Push-button and twisted-pair lighting control modules
DzieX 1842 20
Can I find off-the-shelf lighting modules that work with existing push-buttons and also let me switch lights remotely over twisted-pair wiring from a Raspberry Pi/app?
Yes: the thread’s concrete suggestions were Shelly modules — Shelly 1 for 1 channel and Shelly 2.5 for 2 channels — because they can be controlled from wall switches (including bell/push buttons) and also via a bus/app, with the note that you should check whether they fit in the flush boxes [#18873176][#18873349] For roller shutters, Shelly 2.5 or shutterBox were suggested as ready-made solutions that support both switch and app control [#18872897] If you want a more analogue, DIY-friendly approach, another option mentioned was using bistable relays driven from the Raspberry Pi [#18873349] The replies did not identify a dedicated 3-channel wired lighting module matching your exact twisted-pair idea [#18873176][#18873349]
  • #1 18872613
    DzieX
    Rate: 52
    Hi, I have a twisted pair cable drawn to each of the boxes in my house and would like to use it to control lighting and roller shutters. While the subject of roller shutters seems fairly straightforward to me, I can't (maybe I've searched poorly) find lighting control modules (1, 2 and 3 channel). I'd like to keep the current candlestick switches, but add the ability to switch the lights on over the twisted pair. I don't know if I'm approaching the subject correctly because, to my surprise, finding such wired controlled modules is probably impossible. Ultimately the whole thing is to be operated by a Raspberry Pi and an app on a phone. Are there any off-the-shelf modules available that will allow switching both from buttons and remotely?
  • #2 18872619
    kkknc
    Help: 1916
    Rate: 6712
    Isn't it better to give z-wave modules and a control unit? You could also give our Suple from zamela or and not similar modules. Cheaper, although less possibilities.
  • #3 18872897
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    DzieX wrote:
    I would like to keep the current candlestick switches, but add the possibility of switching the light on via a twisted pair
    How would this work? A candlestick switch complicates the situation.
    It might be better to use a ready-made solution - more flexible, functional and probably much cheaper.
    For roller shutters maybe Shelly 2.5 or shutterBox, for example - you can control with a switch and from an app.
    For light control - there are a lot of solutions here - from smart switches to dimmable/coloured light bulbs by remote control.
    If you integrate it with e.g. google home, you control it with one app. The whole system can be expanded in the future.
    The choice of specific solutions is a matter of budget and requirements.
  • #4 18873001
    DzieX
    Rate: 52
    Well, I don't know how. Preferably like the mentioned supla only by cable. In general, I would like to base everything on the raspberry pi and write myself an app for this. Ready-made solutions do not interest me.
  • #5 18873060
    kkknc
    Help: 1916
    Rate: 6712
    Then write, it only works out cheaper and more secure that way. I write about ready-made solutions.
  • #6 18873073
    DzieX
    Rate: 52
    It is nothing urgent. Even if it takes a long time. The problem is to find just such a relay which, having the input from the switch and the signal on the twisted pair, will switch the light on or off. Unless I don't know how to look or it's called something specialised and I don't know the name. I was hoping for some kind of hint.
  • #7 18873176
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    I have already given a hint: Shelly 2.5.
    Universal for your own ideas - two channels, you can control switches (also bell switches), over the bus, if you add relays it's also low current.
    If you don't want to use wireless functions, you don't have to (except for configuration). Or you can use the app straight away and work on your system.
    You give little information, so the answer is very general.
    Twisted pair control can be implemented in many ways. The number of lights you want to control is also important - Shelly 2.5 has 2 channels, Shelly 1 has 1 channel.
    It is also important what kind of installation you have (with N - the so-called new type, or without N in the switch boxes - the so-called old type, or e.g. star).
  • #8 18873189
    DzieX
    Rate: 52
    N and earth are in the same box as the switches
  • #9 18873211
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Check this out Shelly. How about regular relays?
    You give little information so it's hard to advise more.
  • #10 18873220
    DzieX
    Rate: 52
    That's because I'm constantly wondering what to choose.
  • #11 18873300
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    The basis is a description of the functionality you want and what is and cannot be changed (e.g. installation). In addition, individual requirements - such as RPi and twisted-pair control.
    Then you can look for possible solutions and choose the best one.
    If not the requirements: RPi and twisted pair - the topic would be very simple. This complicates the situation and brings "an era down".
    How do you envision controlling devices via RPi? GPIO via some relay module or some other way?
    I'm assuming you'll do the software (RPi + application) on your own.
  • #12 18873319
    DzieX
    Rate: 52
    Yes, gpio. I will write the soft myself based on ready-made libraries.
    Generally, nothing can be changed in the installation because everything is already plastered and I live. More requirements than a raspberry and twisted pair I do not have. I just want to keep the "manual" operation of the installation. The electronics should only be an addition.
    Don't tell me that cable control is an epoch down relative to wifi. Over wifi everything works beautifully until suddenly after a storm you have to reprogram all the modules :-) .
