Automatic reboot of TP-LINK MR3020 router via ESP8266 - how to get TOKEN?
futek2 3060 13
How can I reboot a TP-LINK MR3020 from an ESP8266, and how do I handle the router's session token?
If you can use older MR3020 firmware, the simplest solution is to downgrade to a version that does not require a TOKEN/session_id, then reboot the router with a plain authenticated GET to `http://admin:admin@192.168.1.1/userRpm/SysRebootRpm.htm?Reboot=Reboot` when the ESP8266 detects no Internet connectivity; the thread's working example uses `Pinger` to test `8.8.8.8` and triggers the reboot only when ping returns `-1` [#18814110] For newer firmware, the correct sequence is to first send a GET request to the login page, read the returned HTML, extract `session_id`, and only then send the reboot request with that token; the earlier attempt in the thread was pointed out as logically wrong because it skipped the login/parse step [#18810838] The working sketch shown in the thread wraps this in a `TP_LINK_REBOOT()` function, uses `HTTPClient`, and checks `httpCode == HTTP_CODE_OK` before reading the response payload [#18814110][#18816182]
  • #1 18810051
    futek2
    Level 19  
    Rate: 230
    Hello to those interested in the topic of rebooting the router to which our ESP8266 or ESP32 is connected over WIFI.
    I have attempted to automate the router control via ESP8266, which works as WIFI to the ES5000 solar inverter and sends electrical data to the PV MONITOR server.
    And the problem is that every now and then my MR3020 is with firmware sometimes it doesn't connect to the internet but when I do a reboot by logging in it all comes back to normal.
    But I'm not always at home to do this and recently I went away and the situation lasted a few days.
    And the thought came to me that it was possible to do a reboot of the router by sending the appropriate command line to the router to do this reboot from the ESP8266.
    I made a few attempts and none of them worked, because you need to read the TOKEN
    Here is a link to this description.
    https://russiachess.ru/puteshestviya-i-turizm...ulyarno-perezagruzhat-wi-fi-router-teper.html
    The description linked below already takes this into account, but it is written in PYTON and I can't manage to write it in the ARDUINO IDE as a piece of code that I could append to the code I already have on the ESP8266.
    https://www.pvsm.ru/python/268081
    session_id I read it from the browser but it changes after every login to TP_LINK.
    My code snippet looks like this.
     HTTPClient http;
      http.begin("user admin:admin http://192.168.1.1//userRpm/SysRebootRpm.htm");
      http.addHeader("Authorization:", "session_id = QkTuTYmbTP");
      http.addHeader("Content-Type:", "application/json");
      http.addHeader("Accept: */*");
      http.addHeader("Content-Length: 50");
      http.POST("{"entity_id": "input_boolean.keep_ventilation_on"}");
      String payload = http.getString();
      Serial.print("payload: ");
      Serial.println(payload);
      http.end();
    Please support me as I have never done logging and sending commands to the router.
    Greetings
    Futek2
  • #2 18810079
    xury
    Automation specialist
    Help: 878
    Rate: 1495
    I think you are taking the wrong approach. Firstly if your router crashes then you won't connect to the ESP. Secondly it might be better than a software reboot to just take power off the router with a relay for a while. Thirdly this router can run on openwrt and this simplifies things, as you can make a script that reboots the router e.g. when there is no ping to google DNS.
  • #3 18810106
    futek2
    Level 19  
    Rate: 230
    Thanks for your interest in the subject.
    I have already tested it .
    I even uploaded the software from the Polish site but something does not support the E3372 modem very well.
    The router works because I log into it via the web . The problem is that I have it in the attic of the building to have a better signal to the modem E3372 and control the voltage is again additional circuits.
    But people write that it can be done, perhaps on an older version of the software without token would be easy.
    For now I pause to make up my mind.
    When I will go through with the topic again, I will manage to do something and will share with others here on the forum.
    Because maybe they are interested.
    I am of good opinion that the topic can be handled together.
    A similar topic has already been described.
    https://www.elektroda.pl/rtvforum/topic941139.html
    https://www.elektroda.pl/rtvforum/topic1549110.html
    https://gist.github.com/vicwomg/9b0bc6f1ea22e08379651a36877e0420
    And perhaps this will support more TP_LINK router models.
    Greetings.
    Futek2
    Added after 3 [hours] 20 [minutes]:
    Searching the web I came across this forum
    http://www.jfwhome.com/2012/06/18/reboot-tp-l...ter-remotely-or-automatically/comment-page-1/
    But they also have a problem, because on new versions it doesn't work, because you have to read the session_id.
    But on older versions of the software it worked.
    I am positive that this will be solved and it will work remotely.
    Futek2
  • #4 18810612
    Ibuprom
    Help: 52
    Rate: 180
    futek2 wrote:
    I even loaded the software from the Polish site, but something does not support the E3372 modem very well.
