[Solved] ESP32 ADC and noise from VS1053 for audio spectrum analyser
faber 1944 4
  • #1 18359933
    faber
    Help: 49
    Rate: 36
    I am adding an audio equalizer in the ESP32 + VS1053 circuit. The audio signal from the VS1053 goes to the amplifier. I fed one channel (right) directly to the ADC on the ESP32 for signal analysis (FFT) and spectrum analyser display.
    Generally everything works reasonably ok but there is a lot of noise? And here is my question. Should the signal to the ADC be connected directly ? (I did not use any resistor). Voltage from VS1053 around 1.9V, from what I read ESP32 has 0 to 3.3V
  • #2 18359967
  • #3 18360349
    faber
    Help: 49
    Rate: 36
    Indeed, I've done a bit of reading on the subject of v_ref and characteristics and it's not colourful. But I also came across advice that with ADC_ATTEN_DB_6 (halving the voltage) and using a 220k resistor plus a 0.1 uF capacitor is pretty good. And it looks pretty ok, I've applied and am testing, I can hardly see the noise, it's much better.
    I will organise sound samples and test thoroughly.
  • #4 18360388
  • #5 18361654
    faber
    Help: 49
    Rate: 36
    ok, after many attempts I am left with a 220k resistor and a 0.1uF capacitor, with the ADC_ATTEN_DB_2_5 setting. The analyser works on 4+, the rest I can adjust with ranges.
    PS I measured the v_ref and in my case it is 1094mV, the default setting is as you already wrote 1100mV. This calibration requires changing the readout function everywhere it is used so I will give up. Thanks for your help
