How to Program 3-Switch Remote Control Set for Independent Operation?
cjerzy1 1386 2
  • #1 18435921
    cjerzy1
    Rate: 78
    It's about a set of 3 switches (look in the photo attached) controlled by remote control. The problem is that I have not been able to set them so that each works separately, and I have made probably a dozen or so attempts. The problem is that when e.g. no. 1 works well, then when I switch on no. 2, both sockets no. 2 and no. 3 are switched on at the same time. With other programming the situation is similar, e.g. when I switch on remote control no. 3, it also switches on socket no. 1. When it comes to switching off, the situation is similar. Maybe someone also has such a set and was able to programme each socket independently, please let me know how they did it.
    • How to Program 3-Switch Remote Control Set for Independent Operation? DSC00755.JPG (1.6 MB) You must be logged in to download this attachment.
  • #3 18437690
    cjerzy1
    Rate: 78
    Thank you colleague for your help and best regards.