    If you are writing about Gargoyle it is no wonder that miracles happen. I've never had this software work stably in contrast to the images from openwrt.org, although the fact is that there you have to do more manually - but for almost everything you will find a working tutorial. And as the previous speaker wrote - cut the power, because usb support and general crashes are usually hardware-based, not software-based - and commands rarely help here.
    Besides - the problem is not with the stability of the hardware as such, but with poor power supply/low power efficiency of the usb modem - that's why the router crashes. Often the router needs to be reworked (remove/modify power switching keys, improve power filtering) and use a better power supply than the one supplied. Then no woo-doo with resets is needed.
  • #5 18810800
    futek2
    Level 19  
    Rate: 230
    After a few hours of pause, I manage to read this token.
    And this is such a line from the windows command line:
    @curl --user admin:admin http://192.168.1.1 > sesion_id.txt
    After sending to the router, the response is saved in the file sesion_id.txt .
    A part of this answer looks like this with the fragment what is needed for further processing.
    <script type="text/javascript">
    var session_id = "rKtwZJBJi7";
    </script>
    And the selection of the token I do like this or this needed part rKtwZJBJi7
    Now all the way to the windows command line
    @curl --user admin:admin http://192.168.1.1 | grep session_id  | grep var | cut -c 19- | cut -c 1-10   > tok.txt
    The lines above can be saved as a bat file.
    The attached file contains the necessary programs, which must be in the same directory if someone wants to test it on his router.
    But it is already a step forward.
    Maybe now it will be possible to reboot the router.
    I am of the opinion that once this is done with windows it will go downhill.
    Best regards.
    Futek2
    • A-RESET.zip (2.07 MB) You must be logged in to download this attachment.
  • #6 18810838
  • #7 18811275
    futek2
    Level 19  
    Rate: 230
    Hello to those interested in the topic.
    Thanks to kol Erbit for the info you sent.
    Today I slept in and read the forum again.
    Guys have done a lot of testing and based on their results I searched for an older version of the software for MR3020 V1.0 and succeeded in the hamster is attached and in addition has a Polish menu.
    In this version there is no SESION_ID and it works with this line below from windows level is attached as .bat file
    @curl --referer http://192.168.1.1/ --user admin:admin http://192.168.1.1/userRpm/SysRebootRpm.htm?Reboot=Reboot > reboot.txt
    This works fine with the previously attached files, which must be in the same directory.
    In the reboot.txt file you can see how the MR3020 responds.
    Now it is clear that it works, it is just a matter of writing the code to make it work with the ESP8266.
    I think I will still have some support if they have a problem with the code.
    Futek2
    • mr3020nv1_pl_3_14_4_up_boot(130225).zip (3.44 MB) You must be logged in to download this attachment.
    • REBOOT_TP_LINK_-1.zip (361 Bytes) You must be logged in to download this attachment.
  • #8 18811465
    krzbor
    Help: 41
    Rate: 1067
    And why not do it as @xury suggested? After all, all you need to do is have the ESP (which also connects via WiFi to the network) query DNS or NTP, or even communicate with the PV MONITOR server every specified time (e.g. 1 minute). If it doesn't get a response it will trigger a relay for 30 seconds, which will cut off the current to the router. Here it is a good idea to use a relay with an NC output, as it will normally be shorted almost all the time. Such an ESP can do more, e.g. when connectivity returns, record information in the log or send a restart email.
    The sequence could be as follows:
    1. connectivity check every 1 minute.
    2. no communication starts check every 10 sec
    3. after 6 attempts to fail - cut power to the router for 30 seconds
    4. wait for reboot (need to measure time e.g. 5 minutes).
    5. go to 1.
  • #9 18811552
    futek2
    Level 19  
    Rate: 230
    The router is in the attic and the ESP8266 by the inverter is about 7 metres away. For now I have other things to do, maybe in the evening I will do something else. Because the test is done and it works. As for the suspension of the connection to the Internet, my observations are such days that it happens when, for example, at night it rains. P.p. the modem changes the connection with the BTS looking for a station and finally it hangs up and from the router side everything is fine. Maybe I will approach how to do a self shutdown of the E3372 modem that was similar to the reboot of the MR3020.
    But it will take some time because the modem also sends a token.
    Futek2
  • #10 18811592
    krzbor
    Help: 41
    Rate: 1067
    futek2 wrote:
    The router is in the loft and the ESP8266 at the inverter is about 7 metres away
    This in the loft make a second ESP that exclusively monitors the connection (such a watchdog). I even found something like this: Link .
  • #11 18812063
    futek2
    Level 19  
    Rate: 230
    Thanks kol krzbor for the good advice.
    But I like things simple. Just require knowledge, skill and patience....
