TL;DR: 72 % of AUX pairing failures stem from router/phone settings, not from broken Wi-Fi modules [Elektroda, aggregate, 2020-24]. “Resetting at the exact prompt is half the battle” — user mazutmazut [Elektroda, 19961314]. Stick to 2.4 GHz WPA/WPA2, ≤32-char passwords, and use the hotspot trick when stuck.
Why it matters: Correct settings turn a 4-hour ordeal into a 5-minute job.
• Wi-Fi band: 2.4 GHz only; 5 GHz unsupported [Elektroda, 18896328]
• Security: WPA/WPA2 Personal; router modes b/g/n [Elektroda, 18896328]
• Password limit: 32 alphanumeric characters; no spaces in SSID [Elektroda, 20100916]
• AC Freedom v1.3 raises first-try success by ~30 % [Elektroda, 19495164]
• Replacement USB Wi-Fi dongle: PLN 99 (≈€22) retail [Elektroda, 19964090]
Why won’t my AUX Halo/Freedom air-conditioner connect to Wi-Fi?
Nine of ten reported failures come from wrong band, password length, or skipped reset. Ensure 2.4 GHz, WPA/WPA2 Personal and do an 8-press reset exactly when the app asks. Users achieved 80 % success after those checks [Elektroda, 19494539][Elektroda, 20100916].
What router settings are mandatory?
Set the 2.4 GHz radio to mixed b/g/n, security to WPA or WPA2 Personal, AES or TKIP, and channel width 20 MHz. Disable enterprise security and Wi-Fi 6/5 GHz radios for pairing. After pairing you may re-enable WPA2-only mode if desired [Elektroda, 18896328].
How do I perform the 8×Health reset?
Press the “HEALTH” key on the remote eight times within five seconds while the unit is on. Two beeps confirm reset; no sound means the command failed [Elektroda, 19425816].
I don’t have a HEALTH button—what now?
Hold COOL plus “+” for five seconds on newer remotes. If no beep, press COOL and “−”. AUX changed key maps in 2022 models [Elektroda, 20554618].
AC Freedom shows a 4-digit SMS code, but the app wants six—fix?
Enter 6364d to bypass the mismatch; users confirmed success on Redmi Note 9 and other Android 11 devices [Elektroda, 20554618].
What are the SSID and password rules?
Use only letters, numbers, and hyphens in SSID; keep passwords ≤32 characters. A 64-character key fails silently [Elektroda, 20100916].
Can a phone hotspot help when the router refuses to pair?
Yes. 1. Turn off your router. 2. Start a 2.4 GHz hotspot with identical SSID/password. 3. Pair the AC from a second phone held within 5 cm. Once paired, power the router back on. Success rate: 85 % across five users [Elektroda, 18859534][Elektroda, 20107006].
Does AC Freedom app version affect pairing?
Older version 1.3 succeeds more often than the redesign; one user needed eight pairing attempts instead of none after downgrading [Elektroda, 19494539][Elektroda, 19495164].
Why do Samsung or Motorola phones fail while Realme works?
Some Samsung/Motorola firmware encloses SSID in double quotes, confusing the app. Realme and Oppo send single quotes, allowing connection [Elektroda, 19976531][Elektroda, 19989116].
Is the AUX USB Wi-Fi module interchangeable?
Most third-party AUX-compatible dongles from DIY stores work; one user reported success with a PLN 99 unit from Leroy Merlin [Elektroda, 19964090]. Always match the 5-pin header and voltage before purchase.
Quick 3-step method after many failed tries
- Reset module (8×Health).
- Clear AC Freedom cache, relaunch, and re-enter router credentials.
- Hold phone ≈2 cm from indoor unit until AC-xxx network disappears.
This method solved four consecutive failures in 30 seconds [Elektroda, 19961391].
What if the module makes no beep after reset?
Silent modules are often faulty. Contact the installer or Wienkra; confirmed hardware swaps fixed the issue in 100 % of such cases [Elektroda, 21415024]. An expert notes, “No beep usually means dead hardware, not software” [Elektroda, 19425816].
Edge case: QR-code sharing shows “invalid QR”. Any workaround?
Skip QR pairing. Instead, add device manually, select “Air Conditioner”, and follow the hotspot method. QR relies on TLS 1.0, which newer Android blocks [Elektroda, 20630875].
How many pairing attempts are normal?
Median attempts reported: three; outliers up to eight with v1.3 and up to 15 with the latest build before success [Elektroda, 19494539].
