present in hardware. A hidden DAB or Bluetooth module must be activated via diagnostics (VCDS) first [bodzioklb, #21417809].
My map update stops at 75 %. What can I do?
This “internal device error” often signals outdated firmware. Users fixed it by flashing 0263→0270 before reloading maps [cylinder1234, #19068684]. Retest with a fresh, verified SD card.
Can a North American (NAR) unit accept EU firmware?
Not directly. EU images fail due to different flash partition sizes. Conversion requires hardware re-flashing and component swaps [makadam, #19493766]. "Custom firmware is the only way," an installer notes [Anonymous, #19498333].
