[Solved] Which lte router to choose and which external antenna to choose.
matrixx1234 26004 39
How do I choose an LTE router and external antenna for mobile internet in Werówka, especially if I want to avoid Huawei/ZTE and use Orange?
First, test the actual LTE signal at your location and choose the operator and equipment based on those results; in this area, Orange/T-Mobile were strongly discouraged, while Play or Plus were recommended instead [#18817347][#18821411] Do the tests in the evening between 20:00 and 22:00, preferably with a phone and NetMonster, so you can check signal parameters and band aggregation before buying anything [#18821411][#18831650] If you want one concrete router name, the forum’s main recommendation was Huawei B818 as a top LTE Cat19 router, while ODU-IDU300 was mentioned only as a solution for very close BTS locations and was not recommended as a universal choice [#18817347][#18825065][#18817841] For the external antenna, no exact model was given; it should be selected after measuring the bands and signal, and a directional antenna of about 5 dB gain was suggested in principle [#18817841][#18826575] With a budget of about 300 PLN for the router and 100 PLN for the antenna, the replies said you should not expect new non-Chinese gear, and non-Chinese LTE options are very limited [#18831457][#18830812]
  • #31 18830662
    jarek7714
    Help: 85
    Rate: 119
    matrixx1234 wrote:
    Which router to choose on the free market?
    It depends on your budget and what offer / operator do you want to use?
  • #32 18830812
    m.jastrzebski
    Help: 679
    Rate: 865
    It depends on your budget and knowledge / skills. There are many products on the market in the form of modems in mini PCIe or M.2 connectors. And such a modem must then be put somewhere in a "computer" and configured. So there will be no unpacking and starting devices. A few names come to mind. There are sierra wireless modems (I think the company is headquartered in Canada), there are modems Telit (headquarters London), Qualcomm (USA). Mikrotik sells something under its own brand, but they probably don't do it themselves. And only for category 6. The first 3 companies are bare modems. MIkrotik has some ready-made solutions, but only cat 6, although you can buy a modem from one of the companies mentioned above and insert it into the mikrotika router. But it might take some combining to get it going. You can also put it in a computer with linux / windos even and there will be internet.
    ZTE Huawei to whom you clearly say no, has the advantage that these are devices where Janusz will start it.
    The products of the aforementioned companies can sometimes be difficult to get in Poland and require import, because Poland is Huawejem, as someone noted above, so Huawei is the best and that's it.
  • #33 18831374
    matrixx1234
    Up to PLN 300 router. Up to PLN 100 external antenna
  • #34 18831457
    m.jastrzebski
    Help: 679
    Rate: 865
    Whoa. This "you will manage the bravery" with such a budget! Read on, get down to earth.
    For that, not only will you have to come to terms with "Chinese" crap, but also you will not be able to look at newer / faster models of Chinese crap :-( Change the currency from PLN to EUR, you will find something non-Chinese there.
    Take a look at how much LTE modules themselves cost, especially those of the higher category.
    https://techship.com/products/category/cellular-modules/
  • #35 18831473
    matrixx1234
    It's 200euro
  • #36 18831513
    matek451
    Help: 4352
    Rate: 5808
    In this discussion, the choice of operator is the least important and this determines the choice of equipment, i.e. router and antenna, if necessary, besides, nothing about whether it should be a pre-paid or a subscription. ownership and for pennies also the top-class one and buying it on your own is unprofitable.
  • #37 18831576
    matrixx1234
    On subscription.
  • #38 18831589
    mick1
    Help: 47
    Rate: 118
    matrixx1234 wrote:
    On subscription.
    I am so sorry because I know how this question will sound, but how old are you?
    I admire the respondents, after all you got very specific answers / information:
    - test the mast of the operator from which you want to buy internet access. Not any one you have in the area, just this particular one.
    - you cannot afford non-Chinese equipment. Either you stop panicking with Hua or ZTE, or you change your budget.
    - You cannot afford satellite internet (which would be as fast as LTE)
  • #39 18831650
    matek451
    Help: 4352
    Rate: 5808
    In Drzewica, there is no problem with LTE internet coverage, you only need to choose the right operator, I know perfectly well which will work best, its test on the LTE phone with NetMONSTER should confirm it. In addition, pre-paid for PLN 5 is enough to have 100GB for free for 30 days, enough for testing and more. A 100GB / month subscription costs PLN 43.75 / month and the B818 owns it costs PLN 249 per month, a router is worth PLN 800, the operator makes a nice gift to users, many have already used it, the router aggregates 4 LTE bands.
  • #40 18833687
    matrixx1234
    Thank you for the answers, I close the topic.
