Error compiling hello world on ESP32 - how to set paths and IDF_TARGET?
kamilmm 1671 5
  • #1 18623657
    kamilmm
    I'm just starting to "play" with esp32 so don't beat me up for a beginner's question.
    I'm having trouble compiling a simple "hello world.
    What I've done: installed the latest Python and Git for Windows. From https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/windows-setup.html I downloaded the latest installer: esp-idf-tools-setup-2.3.exe, during the installation I selected esp-idf v4, manually added the location to cmake to the PATH (the installer didn't do it).
    Trying to compile (idf.py menuconfig) "hello_world" with "esp-idf\examples\get-started\hello_world" gives an error as below:
    Warn about uninitialized values.
    -- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.25.1.windows.1")
    -- IDF_TARGET not set, using default target: esp32
    -- The C compiler identification is GNU 8.2.0
    -- The CXX compiler identification is GNU 8.2.0
    -- The ASM compiler identification is GNU
    -- Found assembler: C:/Users/mkm/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
    -- Check for working C compiler: C:/Users/mkm/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
    -- Check for working C compiler: C:/Users/mkm/.espressif/tools/xtensa-esp32-elf/esp-2020r1-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- broken
    -- Configuring incomplete, errors occurred!
    See also "C:/esp32/mkm/eclipse-workspace/hello_world/build/CMakeFiles/CMakeOutput.log".
    See also "C:/esp32/mkm/eclipse-workspace/hello_world/build/CMakeFiles/CMakeError.log".
    Executing action: menuconfig
    Running cmake in directory c:\esp32\mkm\eclipse-workspace\hello_world\build
    Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized -DCCACHE_ENABLE=0 c:\esp32\mkm\eclipse-workspace\hello_world"...
    cmake failed with exit code 1
    Any ideas what is wrong?
  • #2 18623852
    adamegah
    Help: 39
    Rate: 92
    Please include
  • #3 18624771
  • #4 18632580
    kamilmm
    Cannot find or there is a corrupted compiler file for xtensa-esp32.
    kamilmm wrote:
    I manually added the location to cmake to the PATH (the installer did not do this).
    And how specifically? Do you follow this instruction?
    https://docs.espressif.com/projects/esp-idf/en/latest/esp32/get-started/index.html#id2
    The editror is OK, I have made use of this instruction. I think the errors are with the PATH variable.
    I found a temporary workaround for the problem. When I type "idf.py menuconfig" in the "cmd" window I get errors as above, but when in the same window I issue the command
    path C:/Program Files/Java/jre1.8.0_241/bin/server;C:/Program Files/Java/jre1.8.0_241/bin;[tutaj reszta ścieżki];C:\esp32\esp-idf\tools;C:\esp32\esp-idf;C:\esp32\eclipse
    then the program compiles without errors. This solution only works until the computer is restarted and only in the directory with the specific project. Changing to another project (changing the directory) causes errors.
    Path after "path" copied vividly from the window "sysdm.cpl/Advanced/Environmental variables.../PATH".
    How to turn the "workaround" into a permanent solution?
    Greetings
    Kamil
    [Added]
    The problem was bad characters in the PATH variable, swapped slashes and backslashes. In the registry it looked like this: „C: /esp32/.espressif/tools / ...”, while it should look like this: „C: /esp32/.espressif/tools / ...” Manual replacement helped.
    Topic to be closed.
  • #5 18633148
  • #6 18633410
    kamilmm
    khoam wrote:
    kamilmm wrote:
    How to turn a "workaround" into a permanent solution?
    And it's not like you have to call export.bat with espesp-idf ?
    I ran first "install.bat" o later "export.bat". The problem was the wrong characters, confused / with (not sure if inserted wrong by the installer or by me).
    Greetings
    Kamil
