[Solved] esp32 oled arduino and windows xp library errors during compilation
tos18 2484 4
  • ESP32 Arduino toolchain installs on Windows XP
    #1 17174013
    tos18
    Help: 1113
    Rate: 1870
    Following the description from https://www.elektroda.pl/rtvforum/topic3361738.html
    -install the latest version of Arduino https://www.arduino.cc/ currently 1.8.3 - executed. I have 1.8.3 and 1.8.5 .
    -install python 2.7 https://www.python.org/ by selecting "Add python.exe to Path" during installation. - performed .
    -install Git client https://git-scm.com/downloads - not compatible with xp .
    -run Git GUI as administrator (right mouse button)
    -select "clone existing repository"
    -enter source: https://github.com/espressif/arduino-esp32.git
    I unzipped into the recommended directories. .
    -go into the created catalowgroups \hardware then \tools and run get.exe - executed. In order to observe possible errors run from the console not by clicking. .
    Microsoft Windows XP [Wersja 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    D:\Documents and Settings\tos>cd D:\Documents and Settings\tos\My Documents\Ardu
    ino\hardware\espressif\esp32\tools
    D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\tool
    s>get
    System: Windows, Info: Windows-XP-5.1.2600-SP3
    Platform: i686-mingw32
    Tool xtensa-esp32-elf-win32-1.22.0-80-g6c4433a-5.2.0.zip already downloaded
    Extracting xtensa-esp32-elf-win32-1.22.0-80-g6c4433a-5.2.0.zip
    Tool esptool-da31d9d-windows.zip already downloaded
    Extracting esptool-da31d9d-windows.zip
    Tool mkspiffs-0.2.2-arduino-esp32-win32.zip already downloaded
    Extracting mkspiffs-0.2.2-arduino-esp32-win32.zip
    Renaming mkspiffs-0.2.2-arduino-esp32-win32/ to mkspiffs
    Done
    s>
    watch the download process, unpack - does not throw any errors.
    at the end i have done.
    -Start the Arduino environment, select tools->plate and you should see the option to select ESP32 Dev Module, select the serial port that appeared in the system when the board was connected. - made .
    We can now start working with the ESP32!
    So I load any example.
    I compile ...and ...
    Arduino:1.8.5 (Windows XP), Płytka:"ESP32 Dev Module, Default, QIO, 80MHz, 4MB (32Mb), 921600, None"
    D:\ins\arduino-1.8.5\arduino-builder -dump-prefs -logger=machine -hardware D:\ins\arduino-1.8.5\hardware -hardware D:\Documents and Settings\tos\Local Settings\Application Data\Arduino15\packages -hardware D:\Documents and Settings\tos\My Documents\Arduino\hardware -tools D:\ins\arduino-1.8.5\tools-builder -tools D:\ins\arduino-1.8.5\hardware\tools\avr -tools D:\Documents and Settings\tos\Local Settings\Application Data\Arduino15\packages -built-in-libraries D:\ins\arduino-1.8.5\libraries -libraries D:\Documents and Settings\tos\My Documents\Arduino\libraries -fqbn=espressif:esp32:esp32:PartitionScheme=default,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10805 -build-path D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748 -warnings=default -build-cache D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_cache_993500 -prefs=build.warn_data_percentage=75 -verbose D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\examples\SerialToSerialBT\SerialToSerialBT.ino
    D:\ins\arduino-1.8.5\arduino-builder -compile -logger=machine -hardware D:\ins\arduino-1.8.5\hardware -hardware D:\Documents and Settings\tos\Local Settings\Application Data\Arduino15\packages -hardware D:\Documents and Settings\tos\My Documents\Arduino\hardware -tools D:\ins\arduino-1.8.5\tools-builder -tools D:\ins\arduino-1.8.5\hardware\tools\avr -tools D:\Documents and Settings\tos\Local Settings\Application Data\Arduino15\packages -built-in-libraries D:\ins\arduino-1.8.5\libraries -libraries D:\Documents and Settings\tos\My Documents\Arduino\libraries -fqbn=espressif:esp32:esp32:PartitionScheme=default,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -ide-version=10805 -build-path D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748 -warnings=default -build-cache D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_cache_993500 -prefs=build.warn_data_percentage=75 -verbose D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\examples\SerialToSerialBT\SerialToSerialBT.ino
    Using board 'esp32' from platform in folder: D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32
    Using core 'esp32' from platform in folder: D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32
    Detecting libraries used...