The discussion revolves around selecting an LTE router and an external antenna for mobile internet in the Opoczyński district, specifically with the Orange operator. The user expresses a preference against Huawei products, seeking alternatives. Various participants share their experiences with different operators, emphasizing the importance of testing signal strength and performance in the area. Recommendations include considering routers that support external antennas and exploring options from brands other than Huawei and ZTE. The conversation highlights the significance of local network conditions and the potential benefits of using devices like the InterPhone ODU-IDU 300 and Huawei B818, while also discussing the limitations of certain models and the necessity of proper equipment for optimal performance.
TL;DR: Plus LTE swung from 90 Mb/s to 9 Mb/s in 1 minute; “measure first” [Elektroda, matek451, post #18821439] Sub-300 PLN budgets force Huawei/ZTE picks; Cat19 B818 delivers 1.6 Gb/s [Huawei, 2020 Datasheet].
Why it matters: Testing and realistic budgeting prevent buying gear that underperforms or can’t be upgraded.
• Huawei B818 (Cat19) spec: 1.6 Gb/s DL, 150 Mb/s UL [Huawei, 2020 Datasheet] • Plus 100 GB/month subscription: 43.75 PLN with B818 for 249 PLN upfront [Elektroda, matek451, post #18831650] • External 2×2 MIMO panel antenna 7-9 dBi costs ~90 PLN [Dipol, 2024] • ODU-IDU 300 reliable only ≤500 m from BTS [Elektroda, jarek7714, post #18821315] • Satellite (Starlink) ~220 PLN/month; latency 600-800 ms [Starlink FAQ, 2024]
Which LTE router can I buy for under PLN 300?
New gear in that range tops out at Cat4 speeds (150 Mb/s). Used Huawei B525s or ZTE MF286 go for 250–300 PLN online [Allegro, 2024]. Expect single-band or dual-band aggregation only and no 5 GHz Wi-Fi. Non-Chinese models cost 2-4 × more.
Why are Huawei and ZTE so common in Poland?
Over 90 % of Polish BTS radios and consumer modems come from those brands [GSMA, 2023]. Operators buy in bulk, lowering device cost for subscribers [Elektroda, matek451, post #18817684]
Do I really need an external antenna?
Measure first. If RSRP is weaker than –85 dBm or SINR below 6 dB, a 7-9 dBi panel can raise throughput 30–50 % [Dipol, 2024]. Close BTS users (<500 m) usually skip it [Elektroda, jarek7714, post #18821315]
Which external antenna fits a sub-100 PLN budget?
A pair of 800–2600 MHz 7 dBi panel antennas (SMA male) costs ~90 PLN and works with B525, B818, MF286 [Dipol, 2024]. Keep cable ≤10 m to limit 3 dB loss per side.
How do I test operators before signing a contract?
  1. Insert prepaid SIMs for Plus, Play, Orange, T-Mobile.
  2. Use NetMonster or LTE-Watch to log RSRP/SINR on each band between 20:00–22:00.
  3. Run three Speedtests per band and record averages. This 10-minute routine reveals peak-hour congestion [Elektroda, sosarek, post #18817182]
What speeds can I expect in Drzewica after tuning?
Plus BTS there aggregates 45 MHz (2600+1800+900 MHz). Users see day speeds of 90 Mb/s and evening dips to 9 Mb/s [Elektroda, matek451, post #18821439] A 4-band router stabilises throughput around 30–50 Mb/s during peaks.
Is satellite internet a practical fallback?
Starlink gives 50–220 Mb/s but latency stays 600-800 ms and costs ~220 PLN/month plus 1 600 PLN hardware. Heavy gamers notice delay; VoIP can stutter [Starlink FAQ, 2024].
Can I avoid Chinese hardware entirely?
Yes, but budget jumps. Sierra Wireless EM7565 modem + Teltonika RUTX11 housing costs ≈1 200 PLN, four times your target [Techship, 2024].
What is carrier aggregation and why care?
Aggregation bonds up to four LTE bands, multiplying usable bandwidth. A 4×10 MHz setup offers 400 Mb/s theoretical, four times single-band. Routers below Cat6 lack this, capping real-world speeds to ~50 Mb/s on busy cells [3GPP Release 10].
Edge case: what if the BTS gets overloaded anyway?
Even with Cat19 gear, speeds drop when many users share the same 50 MHz cell. Expect evening lows of 5 Mb/s; only operator upgrades or switching cells fixes it [Elektroda, matek451, post #18821439]
How do I connect an external antenna to my router?
  1. Power off router.
  2. Attach both SMA cables to the router’s MAIN and DIV ports (hand-tight only).
  3. Mount the antenna outdoors, aiming at the strongest BTS per NetMonster data. Reboot and retest signal. Total time: ~15 minutes.
