[Solved] Cannot connect(pair) Xiaomi Mi LED Smart Bulb White&Color
rupert201 8691 1
  • #1 19101260
    rupert201
    Help: 60
    Rate: 162
    Hi. I have the above mentioned LED bulb and the Yeelight and Mi Home apps installed. After doing a reset of the bulb(i.e. 5 times on and off) and following the instuctions, an error appears, i.e. the whole process reaches 100%, and it writes that it failed to connect to the Wi-Fi network(here the name of the network appears, i.e. the name of the router network, not the name of the bulb) and to try again. Thank you in advance for your help. Greetings.
  • #2 19102257
    rupert201
    Help: 60
    Rate: 162
    The solution to the problem was to reboot the router(known as a hard reset) and restore it to its initial settings. After this action, both the Mi Home app and Yellight work correctly and detect the bulb.
