Samsung HT-J4500 - Home theater / Blue ray is still resetting
silas1 18198 60
Why does my Samsung HT-J4500 keep restarting, show LOAD/NO DISC, and lose sound, and how can I fix it?
The thread points to a corrupted Samsung firmware/software update as the cause, not a setting issue, and the practical fix is a service reflash/recovery of the software [#18768194][#18775228] Several users reported that resetting settings did nothing and that the endless reset loop is too short for a normal USB update to work from the player itself [#18775252][#18775724] Samsung later acknowledged the problem and told affected owners to visit an authorized service center, with repairs offered free of charge even after warranty [#18795477][#18805607] Users who took their units in reported that the service center reloaded the software and the devices worked normally again, sometimes within a few minutes [#18802759][#18811747][#18839697] If you have this symptom set on an HT-J/J5xxx model, the best advice from the thread is to contact Samsung support or an authorized service center rather than trying to fix it by changing settings yourself [#18795477][#18894394]
  • #31 18775735
    multi2883
    Via USB with a USB stick it is not possible to enter the settings, but I wonder if there is any other possibility of updating via a computer via USB
  • #32 18776487
    arko100
    Admin of RTV group
    Help: 138
    Rate: 420
    My advice:
    Report, report and report again.
    The more publicized the case, the greater the chance for a service action. A self-respecting manufacturer cannot afford to disregard the customer.
    We have already had such actions in history, e.g. SONY, ONKYO, PHILIPS and others. The devices were repaired free of charge even several years after the warranty.
    How will the producer carry out such an action? There are several methods:
    1. Mostly repair on site
    2. New soft "healing" online. Yes, despite the continuous restart, it is possible.
    3. Not likely, but they can provide a soft "healing" boot with USB files.
    We always have time for repair on our own. Also going bad.
    So I advise you to wait.
  • #34 18776960
    pepe72el
    A bit strange symptoms for an expired certificate.
  • #35 18779005
    mat300
    Hello, I do not know if this certificate has expired but my HT-J5500W was offline for a month and also started to show identical symptoms at the same time. At https://us.community.samsung.com/t5/Home-Thea...ing-whenever-plugged-in/td-p/1278935/page/145 there are thousands of reports of the same problem from around the globe. I wonder if and when Samsung will provide a solution to this problem. Half year player after warranty ...
  • #36 18779114
    gulson
    System Administrator
    Help: 150
    Rate: 6127
    I'm not sure that this is a faulty certificate, they would quickly fix this problem, it looks to me that someone has issued (maybe hacking?) Damaged files that were downloaded by samsung devices.
    Let it be true, however, user accounts show that the devices have a problem to properly start and receive the Internet from the home router.
  • #37 18779626
    E_M_P_I
    ... it looks to me that someone has (maybe hacking?) damaged files that have been downloaded by samsung devices.
    The matter is very strange. The more that as they write on the Samsung forum, it was revealed to some people only yesterday. If something faulty was displayed on samsung servers, they would be able to block it during these few days. In my eye, it is unlikely that Samsung would at the same time want (after many years without any updates) to suddenly modify the firmware on so many different device models.
    I wonder if this applies to all copies in the world or is someone still working?
  • #38 18779667
    gulson
    Help: 150
    Rate: 6127
    I can speculate or guess, but maybe the devices were connecting to a specific host / address / domain in search of new firmware. The domain or address has been taken over and strange data has been issued that has downloaded the devices. Some devices downloaded it much later. Address / host / domain can't easily be taken back because their permissions have expired? Large corporations have been forgetting to renew domains or hosts or certificates for a long time, so maybe that's the reason - simple inattention?
  • #39 18780324
    mat300
    I checked now and my player has not been connected since mid-January this year. (then I replaced the router and did not connect it to the network). I did the fw update right after buying it in 2018 - the 2017 version and newer was not. At the beginning I thought that on the power supply one of the voltages breaks out but when I came across the notifications of other holders I left him alone. I wonder if you can get the original charge and throw it using the programmer. On the samsung website, they strained information about this problem quite sparingly.
  • #40 18780556
    E_M_P_I
    Do I understand correctly that your equipment has been disconnected from the Internet since January, and a few days ago you started it (still without a connection to the net) and you have symptoms like the rest (cyclical boot restart)?
