Compatible Light Sensor for Rojal S-Timer Roller Shutter Controller?
lopiola 960 3
  • #1 18750865
    lopiola
    Help: 8
    Rate: 57
    What light sensor is used on the Rojal S-Timer roller shutter controller?
    This sensor allows the roller shutter to close partially as the sun shines strongly.
  • #2 18756164
    dasej
    Level 32  
    Help: 165
    Rate: 266
    Welcome.
    Link A little expensive.
  • #4 18756656
    dasej
    Level 32  
    Help: 165
    Rate: 266
    As you can see from the photo, the plug has 4 contacts.
    It can successfully be
    VCC, GND, TX, RX.
    It is difficult to tell from the photo. Disassemble the controller then you will know how the communication is.
