How do I make the installation for controlling roller shutters, heating and light?
valek333 4506 49
How should I wire a new house so I can later control roller shutters, heating and lighting, including motion-sensor lighting?
There is no universal cabling scheme: first choose the control system, because the required wires depend on it, and a full return-to-the-switchboard layout only really makes sense for a KNX-type system, which is expensive and usually installed by professionals [#18456913] [#18462617] Do not route alarm sensors to light switches; keep the alarm sensors on the alarm system, and if you want the alarm to participate in automation use a Satel Integra with its outputs/integration protocol instead of wiring it directly as a light control [#18456913] [#18455770] [#18462617] If you want a more future-proof installation, plan the automation separately from the alarm, use deep junction boxes, and consider that many solutions are now wireless or use distributed modules such as Sonoff/Supla/HomeMatic rather than centralizing everything in one place [#18485252] [#18455770] For lighting, one practical option mentioned was a Sonoff TX touch switch, which needs L and N but can still work as a local switch even without app control [#18485252]
  • Separate bus, sensor, and switch wiring recommended
    #1 18446031
    valek333
    Rate: 16
    Hi, I'm doing an installation in a new house and I don't know how best to do the installation to control the roller shutters, heating and lighting.
    Is it enough if I run a bus cable from the distribution board to each point I want to control and back to the distribution board?
    If I want to control the light via a sensor in each room, should I run the cable to a separate sensor or should I use the sensor from the alarm and, if possible, run the cable from the sensor to the switch (I want to use the switch to decide whether the light should be completely switched off or whether it should be switched on by means of a sensor)?
    Moderated By suworow:
    I have merged both of my colleague's topics. Please do not set up two topics which are basically the same, because users then do not know where to answer.
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    Consider wireless modules e.g. Supla, Sonoff.
    suworow
    Help: 650
    Rate: 1278
    If, for a colleague, the problem boils down to whether or not to run a wire from the sensor to the switch, then I suggest you give it a rest. If it's going to work, you simply have to sit down and think about it, preferably with someone who knows a bit about it. If you want to make your wiring fairly universal, then you should certainly link the smart home installation to the alarm system, as well as others, but certainly not in the way you have presented it.
  • #5 18456913
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    valek333 wrote:
    Is it sufficient if I run a trunk cable from the switchboard to each point I want to control and back to the switchboard ??
    This would only make sense with Knx type systems.
    This is an expensive system and the customer is unlikely to do anything himself but have everything done by professionals. Even the wiring.
    valek333 wrote:
    and if it is possible, it is enough to run a cable from the alarm sensor to the switch (
    No. Not that way. Leave the alarm sensor alone.
    If you do, you must have a Satel Integra control panel to use the sensors for control. And this is done by programming it properly and using the outputs of the control panel, or what is a much better solution through the integration protocol.
    Anyway, from the way you asked the questions, I think it's unlikely you'll be able to do it yourself.
  • #6 18456933
    valek333
    Rate: 16
    So what do you propose for future control of lighting, roller shutters, heating via the internet and of course switches, and for the installation to be traditional, not star-shaped.
  • #7 18456945
    valek333
    Rate: 16
    And a trunk cable from the switchboard to the point I want to control is not enough?
  • #8 18457058
    xury
    Help: 878
    Rate: 1497
    I suggest looking for a contractor.
  • #9 18458233
    suworow
    Help: 650
    Rate: 1278
    I dream of a topic from which home automation enthusiasts will learn how to approach this issue, but with the author's attitude and reducing the discussion to how to "throw a cable" I can hardly see it happening....
    But I'll give it a try....
    First lifebelt:
    Lighting circuits. Are they only to be controlled from motion detectors, or perhaps additionally in some other way?
  • #10 18458684
    Daro1003
    Help: 295
    Rate: 608
    When making an installation according to the author's needs, it is necessary to know which control modules are to be used, and more precisely which system. Whether you want to use sonoff and supla, as mentioned earlier, or an alarm system, e.g. Integra, or an adapted Fibaro system for home automation.
    Personally, I am planning to make an installation at my house, but I know exactly which module will control what, how and how to connect everything. I plan to lay all wires to the switchboard and put all modules there. According to my calculations, there are 288 module spaces :) .
    My colleague writes that he wants a traditional installation, so for lighting control you can give sonof touch instead of contacts or pack schelly modules behind contacts into boxes, in both cases it would be good to use boxes with pockets. In this way we have an installation for lighting laid traditionally we can always use ordinary contacts and it works traditionally.
    We can load various suple, AFE, Tasmota , EspEasy softy into the modules I have mentioned.
  • #11 18459972
  • #12 18459985
    Daro1003
    Help: 295
    Rate: 608
    Erbit wrote:
    This is why I personally decided to build "from blocks" from one manufacturer
    What is the main thing you have based on mate Erbit ?
    What did you use for lighting control ?
  • #13 18460031
  • #14 18460055
    Daro1003
    Help: 295
    Rate: 608
    I'm planning to do it in a star and use a Sonoff 4CH in the switchgear, and control them locally via switches which I'll feed with 12V, which will switch on the relay and which will fire the Sonoff.
  • #15 18460063
  • #16 18460210
    Daro1003
    Help: 295
    Rate: 608
    Yes, Sonoff is cheaper, but you have to dismantle each one, solder the pins and upload the software, then solder the wires and lead them outside for local control. It is a bit tedious.
