ESP8266 with Arduino UNO does not connect to io.adafruit.com - what code?
robo1973 765 2
  • #1 18411233
    robo1973
    Rate: 59
    Hello !!!
    I have connected the ESP8266 module on TX and RX to an Arduino UNO and cannot connect to the io.adafruit.com platform.
    Below is the program code. On the ESP8266 NodeMCU WiFi module I connect without any problem, and here when I connect the wifi separately I have the problem.
    ESP8266 + Ardurino connects to wifi, but cannot with io.adafruit.com, so that wifi works.
    Maybe something with the WiFiEspClient client; ?
    On the nodeMCU I use WiFiClien ?
    Code: C / C++
  • #2 18412004
  • #3 18413089
    robo1973
    Rate: 59
    Thank you kol khoam for your help Actually setting the speed to 9600 helped
    Greetings !!!!