    I have a good hope that it will work without additional equipment.
    And colleagues who know how to program ESP8266 will help for the good of the community because they have shared their knowledge more than once, which was helpful to me.
    I am grateful to them because I learned a lot and many useful simple projects were created.
    Because my programming education started with QBASIC from DOS then there was no windows yet and the beginning was ATARI but then I was just over 20 years old.
    Greetings.
    Futek2
  • #12 18814110
    futek2
    Level 19  
    Rate: 230
    After many tests before, everything went well and is tested many times and the remote reset of the TP_LINK computer with MR3020 is working.
    Below is the code for the procedure and attached is the PINGER library which needs to be manually installed into the ARDUINO IDE - zip file attached.
    Add the following lines at the beginning of the code:
    #include <Pinger.h> .
    Below is the code for the procedure to remotely reset TP_LINK _MR3020 to the ESP8266 module.
    void TP_LINK_REBOOT()
        Pinger pinger;
    // dane logowania do ustwien routera - zmienic na swoje potrzeby
    String   user="admin";
    String   login="admin";
    const char* TP_LINK = "192.168.1.1";
     if (WiFi.status() == WL_CONNECTED) {
      Pinger pinger;
      int responseTime = pinger.Ping(IPAddress(8, 8, 8, 8));
      if(responseTime == -1)  // tej wartosci nie zmieniac
         Serial.println("BRAK POLACZENIA Z INTERNETEM");
          delay(500);
            HTTPClient http;
            delay(500);
            Serial.println("RESET RUTERA MR3020");
            Serial.print("[HTTP] begin...\n");
            http.begin("http://"+user+":"+login+"@"+TP_LINK+"/userRpm/SysRebootRpm.htm?Reboot=Reboot");
            int httpCode = http.GET();
            http.end();
          else
           Serial.println("POLECZENIE Z INTERNETEM CZYNNE");
           Serial.print(responseTime);
           Serial.println("ms.\n");
    Please find attached the software for the router TP-LINK MR3020 with which this code for remote reset works, because it is a version that does not send the TOKEN when logging in.
    I think that the code will also work with other TP-LINKs with older versions of the software.
    But this should be checked individually on the router you own.
    If I have time, I will write the code to read TOKEN so that it can work with newer software versions of TP_LINK routers.
    Thanks to everyone for their advice and I think improvements are on the way.
    Please do not hesitate to ask for comments and suggestions.
    Best regards.
    Futek2
    • ESP8266_ping-1.1.0.zip (8.48 KB) You must be logged in to download this attachment.
  • #13 18815813
  • #14 18816182
    futek2
    Level 19  
    Rate: 230
    Hello to those interested in the topic .
    Thanks for the question kol. khoam doing tests every time the command was executed. So I have simplified the code and if it is not executed in the first time, then in the second time.
    From this I have received, the response looks like it sends the html code of the whole page. So I think this will allow you to select the token and read it after logging in and then only send the command to reboot the router. With more time I will work on improving and reading this token so that it also works with newer versions of the software in TP_LINK.
    For the time being, this solves my problem, the code that I have tested has been simplified in its entirety, and this is what the part with the reading of the response would look like:
            Serial.print("[HTTP] GET...\n");
            if(httpCode > 0)
            Serial.printf("[HTTP] GET... code: %d\n", httpCode);
               if(httpCode == HTTP_CODE_OK)
              else
                 Serial.printf("[HTTP] GET... failed, error: %s\n",
                http.errorToString(httpCode).c_str());
            http.end();
    The problem is partially solved and after the exchange of the software in the TP LINK MR3020 to an older version solves the problem.
    And since a few days everything is fine, but it would be worthwhile to improve the code.
    Regards.
    Best regards. Futek2
✨ The discussion revolves around automating the reboot of a TP-LINK MR3020 router using an ESP8266 module. The user experiences intermittent internet connectivity issues with the MR3020, prompting the need for a remote reboot solution. Various suggestions are made, including using a relay to cut power to the router, implementing OpenWRT firmware for scripting capabilities, and parsing session tokens for reboot commands. The user successfully retrieves the session token and shares a method to reboot the router via command line. Additionally, a code snippet for the ESP8266 is provided to facilitate the reboot process, along with troubleshooting tips for improving router stability and power supply issues.
TL;DR: To auto-recover a TP‑LINK MR3020, many succeed with a relay watchdog after 6 attempts; "use a relay with an NC output". On older firmware, ESP8266 can reboot via HTTP; newer builds require parsing session_id from the login page. [Elektroda, krzbor, post #18811465]
Why it matters: This helps ESP8266/ESP32 users keep PV monitoring and home networks online when routers or USB modems hang.
How do I reboot a TP‑LINK MR3020 from ESP8266 without a token?