    I have calculated 288 modules. But I will order more than 300 so that I have plenty to spare.
  • #17 18460230
  • #18 18460264
    Daro1003
    Help: 295
    Rate: 608
    You have 100% if it works and it works with colleagues on another forum it will work out inexpensively for me especially as I have already accumulated 8 Sonoff 4CH.
    I want to put the server on a Raspberry, I already have everything, a power supply, 2 Raspberries for testing and SSDs for them. I already have most of the components. As you wrote for 200PLN I have two Sonoffs or even almost 3 which have 4 outputs each so for 200PLN I control 12 bulbs independently.
  • #19 18460265
    suworow
    Help: 650
    Rate: 1278
    Erbit wrote:
    suworow wrote:
    I dream of a topic from which home automation enthusiasts will learn how to approach this issue....
    It's not that simple. Firstly everyone has different requirements for functionality and installation depends on these. secondly everyone has different skills. Some can upload alternative software to Sonoff. others cannot. Thirdly, there are those who know how to hold a soldering iron, fourthly, there are those for whom the best option is to "play with ready-made blocks" (I am completely ignoring those who do not know anything or have a lot of money and do not feel like playing). Add to this the options: building inhabited or is under construction or before renovation
    And this is precisely the kind of information for those fascinated by home automation that I am concerned about. About what they will have to deal with, what skills it all requires. It's not about a ready-made recipe, because there really isn't one.
    The author asked how to do the wiring. Here, undoubtedly, the greatest opportunity will be to pull all the circuits into the switchboard:
    Daro1003 wrote:
    I myself am trying to do the installation at my place, but I know exactly which module will control what in what way and how to connect everything. I plan to lay all the wires to the switchboard and give all the modules there. According to calculations, I have 288 module places :) .
    Another important piece of information has also emerged:
    Erbit wrote:
    If you want to base it on the actuators in the switchgear then buy "5 switchgear" at once because one, however big it may be, will not be enough
    And we have an order of magnitude in terms of finances ;)
    Erbit wrote:
    You can do it differently. My 160 components (over PLN200 each) adds up to no less than PLN32,000. Now translate that into your soldering and software upload. The choice is yours.
  • #20 18460294
    Daro1003
    Help: 295
    Rate: 608
    In summary my system is: .
    Sonoffy I bought for 60zł on allegro I saw for about 80zł.
    Raspberry about 300zł but I have one ali for 150zł in total only one will be needed but the other to spare and for testing.
    I bought two SSD 120G drives at 130PLN each to have two independent systems in case of emergency.
    Power supply 5V 6A approx. 60PLN.
    For the relay strips 8 relays on one x 8pcs cost me 150zł.
    The distribution board will cost about 3 thousand zlotys.
    And the wires - you know it will go much more.
    Bargain I bought on FB Zuggy connectors from some disassembly 600pcs at 0.30zł a piece so all the wires from the installation will end up on these Zuggy connectors in case of emergency appropriate bridges and replacement of contacts will make the installation will be traditional.
  • #21 18460306
  • #22 18460373
    Daro1003
    Help: 295
    Rate: 608
    I've also considered what will happen if the RBPi ladies or if the wifi goes down but the Sonoff 4CH from the local buttons will work and turn on the lights even though it won't be connected to the wifi this is some kind of plus. It is known to be a sculpted system.
  • #23 18460382
  • #24 18460422
    Daro1003
    Help: 295
    Rate: 608
    I'm just worried about interference because there will be a lot of these sonoffs in the switchboard, about 15 of them, and each one will be connected to the WiFi network; I wonder how it will work ;/ the downside is that they can't be connected via LAN.
  • #25 18460443
  • #26 18460466
    Daro1003
    Help: 295
    Rate: 608
    Do you think there will be too many wifi receivers next to each other ??
  • #27 18460469
  • #28 18462539
    valek333
    Rate: 16
    Hello, I am not interested in a star installation but in a traditional installation, if I can afford it in the future I would like to control the lighting, roller shutters, heating ... ... via the internet and telephone. I will soon be doing the installation in my new house and I would like to know what additional cables to run so that there are not too few of them, or is it enough to run a trunk cable to each point I want to control? And if I buy a SATEL INTEGRA 128-WRL GSM HOME ALARM SYSTEM and want to control lighting and other things, should I run star-shaped cables from the central unit to the point I want to control? And can I use sensors to switch on the lights?
  • #29 18462617
  • #30 18463082
    suworow
    Help: 650
    Rate: 1278
    Erbit wrote:
    I would never use a control panel to control lighting, heating and roller shutters. Well, but that's me - you can do as you think.
    For simple automation, control of a few lighting points, since we already have such a platform on the site, why not.
    Author forgive me, but how am I supposed to answer your questions when you ignore mine :( .
    suworow wrote:
    Lighting circuits. Are they to be controlled from motion detectors only, or in addition by other means?
The discussion revolves around the installation of a smart home system for controlling roller shutters, heating, and lighting in a new house. The main query concerns the feasibility of running a bus cable from the distribution board to each control point and the integration of sensors for lighting control. Various responses suggest considering both wired and wireless solutions, with recommendations for brands like Sonoff and Supla for wireless modules. The complexity of wiring depends on the chosen system, with suggestions to avoid combining alarm systems with smart home controls. Participants emphasize the importance of planning, understanding the required modules, and the potential need for professional installation. Concerns about WiFi interference with multiple devices and the advantages of using a Raspberry Pi for control are also discussed.