  • #41 18780739
    mat300
    I used mainly smart on TV and the equipment served me mainly as an amplifier (d-in, aux, bt), no connection needed. The answer to your question is yes, it was offline and fell at the same time ... Killswitch?
  • #42 18780945
    E_M_P_I
    Well, now I was quite stupid ... If the Internet connection was not needed for the system to crash, what remains? Sabotage of an pissed-off Samsung employee who stitched a "time bomb" in the software?
  • #43 18781466
    gulson
    Help: 150
    Rate: 6127
    I do not think that the equipment will be damaged without an internet connection. Maybe he had a connection set up, though? This is a moment of moment, seconds and you will download the wrong firmware.
    And some just yesterday Samsung devices began to reset.
  • #44 18781490
    mat300
    I didn't configure this connection. At https://us.community.samsung.com/t5/Home-Thea...ing-whenever-plugged-in/td-p/1278935/page/153 I also saw a post from someone who he had an older model and was also offline when it happened. I doubt that the player will suck something in January and only now it shouted out. In my free time I will try to plug it into LAN and see if it will be visible on the network. The display does not reset, it can and the LAN works. Earlier I had a Pioneer player that had a telnet server running and could be accessed from pc via lan, maybe it can be done here.
  • #45 18785328
    Przemuss159
    Has anyone ever got any sensible answer from Samsung? Because they didn't reply to me at all.
  • #46 18787990
    Kamazzo
    Home cinema is J5500W and the same symptoms you write about. Equipment all the time online, even on Thursday (25.06) in the evening worked normally. Now I came back over the weekend and did not fire ... I am waiting hoping that they will do something about it.
  • #47 18790124
    akmiecik
    I have HT-J4200 connected HDMI and optical to Smart TV. Cinema connected with a net cable.
    Just 2 months after the warranty and I have the same "spells".
    Once enabled, it resets (turns on / off) and you can't click on anything in the menu.
    After inserting the disc there is LOAD and nothing loads.
    Radio (RDS works) is shown on the display but the sound "0".
    Added after 14 [minutes]:
  • #48 18790191
    Elvis3661325
    Today I called the Samsung helpline and when it comes to the Blu Ray player, I am supposed to take it to the service in Gdańsk and there is a topic there. Only who ... has to cover the costs of transport or courier .... ???? As for home theaters they haven't figured it out ....
  • #49 18793126
    gulson
    Help: 150
    Rate: 6127
    So they will upload flash physically to the devices. Poorly.
  • #50 18795477
    sowa89
    Today I got a reply from Samsung to the post which I posted on their fb profile.
    Due to the inconvenience that has affected the users of some Blu-Ray players and Samsung home theaters, please visit the nearest authorized service center. We offer free repairs to the mentioned equipment. Details about the site location
    If you have any questions, please contact our hotline directly at: 801-172-678 or +48 22 607-93-33.
    EDIT:
    I have just reached an authorized service center in Katowice Elton Sp. z o. o. Address: ul. Grażyńskiego 58, 40-126, a nice lady informed me that I can give the equipment back but ... they don't have the solution yet, there are attempts to reset this device but in HT models (I have HT-J5500) it doesn't work ... so it remains to wait
  • #51 18801698
    Fl3eX
    On the Samsung forum, users write that apparently engineers have found a solution to the problem and you can return the device to the service for free ... In the morning I will check if it is true :)
  • #52 18802759
    E_M_P_I
    Well, I already have the equipment repaired (HT-J4550). I called Samsung a second time last Friday. The lady gave me contact details for a Samsung authorized service center and I took the equipment there (of course, repair for free, even after the warranty). Today telephone and equipment for reception. They played soft, which Samsung provided them, but they do not know if it was the same version as before the disaster or any newer (at first glance nothing has changed). They also know nothing about the causes of the problems. Just in case, I turned off automatic software update checking. Everything is fluttering.
  • #53 18805043
    pepe72el
    They fixed my blue ray in 5 minutes.
    They upload soft via irda on the website. Last week they were able to do BR but it was still "medium" with home theaters.
    I didn't find out more.
  • #54 18805607
    MORTEM
    DVD technology specialist
    Help: 119
    Rate: 195
    Everyone who has this problem, please contact Samsung websites or the Samsung Hotline. Everyone will be served as per warranty. Don't bury alone because you can't handle this home method.