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti  -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32"  -DESP32 -DCORE_DEBUG_LEVEL=0 "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\variants\esp32" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp" -o "nul"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti  -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32"  -DESP32 -DCORE_DEBUG_LEVEL=0 "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\variants\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\src" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp" -o "nul"
    Using cached library dependencies for file: D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\src\BluetoothSerial.cpp
    Generating function prototypes...
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti  -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32"  -DESP32 -DCORE_DEBUG_LEVEL=0 "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\variants\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\src" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp" -o "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\preproc\ctags_target_for_gcc_minus_e.cpp"
    "D:\ins\arduino-1.8.5\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\preproc\ctags_target_for_gcc_minus_e.cpp"
    Kompilowanie szkicu...
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DHAVE_CONFIG_H "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/config" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bluedroid" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_trace" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/app_update" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bootloader_support" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/bt" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/driver" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/esp_adc_cal" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ethernet" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/fatfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/freertos" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/heap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/jsmn" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/log" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mdns" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/mbedtls_port" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nvs_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/openssl" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spi_flash" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/sdmmc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/spiffs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/tcpip_adapter" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/ulp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/vfs" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wear_levelling" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/xtensa-debug-module" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/coap" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/console" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/expat" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/json" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/lwip" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/newlib" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/nghttp" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/soc" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/include/wpa_supplicant" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib  -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10805 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32"  -DESP32 -DCORE_DEBUG_LEVEL=0 "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\cores\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\variants\esp32" "-ID:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial\src" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp" -o "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp.o"
    Compiling libraries...
    Compiling library "BluetoothSerial"
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\libraries\BluetoothSerial\BluetoothSerial.cpp.o
    Compiling core...
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-adc.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-bt.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-dac.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-gpio.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-i2c.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-ledc.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-matrix.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-misc.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-sigmadelta.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-spi.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-time.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-timer.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-touch.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-uart.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\stdlib_noniso.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\wiring_pulse.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\wiring_shift.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\libb64\cdecode.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\libb64\cencode.c.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Esp.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\HardwareSerial.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\IPAddress.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\IPv6Address.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\MD5Builder.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Print.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Stream.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\StreamString.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\WMath.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\WString.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\base64.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\cbuf.cpp.o
    Użycie wcześniej skompilowanego pliku: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\main.cpp.o
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-adc.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-bt.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-dac.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-gpio.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-i2c.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-ledc.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-matrix.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-misc.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-sigmadelta.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-spi.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-time.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-timer.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-touch.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\esp32-hal-uart.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\stdlib_noniso.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\wiring_pulse.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\wiring_shift.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\libb64\cdecode.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\libb64\cencode.c.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Esp.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\HardwareSerial.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\IPAddress.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\IPv6Address.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\MD5Builder.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Print.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\Stream.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\StreamString.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\WMath.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\WString.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\base64.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\cbuf.cpp.o"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-ar" cru  "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\core\main.cpp.o"
    Archiving built core (caching) in: D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_cache_993500\core\core_espressif_esp32_esp32_PartitionScheme_default,FlashMode_qio,FlashFreq_80,FlashSize_4M,UploadSpeed_921600,DebugLevel_none_f52f0b51e7bcfb104ad31d7115f833b9.a
    Linking everything together...
