[Solved] Parkside vs DeWalt? Weird? - What's better? The price is similar, but there
TomeG2kc 43791 33
Should I choose a Parkside Performance PABSP 20-Li A1 or a DeWalt DCD776 for occasional woodworking and light DIY, and is the DeWalt hammer function worth it?
DeWalt is the safer choice here; the thread leans against Lidl/Parkside tools on ergonomics and reliability, while DeWalt is described as better quality overall [#18303181][#18304200][#18306845] Brushless vs. brushed is not a big practical difference in use, and one reply notes that brushed tools are simpler and less failure-prone because there is no inverter, while brush replacement is cheap [#18313771][#18314557] For your use, the hammer function is not a decisive advantage because you already have a corded Bosch hammer drill for concrete, so the DeWalt’s hammer mode does not add much [#18313771] One user who compared the Parkside Performance unit found it defective on arrival and said the DeWalt performed slightly better in practice, with similar runtime despite the smaller battery [#18326014] So the thread’s practical recommendation is to keep the DeWalt unless you specifically want the Parkside’s longer warranty and brushless marketing points [#18326014]
  • Parkside drill showed clutch slip and battery weakness
    #32 18326014
    TomeG2kc
    Rate: 11
    I also bought his Parkside for comparison (free return within 30 days) and what turned out?
    The wind handle (the so-called fur) had the paint scratched off in some places, in one even a 1 cm scratch. Additionally, when the "fur" was held in the 1st gear, of course, you could hear the clutch jumping - and it was normal. But when I was still holding the "fur" and changing the revs with the other hand, the engine was getting very high-pitched (and probably revs too). So so far us Parkside Performance Cordless Drill Flew as a defective return.
    A test by the same author appeared on the Internet as someone previously wrote down a link of this screwdriver with some expensive brushless DeWalt.
    As expected, the DeWalt was a bit better (see stronger, he got more screws, but only a little + 10%). But what amazed me was that the Parkside had a 2Ah battery and the DeWalt a 1.3Ah - and both had been running for a similar amount of time on a single charge. Something tells me that Parkside Performance's switch to the X20VTeam series batteries was a shot in the foot.
    He stays with DeWaltt. Thanks to all the speakers, I hope that someone will find it useful to tav polemics. Regards
    Thomas.
  • #33 18326031
    freebsd
    Help: 767
    Rate: 2035
    I received this information and no other information. Zero information from Lidl
    "We have finished the service cooperation with Lidl.
    Please contact the Lidl hotline to arrange a new service for their devices. "
  • #34 18330877
    TomeG2kc
    Rate: 11
    Thanks to the information from forum members and the shipment, the problem / question solved itself when I received the screwdriver in my hand - it was used, so I already got burned and stays with DeWaltt.
    Thanks again all ?
The discussion centers around a comparison between Parkside and DeWalt power tools, specifically focusing on the Parkside Performance PABSP 20-Li A1 and the DeWalt DCD776. Users express skepticism about the quality of Parkside tools, citing issues with ergonomics, durability, and performance, particularly in the context of DIY and professional use. Many participants favor DeWalt for its reliability and reputation, despite acknowledging that Parkside offers a longer warranty (5 years) and a brushless motor. Concerns are raised about the overall quality of Lidl's tools, with several users sharing negative experiences regarding their performance and build quality. The conversation also touches on the importance of battery quality and the potential for repairs, with some users recommending alternatives like YATO for better value.
TL;DR: Parkside’s brushless PABSP 20-Li A1 delivers 60 Nm vs DeWalt DCD776’s 42 Nm torque, yet “DeWalt is not the quality from 7 years ago” [Elektroda, TomeG2kc, #18302692; Elektroda, freebsd, #18303181]. Most users still pick DeWalt for reliability despite the spec sheet. Why it matters: Specs alone don’t predict lifetime or service access.
• Parkside Performance PABSP 20-Li A1: 60 Nm hard torque, 1.6 kg with 2.5 Ah battery [Elektroda, TomeG2kc, post #18302692] • DeWalt DCD776: 42 Nm hard / 24 Nm soft torque, 1.705 kg with 1.3 Ah battery [Elektroda, TomeG2kc, post #18302692] • Warranty: Parkside 5 years tool/1 year battery; DeWalt 3 years after online registration [Elektroda, TomeG2kc, post #18302692] • Typical street price (PL): Parkside set 349 PLN; DeWalt clearance set 427 PLN [Elektroda, TomeG2kc, post #18302692] • Reported early failure: Parkside hammer stator melted after 20 minutes use [Elektroda, ptero, post #18306845]
Which drill/driver lasts longer in everyday DIY: Parkside Performance or DeWalt DCD776?
Forum feedback shows recurring Parkside switch and stator failures within months, while DeWalt issues are usually worn brushes after years [Elektroda, ptero, #18306845; Elektroda, freebsd, #18303181]. DeWalt’s service network and parts availability increase tool life.
How significant is the 60 Nm vs 42 Nm torque gap?
For soft materials like pine or pallet wood, both torque levels drive 6 × 120 mm screws; users saw only a 10 % screw-count edge for Parkside’s 60 Nm figure [Elektroda, TomeG2kc, post #18326014] In concrete you’ll need a rotary hammer anyway.
Does the hammer (“stroke”) mode on DeWalt add value?
Yes. The integrated percussion function drills Ø6 mm holes in brick without a corded hammer, saving setup time [Elektroda, TomeG2kc, post #18302692] Parkside lacks this mode.
Are Parkside batteries interchangeable across series?
Performance-series batteries are NOT compatible with the green X20 V Team line [Elektroda, TomeG2kc, post #18302692] That limits affordable spare packs.
What’s the biggest failure edge-case reported for Parkside?
A new Performance rotary hammer fused its fan and stator cover after 20 minutes continuous load [Elektroda, ptero, post #18306845]
How do I spot a refurbished or fake DeWalt battery?
  1. Check production date stamp; mismatched dates signal re-celling.
  2. Weigh pack; lighter weight suggests cheaper cells.
  3. Open vent to inspect weld uniformity. [Elektroda, E8600, post #18303998]
Can I service either tool myself?
DeWalt: brushes, triggers, and packs are sold separately online. Parkside: proprietary brushless control boards lack schematics, making DIY repair “impossible” for grinders and similar tools [Elektroda, wisnija, post #18317608]
Does warranty coverage differ in practice?
Parkside’s 5-year claim still needs working Lidl service; one member got “zero information” after the provider changed [Elektroda, freebsd, post #18326031] DeWalt requires online registration within 4 weeks but offers established centres.
What’s a simple 3-step test before your return window closes?
  1. Run tool 2 min in each gear under no load.
  2. Drive ten 6 × 100 mm screws into softwood, noting clutch slippage.
  3. Switch speeds while shaft stalled; listen for pitch jump indicating gearbox mis-alignment [Elektroda, TomeG2kc, post #18326014]
Are cheaper supermarket brands like Niteo Tools comparable?
One user found a 60 Nm Niteo at 250 PLN but still deemed DeWalt superior if batteries are genuine [Elektroda, E8600, post #18303998]
What runtime should I expect per charge?
A 2 Ah Parkside pack and 1.3 Ah DeWalt pack both emptied after roughly the same work session—about 30 large screws—according to a hands-on comparison [Elektroda, TomeG2kc, post #18326014]
