Reinstalling KOBI GS9 9.5W Smart Bulbs: Issues with TUYA App Connectivity
PiotrPelczar 1248 2
  • Bulbs exit pairing mode after a few seconds
    #1 20793672
    PiotrPelczar
    Hi!
    I have a problem with the RE-installation of the KOBI GS9 9.5 smart bulbs (3 pieces behave the same way)
    The bulbs worked flawlessly while connected to the old wifi network: they were connected to the TUYA app, while this was connected to the Google Home Mini.
    The current situation is as follows:
    1. I screw the bulbs into the lamp, do a hard reset (3+ times ON -> OFF)
    2. The bulb starts "breathing" while being ready to be paired (looks ok at this stage!)
    3. After about 3-4 seconds, the bulb stops flashing and shines full light - as if it has automatically connected to some network
    4. Yes both during and after flashing the bulb remains invisible to the TUYA application
    I have tried:
    a) reset the bulb a dozen times
    b) disable my wifi network, disable google home (in case the bulbs somehow connect to them on their own)
    c) I took the bulbs to the basement, away from any wifi networks they are known for, I also didn't have my phone with me
    Each time the effect is the same: hard reset - a few seconds in the pairing state - exit from the pairing state and full light.
    What is going on here? I should add that I have had the IDENTICAL problem with a bulb from another company in the past, but at the time I threw it away considering it to be faulty. This time the situation involves three pieces.
    HELP :) .
  • #3 20793823
    PiotrPelczar
    They have already been removed from the TUYA account, and of course do not show on the Google Home account either.
