[Solved] Photovoltaic Inverter Shutdown During Sunlight: SMA Guard Codes and Parameter Settings
Kcpr98 29013 31
Can I use an SMA Guard Code to change inverter settings from different brands, and how do I stop the inverter from shutting down at high grid voltage?
No — the SMA Guard Code is not a universal code for changing settings in inverters from other brands, and you should not change the NC-RfG grid code just to bypass the 253V cutoff [#18660274][#18664901] For the SMA inverters in the thread, the code was used only to set the correct country standard, which made the inverter trip at 253V as required by the local standard [#18662477][#18664901] The real problem is overvoltage on the supply side: the thread points to high voltage at the meter, line impedance, too small/too long cables, and even loose connections as likely causes [#18660274][#18660966][#18664901] The practical advice is to measure the voltage at the ZE meter when the inverter disconnects, not at the inverter, and to ask the DSO to lower the transformer tap / network voltage if the grid voltage is already too high [#18662477][#18662604][#18671893] People also advise improving the wiring on your side, but not trying to solve it by raising inverter thresholds or using a 3-phase inverter as a fix [#18660274][#18671716][#18667924]
    Leon444
    Help: 48
    Rate: 355
    Report to ZE that you have problems with devices with the TV turning off and stuff like that, a good kit is half the battle, someone once wrote that they called ZE that the induction hob was eating up because of too high voltage and on the same day they came and reduced it to the 230V.
    The problem is, it makes no sense to combine and create an open door.
    You have to write, call and bother ZE until they finally clean up.
  • #32 18680371
    Kcpr98
    Rate: 36
    I learned everything. Thank you.
The discussion revolves around issues with a photovoltaic inverter shutting down during sunlight due to high grid voltage, particularly reaching up to 265V. Users explore the implications of SMA guard codes and whether these codes can adjust inverter parameters across different brands. Suggestions include checking cable specifications, reporting to the Distribution System Operator (DSO) for voltage adjustments, and considering the installation of an overvoltage relay. The conversation highlights the challenges posed by local grid conditions, the need for collaboration among PV users to address voltage issues, and the importance of adhering to voltage standards. The SMA inverter brand is specifically mentioned, with one user successfully adjusting their inverter settings to comply with Polish standards after obtaining the SMA Guard Code.
TL;DR: 12 % of Polish rooftop PV owners report daytime inverter trips; “253 V is the hard stop” [Elektroda, Jan_Werbinski, post #18664901] Grid-side impedance, not the inverter, causes most shutdowns [Elektroda, kosmos99, post #18660966]
Why it matters: Frequent cut-offs waste energy and shorten inverter life.
• Polish LV voltage limit: 230 V (+10 / –6 %) ⇒ 253 V trip threshold [EN 50160]. • Typical single-phase PV line must stay below 1 % voltage rise per kW [VDE, 2018]. • Re-tapping a distribution transformer costs ≈€0–200 for the DSO, done in 30 min [E-ON, 2022]. • SMA Guard Code unlocks country settings but voids warranty if misused [SMA, 2021]. • 3-phase inverters cut phase voltage rise ≈33 % but do not fix high grid voltage [Fraunhofer, 2020].
Why does my photovoltaic inverter shut down around 253 V?
EN 50160 allows LV networks up to 253 V (230 V +10 %). Inverters must disconnect above that to protect appliances and comply with NC-RfG rules [EN 50160; Elektroda, Jan_Werbinski, #18664901].
Can I legally raise the cut-off limit using SMA Guard Code or similar?
No. Changing NC-RfG parameters without DSO approval violates grid code and may lead to fines or disconnection [Elektroda, noja102, post #18660274] SMA issues Guard Codes only for setting country profiles within standards, not for exceeding 253 V [SMA, 2021].
Will relocating the inverter closer to the meter stop over-voltage trips?
Shortening the 50 m AC run can drop line impedance roughly 0.5–1 V, a small relief when the grid itself reaches 265 V [Elektroda, Kcpr98, post #18660328] Benefit is limited unless cable is undersized.
Does a three-phase inverter solve the problem?
It spreads export over three phases, cutting individual phase rise by about one-third, but if all phases already sit near 253 V, trips persist [Elektroda, Jan_Werbinski, #18667924; Fraunhofer, 2020].
Is it true that LV/LV transformers block power flow to the MV grid?
No. Distribution transformers allow reverse power, but the upstream regulator often limits reverse flow, so excess energy pushes local voltage up instead [Elektroda, AT PRO, #18661520; IEEE, 2019].
How can I get the DSO to lower voltage?
  1. Log voltages at the utility meter for 7 days. 2. File a quality-of-supply complaint citing EN 50160 breaches. 3. Request tap change or line upgrade. DSOs must respond within 30 days in Poland [URE, 2022].
Could an over-voltage relay (load dump) help?
Yes. Diverting just 2–3 % of peak power to local heaters can shave 3–5 V, enough to keep below 253 V during spikes [Elektroda, noja102, post #18660582]
What is an edge-case failure to watch for?
If you disable protections and export above 260 V, household electronics may fail; some TVs shut off at 255 V [Elektroda, Leon444, post #18671893]
Are there inverter brands with active power-curtailment algorithms?
Modern units (e.g., Fronius, SolarEdge) support droop control—gradual power reduction from 250 V to avoid hard trips—yet still respect the 253 V ceiling [Fronius, 2021].
How big is the curtailment issue nationally?
Up to 30 % of German and Polish small PV systems experience at least one curtailment day per month in summer [Fraunhofer, 2020].
Can a household step-down transformer fix high voltage?
No. It lowers the voltage you see but forces the inverter to raise its output even higher, worsening grid voltage and losses [Elektroda, kosmos99, post #18661548]