  • #13 18873340
    kkknc
    Help: 1916
    Rate: 6712
    The price of this Shelly 2.5 is similar to the z-wave modules.
  • #14 18873349
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Then you should solve the control with these Shelly (assuming you will be able to tuck them into the cans (they are small, but better check).
    Another way - even more 'analogue' is bistable relays and control from the RPi.
    P.S.
    DzieX wrote:
    Don't tell me that control over cable is an epoch down relative to wifi. After wifi everything works beautifully until suddenly after a storm you have to re-program all modules
    - Correction. By 2 epochs. By one epoch it's backwards to WiFi. Zigbee is currently trending :) .
    As for programming modules after a storm or power cut, that's earlier eras too. I have quite a few different devices, from different manufacturers, different systems and no storm or power cut (e.g. a few hours) has caused problems - after a few minutes (the router has to get up and the devices connect) everything was working. Not all of them remembered the last state - I also have some older devices. A matter of getting the right devices.
    I would be more concerned about twisted-pair cable - I often replace devices connected to it after storms....
    Added after 8 [minutes]: .
    - Any specific suggestions that meet the Author's requirements?
  • #15 18873371
    kkknc
    Help: 1916
    Rate: 6712
    sk1977 wrote:
    Correct. By 2 epochs. By one epoch it's backwards to WiFi. Zigbee is currently trending :) .
    What you install the customer has. Price similar. Availability of equipment too.
  • #16 18873374
    DzieX
    Rate: 52
    I have heard other stories. I do know one thing - most if not all of these modules are in a closed architecture with bundled software making them expensive and not very developable. I have a 220m2 house and 70 garage and hence the idea to implement myself.
    kkknc
    Help: 1916
    Rate: 6712
    I wonder where you heard these stories? Probably from those who had nothing.
    DzieX wrote:
    One thing I do know is that most if not all of these modules are in closed architecture with bundled software making them expensive and not very developable.
    So which systems are closed? Give specifics. There aren't many of them. So you can easily list them all. And this soft is how?
    DzieX wrote:
    I have a 220m2 house and 70 garage and hence the idea of implementing it myself.
    A lot depends on the head office. But with LUA scripts you will earn everything.
    You want to implement, then implement. Only as I see it knowledge is not very much. So little chance of total success.
  • #18 18873425
    DzieX
    Rate: 52
    From my electrician :-)
    Getting the word out is the very purpose of this thread.
    Then I'll list these systems when I sit down to the computer
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    DzieX wrote:
    From my electrician
    - everyone has their own experiences.... Maybe this electrician has just had a bad one. Maybe he came across such workmanship, or did such work himself and then had complaints :) .
    Many installations are done not by electricians, but by electricians and "electricians" (spelling on purpose, and as you know many Poles are familiar with computers, medicine, electricity, mushrooms, and for some time also air crash investigation).
    DzieX wrote:
    Gaining knowledge is the very purpose of this thread.
    - it is good that there are still people seeking knowledge before they get down to shopping and doing :) .
    A lot depends on the choice of equipment. It doesn't have to be expensive and undevelopable. On the contrary. It can be cheap, stable, functional, developmental, etc.
    In this area and probably in the long term (development), I would rather lean towards Zigbee - it has many advantages over WiFi + e.g. Home Assistant.
    Realising your own system is an ambitious and extensive project - a bit like building a car from parts in your garage.... If you decide to do it, I wish you luck and keep my fingers crossed.
    It will be difficult with help, because that's the nature of your own projects - but if you have questions then maybe you can find the answers.
  • #20 18875179
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    sk1977 wrote:
    One era is a throwback to WiFi.
    I will disagree with this, but it is my own opinion.
    If we have a well done LAN and wifi coverage I think this is the cheapest option for an IoT base.
    The main advantage - cheapest components and ease of configuration. Plenty of open source software with which to replace the original mostly cloud-based software.
    Main disadvantage - power consumption - yes z-wave, zigbee, BT LE, run longer on batteries. However, even though most of the components are not very expensive, it still comes out much more expensive overall than those based on ESP processors.
    Current consumption can be reduced by using deep sleep where battery power must be present.
  • #21 18875365
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    By talking about a different era, I meant a change in approach to IoT - creating their own dedicated solutions rather than using existing ones.
    Major manufacturers (or vendors offering smaller manufacturers under their brand) are releasing new devices already based on Zigbee rather than WiFi. This will become clearer in some time, but in my opinion WiFi-based devices will disappear from offerings.
    Device prices are also becoming more accessible, especially for gateways. Compatibility between manufacturers will probably improve too - we will see in a few years.
    To the disadvantages of WiFi-based devices (compared to Zigbee) I would add the load on the WiFi network, the need to take care of coverage (Zigbee-based devices connected to mains mostly extend coverage), longer connection time, response time, stability.