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc" -nostdlib "-LD:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/lib" "-LD:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/sdk/ld" -T esp32_out.ld -T esp32.common.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.spiram_incompatible_fns.ld -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority  -u __cxa_guard_dummy -u __cxx_fatal_exception  -Wl,--start-group "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\sketch\SerialToSerialBT.ino.cpp.o" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748\libraries\BluetoothSerial\BluetoothSerial.cpp.o" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/arduino.ar" -lgcc -lopenssl -lbtdm_app -lfatfs -lwps -lcoexist -lwear_levelling -lhal -lnewlib -ldriver -lbootloader_support -lpp -lmesh -lsmartconfig -ljsmn -lwpa -lethernet -lphy -lapp_trace -lconsole -lulp -lwpa_supplicant -lfreertos -lbt -lmicro-ecc -lcxx -lxtensa-debug-module -lmdns -lvfs -lsoc -lcore -lsdmmc -lcoap -ltcpip_adapter -lc_nano -lrtc -lspi_flash -lwpa2 -lesp32 -lapp_update -lnghttp -lspiffs -lespnow -lnvs_flash -lesp_adc_cal -llog -lexpat -lm -lc -lheap -lmbedtls -llwip -lnet80211 -lpthread -ljson  -lstdc++ -Wl,--end-group -Wl,-EL -o "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/SerialToSerialBT.ino.elf"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/gen_esp32part.exe" -q "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/partitions/default.csv" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/SerialToSerialBT.ino.partitions.bin"
    "D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32/tools/esptool" --chip esp32 elf2image --flash_mode "dio" --flash_freq "80m" --flash_size "4MB" -o "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/SerialToSerialBT.ino.bin" "D:\DOCUME~1\tos\LOCALS~1\Temp\arduino_build_288748/SerialToSerialBT.ino.elf"
    Traceback (most recent call last):
      File "esptool.py", line 34, in <module>
      File "c:\python27\Lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 389, in load_module
      File "site-packages\serial\__init__.py", line 27, in <module>
      File "site-packages\serial\serialwin32.py", line 15, in <module>
      File "site-packages\serial\win32.py", line 182, in <module>
      File "ctypes\__init__.py", line 375, in __getattr__
      File "ctypes\__init__.py", line 380, in __getitem__
    AttributeError: function 'CancelIoEx' not found
    Failed to execute script esptool
    Użycie biblioteki BluetoothSerial w wersji 1.0 z folderu: D:\Documents and Settings\tos\My Documents\Arduino\hardware\espressif\esp32\libraries\BluetoothSerial
    exit status -1
    Błąd kompilacji dla płytki ESP32 Dev Module.
    I don't know where I'm making a mistake.
    Switching the arduino to esp8266 means I can write programs, compile etc without any problems.
    Question - what am I doing wrong ???
    krzbor
    Help: 42
    Rate: 1072
    And have you read this and this and also this ?
    I, at one time, had problems with Arduino and XP - had to look for an old linker. As time goes on, there won't be much you can do on XP.
  • #3 17178867
    tos18
    Help: 1113
    Rate: 1870
    Thanks for the info.
    I've done some reading.
    I also tried the changes to the platform.txt file but it doesn't chatter
    I have never played with python.
    I tried calling esptool.exe in the console and got a set of errors
    so I tried calling python.exe esptool.py and got the following in reply
    importerror : no module named serial
    I have installed pyserial2.7
    Once again, I changed the entries in platform.txt
    [code]
    Code: Ini
    and I got errors like "cannot run py"
    So I changed the entries to :
    Code: Ini
    and the example compiled
    Unfortunately when I tried to upload it to the module I got
    Code: Ini
    and I'm stuck again
  • Arduino hardware folder must be under install path
    #4 17291989
    tos18
    Help: 1113
    Rate: 1870
    It runs compiles and uploads under archaic Windows XP
    here was the problem:
    tos18 wrote:
    -select the target as the path, which you will find in Arduino->File->Preferences->Sketch Location, at the end of the path add hardware, then click Clone - I downloaded the repository as a zip. I unzipped into the recommended directories.
    The files should be unzipped not where the path points to, but where the arduino is installed (in my case, D:/ins/arduino1.8.5/ ) in the directory with the arduino we have a Hardware directory and the files from the repository should be uploaded there.
    I suspect the problem is spaces in the windows directory names, so as a precaution I suggest not packing the arduino into program files.
  • #5 17314106
    tos18
    Help: 1113
    Rate: 1870
    as post above
