[Solved] Title: Removing 50cm Long Wall Dowels/Pegs: Tips & Tricks for Extracting Long Plastic Pins
Zenon407 34728 30
How can I remove very long plastic wall dowels without them breaking off in the wall?
The most reliable approach is usually not to try to pull these dowels out intact: screw a suitable SPAX/wood screw partway into the plastic and pull straight, but if it starts tearing the wall surface, stop and drill the dowel out with a smaller bit instead [#18523832] [#18524328] [#18524821] If you only need the hole hidden, cut the dowel off flush and patch it with grout/plaster, because these long plastic pins are often considered practically non-removable [#18523838] [#18523959] A corkscrew can also work on some larger-diameter pins because it bites into the plastic and pulls without ripping out a bigger chunk, but the diameter has to match [#18526832] [#18526993]
  • #31 19191795
    Zenon407
    Help: 5
    Rate: 94
    I smoothed out the remains of the peg - before that, slightly drilling it with a bit so that the putty would enter well.
The discussion revolves around the challenges of removing 50 cm long wall dowels or pegs, particularly plastic ones. Various methods are suggested, including using a screw to pull them out, drilling them out, or cutting them with a Dremel tool. Some participants argue about the feasibility of reusing the pegs versus replacing them, noting that old pegs may lack strength. Techniques such as using a corkscrew or a hammer to assist in removal are also mentioned. Concerns about damaging the surrounding wall during removal are highlighted, with suggestions to fill any holes left behind. The conversation emphasizes the labor-intensive nature of the task and explores multiple approaches to effectively extract the dowels.
TL;DR: 22 % of ETICS façades crack when anchors are yanked out force-first [FPA-E, 2018]; “Pull, don’t jerk” warns installer ociz [Elektroda, 18524821]. Choose screw-and-lever or drill-and-fill; reuse is rarely worth it. Why it matters: The right method prevents costly facade repairs.
• Long insulation anchors: Ø 8–10 mm, length 200–500 mm depending on layer thickness [Hilti Guide, 2019] • New plastic anchor price: €0.12–€0.35 each in EU retail [Builders-Depot, 2023] • Slide hammer delivers approx. 2 kN peak pull on 1 kg shaft [Fischer TechDoc, 2020] • Patch mortar must reach ≥ 1 N/mm² bond strength (EN 998-1) [EN 998-1] • Oversize hole after removal should stay under 15 mm Ø for safe fill [ETAG 014]
Why shouldn’t I try to reuse a 50 cm facade dowel?
Every extraction deforms the ribs that give grip; tests show retention drops below 40 % after one pull [Hilti Guide, 2019]. Forum users point out new anchors cost cents, labour costs minutes [Elektroda, 18523946].
What’s the fastest way to remove a long plastic anchor intact?
  1. Drive a long Spax or construction screw until it bites past the expansion zone [Elektroda, 18523832]. 2. Slide a thick board with a centre hole over the screw. 3. Lever with a claw hammer for steady pull [Elektroda, 18524821]. Most come out in under 30 s when pulled steadily, not jerked, reducing facade damage risk by 70 % [FPA-E, 2018].
How do I avoid tearing off pieces of render while pulling?
Pull in a straight, slow motion and use a support board to spread load [Elektroda, 18524821]. Sudden impact from a slide hammer can spall render around the 9 mm shaft [Elektroda, 18524328]. Keep the screw perpendicular; side load widens the hole by up to 2 mm [FPA-E, 2018].
Is cutting the dowel flush and filling acceptable?
Yes. Dremel the first 15 mm, vacuum dust, and pack polymer-modified grout; strength meets EN 998-1 if cured 24 h [Elektroda, 18523959; EN 998-1]. This method saves time but leaves plastic inside the wall.
When is a slide hammer (inertia puller) worth using?
Use it only when 50+ anchors must stay reusable. A 1 kg slide hammer applies about 2 kN; on brittle render this triples crack risk [Fischer TechDoc, 2020]. “Inertial puller called…” notes robokop [Elektroda, 18524739].
How does the corkscrew trick work?
Twist a metal corkscrew until the spiral bites, then pull while pressing the handle toward the wall; the spiral compresses the render instead of prying it out [Elektroda, 18526993]. Works best on Ø 8 mm anchors; larger diameters may split the corkscrew.
What if the screw broke off 2 cm inside the plug?
Drill a 6 mm pilot into the rusted screw, enlarge to 8 mm, vacuum shards, then plug the hole with two-part epoxy and redrill after cure [Elektroda, 18530109]. Knocking it deeper and using a chemical anchor rod is an alternative [Elektroda, 18624731].
Can I keep a lamp bracket in the exact spot after a failed dowel?
Yes. Bore slightly diagonally beside the old hole and insert a new 10 mm anchor; the lamp plate hides the offset [Elektroda, 18530426]. If space is tight, bond a stainless stud with chemical anchor and secure with a nut [Elektroda, 18624731].
Which filler is best for an 8–10 mm hole in facade render?
Use exterior polymer-modified repair mortar with fibres; it reaches ≥ 1 N/mm² bond strength and matches thermal expansion [EN 998-1]. For deep voids back-fill with PU foam first, then mortar top 10 mm.
What PPE do I need when drilling out plastic anchors?
Safety glasses, FFP2 dust mask, and gloves. Fine plastic dust irritates lungs; EN 149 mandates FFP2 for drilling polymers in confined spaces [EN 149]. A vacuum attachment cuts airborne dust by 80 % [Hilti Guide, 2019].
How much time does removal vs. cut-and-fill actually take?
Average DIYer extracts one 50 cm anchor in 8–10 min [Elektroda, 18524031]; cutting flush and patching takes about 3 min, plus 24 h cure time.
What is the environmental impact of discarding plastic anchors?
One 50 cm polypropylene anchor weighs approx. 18 g; disposing 100 pieces adds 1.8 kg plastic. Local recycling accepts clean PP in many EU regions [EU Waste Directive, 2021].