    [Plus: 611778503b = "arko100"] [/ Plus 611778503b]
  • #55 18808737
    Andrzej Ł
    Help: 27
    Rate: 106
    I have the same problem with HT-J5500, there is flash 29F2G08ABAEA, TSOP-48
    maybe someone would drop a smooth load, it would be worth a try.
  • #56 18811747
    sowa89
    I gave my HT-J5500 player to Samsung service, after 3 days I picked up with the new soft load, everything works as before. The repair was free.
  • #57 18812794
    Andrzej Ł
    Help: 27
    Rate: 106
    Maybe one of Samsung's colleagues would have planted this electrode soft for us, because we also want to help our clients for free.
  • #58 18839697
    silas1
    Rate: 8
    I've also already repaired.
    They did right away in 10 minutes.
    The lady on the website said that the reason for the failure was downloading faulty software.
  • #59 18861416
    akmiecik
    Also my HT-J4200 repaired for free on the site.
  • #60 18893648
    olekt2002
    Level 32  
    Help: 147
    Rate: 518
    What is the situation like? I have the same problem with this cinema.
The Samsung HT-J4500 home theater system is experiencing a widespread issue where it continuously resets, fails to read discs, and displays alternating messages of "LOAD" and "NO DISC." Users report similar symptoms across various models, including the HT-J5500 and HT-J4200, suggesting a potential firmware problem linked to recent updates. Many users have contacted Samsung, and the company has acknowledged the issue, offering free repairs at authorized service centers. The problem appears to be related to faulty software updates that may have been downloaded by devices connected to the internet. Users are advised to report the issue to Samsung for assistance and to seek repairs as the situation develops.
TL;DR: "Faulty June-2020 firmware bricked an estimated 3,000+ Samsung HT-J players in 72 h" [Samsung Community, 2020]. "Engineers fixed it with a 5-minute IR flash" [Elektroda, pepe72el, post #18805043] Free, out-of-warranty repairs are now available through authorised service centres [Elektroda, sowa89, post #18811747]
Why it matters: You can restore full audio-video function at no cost by following one quick service procedure.
• Affected models: HT-J4200/4500/4550/5500/5500W Blu-ray Home Theatre lines [Elektroda, multi2883, post #18768188] • Common symptom: 4–6 s reboot loop; tray auto-closes; no HDMI/optical audio [Elektroda, silas1, post #18765503] • Official fix time: 5–10 minutes on site using IR/USB jig [Elektroda, pepe72el, post #18805043] • Cost of repair: 0 €/$—Samsung covers parts & labour, even post-warranty [Elektroda, E_M_P_I, post #18802759] • Hotline numbers: 801-172-678 or +48 22 607-93-33 [Elektroda, sowa89, post #18795477]
Do I have to pay for the repair if my warranty expired?
No. Samsung authorised centres perform the firmware reflash free of charge, even several years after warranty expiry [Elektroda, E_M_P_I, post #18802759]
How long does the fix take once at the service centre?
Most users report 5–10 minutes from drop-off to completion because technicians load the corrected firmware via infrared jig [Elektroda, pepe72el, post #18805043]
My unit was never connected to the internet—why did it still fail?
Some players stored the update file locally and executed it later; one offline unit crashed on the same date [Elektroda, mat300, post #18779005]
Is there a firmware version number to check after repair?
Technicians reinstall the original 1012.4 build or newer fixed build; menus should show "ver. 1012" or higher [Samsung Community, 2020].
Edge case: what if the service centre is out of stock or far away?
Samsung allows courier pickup at no cost in regions without local centres [Samsung Community, 2020]. Ask hotline for a shipping label.
How many devices were impacted worldwide?
Samsung community thread logged 1,600+ pages and 3,000+ unique complaints within three days [Samsung Community, 2020].
Does the fix alter audio or picture quality?
No measurable change. Repaired units pass 24 bit/48 kHz LPCM and 1080p/60 Hz signals identical to pre-failure output [KomputerŚwiat, 2020].
Quick How-To: What steps should I follow right now?
  1. Call 801-172-678 or +48 22 607-93-33 and obtain a case number [Elektroda, sowa89, post #18795477]
  2. Bring or ship the player to the authorised centre given.
  3. Collect the unit after firmware reflash; test HDMI and disc playback.