The discussion revolves around the integration of twisted pair cables for controlling lighting and roller shutters in a home automation setup, specifically using a Raspberry Pi. The user seeks to maintain existing candlestick switches while adding remote control capabilities. Various solutions are proposed, including the use of Shelly 2.5 modules, which allow for both manual and app-based control. The conversation highlights the challenges of finding suitable lighting control modules that can operate over twisted pair wiring, with suggestions for using relays and discussing the pros and cons of different communication protocols like WiFi, Zigbee, and Z-Wave. The importance of a well-planned installation and the potential for future expansion are also emphasized.
TL;DR: Want wired control plus apps? Start with Shelly 2.5 (2 channels) for lights and shutters or bistable relays; "Shelly 2.5 has 2 channels." Keep switches, add RPi over twisted pair, and ensure N is in the box. [Elektroda, sk1977, post #18873176]
Why it matters: This FAQ helps DIYers with twisted-pair prewire keep manual switches while adding reliable Raspberry Pi or module-based automation.
Are there wired modules that keep my existing switches and also enable remote control?
Yes. One path is in-wall modules like Shelly placed behind the switch. Another path is bistable step relays driven by your Raspberry Pi over twisted pair. The latter keeps full manual control and adds low-voltage control lines. “Another way – even more ‘analogue’ is bistable relays and control from the RPi.” [Elektroda, sk1977, post #18873349]
What should I use for roller shutters, and can I still use wall switches?
Use Shelly 2.5 or shutterBox for shutters. Both support wall-switch inputs and app control. They fit mixed control scenarios and let you expand later. You can also integrate with Google Home for unified control. “You can control with a switch and from an app.” [Elektroda, sk1977, post #18872897]
How do I add Raspberry Pi GPIO control safely over my twisted pair?
Use a relay interface; do not switch mains directly from GPIO. Keep twisted-pair as low-voltage control to a relay module, then switch mains with the relay. How-To:
  1. Pick an isolated relay board and mount it near the load.
  2. Wire twisted-pair to the relay coil/inputs from the RPi.
  3. Have a qualified electrician wire the relay contacts to the light circuit. This mirrors the suggested “GPIO via some relay module.” [Elektroda, sk1977, post #18873300]
Do I need neutral (N) in the switch boxes for in‑wall relays?
It depends on your installation type. With N in the box (new type), more in‑wall modules will work cleanly. Without N (old type), choices shrink or wiring changes are needed. The wiring topology (e.g., star) also influences placement and options. Define your wiring first, then select modules that match it. [Elektroda, sk1977, post #18873176]
Will Wi‑Fi modules lose settings after power cuts or storms?
Modern devices generally recover after the router and devices reconnect. “After a few minutes everything was working,” though some older devices may not restore last state. The bigger risk mentioned is surge damage on long twisted‑pair runs. “I often replace devices connected to it after storms….” Add surge protection or isolation where practical. [Elektroda, sk1977, post #18873349]
Is Zigbee better than Wi‑Fi for lighting control?
Zigbee can ease Wi‑Fi congestion and improve responsiveness. It forms a mesh, and mains‑powered nodes extend coverage. “Zigbee-based devices connected to mains mostly extend coverage.” Trendlines favor Zigbee for new devices and better cross‑vendor compatibility. Expect smoother scaling as you add modules room by room. [Elektroda, sk1977, post #18875365]
Are Z‑Wave or Supla worth considering for a wired‑first project?
Yes. Z‑Wave modules with a controller are a solid option. Supla by Zamel is another path with lower cost but fewer features. These ecosystems reduce custom coding yet allow later expansion. Evaluate based on desired flexibility and your RPi integration plan. [Elektroda, kkknc, post #18872619]
Can I run everything locally without cloud or even Wi‑Fi?
Yes. Configure modules initially, then operate locally, or build your own RPi‑based control. “If you don’t want to use wireless functions, you don’t have to (except for configuration).” You can still use an app later or integrate gradually. [Elektroda, sk1977, post #18873176]
How do costs compare between Shelly 2.5 and typical Z‑Wave modules?
They are in a similar price range according to user experience. Quote: “The price of this Shelly 2.5 is similar to the z-wave modules.” Final cost depends on count, installation effort, and any added relays or protection. [Elektroda, kkknc, post #18873340]
Do candlestick (two‑way) switches complicate automation?
Yes. “A candlestick switch complicates the situation.” Two‑way toggles route live conductors differently than momentary buttons. Consider ready‑made modules that support switch inputs, or rework to momentary/bell switches if you redesign. This keeps manual control consistent. [Elektroda, sk1977, post #18872897]
What can unify everything under one app if I later add wireless?
You can integrate devices with a common hub. For example, connect supported modules and control them through Google Home as a single app. This centralizes scenes and voice control while keeping manual switches. “If you integrate it with e.g. google home, you control it with one app.” [Elektroda, sk1977, post #18872897]
How many channels do I need per location?
Match module channels to your circuits. Shelly 2.5 provides 2 channels for dual lights or shutters. Shelly 1 provides 1 channel for single loads. Use the smallest device that meets your needs to simplify wiring and configuration. “Shelly 2.5 has 2 channels, Shelly 1 has 1 channel.” [Elektroda, sk1977, post #18873176]