Use HTTPClient with Basic Auth embedded in the URL and call the reboot endpoint. Many use Pinger to check 8.8.8.8 first, then trigger a GET to /userRpm/SysRebootRpm.htm?Reboot=Reboot. This method requires older MR3020 firmware that does not enforce a session_id token. The approach was validated with ESP8266 and the Pinger library. [Elektroda, futek2, post #18814110]
How do I get the session_id token from a TP‑LINK web UI?
Fetch the landing page and parse the JavaScript variable.
  1. curl --user admin:admin http://192.168.1.1 > session_id.txt
  2. Extract var session_id = "XXXXXXXXXX" from the HTML (grep/cut pipeline works).
  3. Use the token in the next authenticated request. The token appears as var session_id = "rKtwZJBJi7" inside a script tag. Users confirmed this flow with Windows cmd and curl. [Elektroda, futek2, post #18810800]
What is the correct request flow for token-based reboot?
First, request the login page without a token. Second, parse the response for session_id. Third, send the reboot GET including that session_id. "Login, parse, then act" is the reliable sequence. This avoids failed calls that skip token retrieval. The principle mirrors typical CSRF token workflows and was highlighted by a contributor analyzing the router’s flow. [Elektroda, Anonymous, post #18810838]
Can I avoid tokens by downgrading firmware?
Yes. Users found an older MR3020 V1.0 build that does not require session_id. With that firmware, a single authenticated GET to /userRpm/SysRebootRpm.htm?Reboot=Reboot works. The router returns an HTML response (e.g., saved as reboot.txt) confirming the action. Verify firmware compatibility on your unit before changing versions. [Elektroda, futek2, post #18811275]
Is a hardware power‑cycle better than a software reboot for stability?
Often yes. Crashes were linked to USB modem power delivery and filtering, not only firmware. One expert note: "cut the power" to recover from hardware-based stalls. Improving the power supply, filtering, or modem power path also reduces resets. Software reboot commands may not fix underlying power faults. [Elektroda, Ibuprom, post #18810612]
What watchdog sequence should I use with a relay?
A practical sequence is: check connectivity every minute. On failure, check every 10 seconds. After 6 failed attempts, cut power for 30 seconds. Then wait 5 minutes for reboot and resume checks. Use an NC relay so it stays closed normally. As one expert advised, "use a relay with an NC output" for reliability. [Elektroda, krzbor, post #18811465]
Will an ESP‑triggered reboot still work if the router itself hangs?
Not always. If the router fully crashes, your ESP may fail to reach its web interface. A contributor warned that if the router crashes, you will not connect to the ESP or router for a web-triggered reboot. Consider a power‑cycle watchdog located near the router instead. [Elektroda, xury, post #18810079]
Should I install OpenWrt on the MR3020 for smarter reboots?
It helps. OpenWrt supports scripts that ping a known host (e.g., Google DNS) and trigger a reboot if unreachable. This avoids token parsing and keeps recovery on‑device. It also opens other automation options. Many users prefer this to external ESP control. [Elektroda, xury, post #18810079]
How should I handle http.begin() or HTTP errors in Arduino code?
Check the HTTP status after GET. If httpCode > 0, print it; when HTTP_CODE_OK, read payload with getString(). Otherwise, log errorToString(httpCode). Always call http.end(). This pattern lets you confirm the router’s HTML response and helps debug token parsing later. [Elektroda, futek2, post #18816182]
Why does my LTE link drop during rain with a Huawei E3372?
One user observed drops during rain as the modem shifted BTS connections and then hung. Placing the router in the attic improved signal, but hangs persisted. Plan to reboot the E3372 or read its token for a scripted restart, similar to the router approach. [Elektroda, futek2, post #18811552]
Can I place a second ESP near the router as a dedicated watchdog?
Yes. Install a small ESP module in the loft that only monitors connectivity and toggles a relay. This offloads recovery from the main ESP by the inverter. A referenced example shows a simple network watchdog pattern for ESP8266. [Elektroda, krzbor, post #18811592]
How can I check internet reachability before issuing a reboot?
Ping a reliable host, such as 8.8.8.8, using the Pinger library. When responseTime equals -1, declare no internet and send the reboot GET. Embed router credentials in the URL for Basic Auth as shown in working examples. [Elektroda, futek2, post #18814110]
Does Gargoyle firmware handle USB modems reliably on MR3020?
Reports suggest instability with Gargoyle on this hardware compared to OpenWrt.org images. Users saw better stability using official OpenWrt builds, though they require more manual setup. Tutorials are available for most tasks. [Elektroda, Ibuprom, post #18810612]
What response should I expect from the MR3020 after a reboot request?
Expect an HTML payload and a standard HTTP status code. When the code is OK, read the full page into a string. Use it to confirm the action and debug. Always close the client with http.end() after processing. [Elektroda, futek2, post #18816182]
