Radio 357 - problem with programming stations on the internet radio
Manix62 29052 83
How can I add Radio 357 to my internet radio if the provided stream link does not work, and is there another stream address I can use?
The main issue is the stream format: Radio 357 originally broadcasts in AAC (about 130 kbps), so many older internet radios and some vTuner receivers cannot open it [#19174572][#19296069] The thread’s practical workaround is to add the station manually in vTuner via “Add station” after logging in [#19162840] A working relay stream shared in the discussion is `http://stream.open.fm/378?type=.aac`, and some users also report success with `http://stream.open.fm/378` or `http://stream.open.fm/378?type=.mp3` depending on the receiver’s supported formats [#19163210][#19481535] Later, a direct MP3 128 kbps link was also posted: `http://n05a-eu.rcs.revma.com/an1ugyygzk8uv` [#19291562] However, older Pioneer N-30/50 models still may not work with the revma links because they cannot handle the redirect mechanism, so in that case the thread suggests Bluetooth/AirPlay or a newer receiver [#19296069]
  • #31 19197709
    Walery K
    Help: 32
    Rate: 100
    Last year, on aliexpress, you could buy such a tiny Audiocast M5 device for a few dozen zlotys and connect it to any amplifier. It works quite decently and you control it with your smartphone.
    Unfortunately, today you will not find it there anymore, but it is available in Polish stores, but it costs twice as much.
    This is supported by vTuner, among other things.
  • Audiocast M5 and Logitech Bluetooth transmitter alternatives
    #32 19197888
    miroz2
    Or the bluetooh logitech transmitter is a bit cheaper and also straight from the smartphone to the amplifier. I have been using it for a long time and it works great.
  • #33 19197952
    Walery K
    Help: 32
    Rate: 100
    Only the Audiocast M5 works independently of the smartphone. The smartphone is only needed to start or change the currently received program for the first time. You can also adjust the volume with it.
  • M5 Audiocast works independently of smartphone
    #34 19198089
    miroz2
    Yes, the M5 audiocast works independently of a smartphone :) you need your smartphone ONLY to turn on and change the channel.
    via bluetooh transmitter logitech you can connect a smartphone or computer and also a smartphone or computer is needed ONLY to turn on and change the channel :D
    Everyone can choose what will be more convenient and cheaper for him.
    I do not insist on my proposal but it shows a different solution. Best regards.
  • Radio 357 stream format unsupported by some receivers
    #35 19198153
    TOM_Yamaha
    Polon_us wrote:
    duszysko wrote:
    We are waiting for an update.
    The problem lies not with the update.
    Please carefully and slowly read your colleague's entry # 18 @krokodylowy .
    The problem is the audio format in which the 357 radio broadcasts.
    I put it wrong - the problem is the lack of audio formats streamed by this radio.
    The one broadcast at present is not accepted by receivers of some manufacturers - as above
    I confirm that Radio 357 appeared on vTuner - it is probably the only radio broadcast on AAC stream. So I still do not receive it on the Yamaha RXA 810 receiver. Nobody from the radio responds to e-mails and messages sent from FB, with a request to add an MP3 128 stream. Is there someone who managed to contact Radio 357 regarding this matter?
  • #36 19198257
    duszysko
    I tried, no response to the contact attempt. Perhaps they would respond if someone from the Patrons group tried to contact.
    But how can you become a Patron if not the ability to listen? :) Thank goodness there are other radio programs.
  • #37 19199516
    miroz2
    Radio 357, which appeared on vTuner on my Yamaha RN 500, works, you have to wait a bit until it clicks and I do not see RDS but it works and shows the RealPlayer 128K format
    So far, I received it by adding it to vTuner myself, using the advice of my colleague Polon_us and streaming, which was provided by my colleague Qubus from Open fm.
    Or via Blauth from your smartphone to the amplifier.
  • #38 19206396
    Krzysiu50627
    My Pioneer N-30 player plays R357 but no RDS and 32 kbps. RNS stream from vTuner shows error.
  • #39 19219743
    slawekzz
    Speaking of what to listen to. Works great on Amazon Alexa.
  • #40 19220221
    Polon_us
    Help: 1184
    Rate: 1280
    Krzysiu50627 wrote:
    RNS stream from vTuner shows bug.
    This may be a bug on the vTuner side.
    If I were a friend, I would go to the RNŚ website, copy the link to the stream and use the vTuner "Add station" function to add this address to the receiver's memory by myself. The station will probably show up in the "Added station" tab.
    I recommend the 256kbps mp3 stream - the game is full :)
  • vTuner app finder misroutes Radio 357 stream
    #41 19220625
    Krzysiu50627
    I think my answer flew into the air. It again:
    First of all, thank you very much for your help. Coming to the matter, unfortunately my attempts to encode via stream did not help. The message "file format not supported" is displayed. I am strange because all other stations in a similar format are available and no problem (even in AAC). However, there is a different problem with the R357. Pioneer vTuner App Finder does not find R357. Only manual search ..... but after trying to play, another station "Radio Nysa" pops up. I wrote to vTuners about it and no response. You can see such a class of concentrator.
  • #42 19220647
    kolesp
    I agree with TOM_Yamaha and soul.
    Nobody from Radio responds to inquiries.
    I have the same problem with the Pioneer VSX920 ampli.
    I am waiting for the address in the form of http: // ......... mp3
    It's good that the "New World" is flying :)
  • Manual station entry using direct stream URLs
    #43 19220919
    Polon_us
    Help: 1184
    Rate: 1280
    Hmm, on the previous page of this topic, the streaming addresses for radio 357 are listed.
    A colleague will review the instructions for this receiver. It tells you how to add a station to the receiver directly, i.e. bypassing the vTuner service, having its streaming address.
    This can also be checked for RNŚ addresses - they are listed on their website.
    Please remember that you must enter exactly, without unnecessary spaces, before or after the address.
  • Manual station entry still fails for Radio 357 and RNŚ
    #44 19221205
    Krzysiu50627
    Please remember that you have to specify exactly, without unnecessary before or after the address.
    Unfortunately, all stations play LINN, RMF, TOK FM, Melo, WNET, RAM, even Radio Zielona Góra in AAC etc. and RNŚ and R357 do not. I gave the addresses and nothing .... All that's left for me is AirPlay.
    It's a pity .... Thank you again for your time and willingness to help. best regards
  • BT-to-FM transmitter failed after one day
    #45 19227146
    patsi2
    I am the patron of 357. At the beginning I asked the FB group about mp3 stream. Unfortunately, from the answers it can be concluded that the chances of this are slim (old technology). So far I am listening from any smartphone (even Lumia on W8) via BT on the amplifier. I tried with a transmitter called X8 (BT to FM). He gave up the ghost after one day of use. (this is called scheduled aging of the equipment - 24 hours of operation and to the trash)
  • #46 19231802
    duszysko
    So the patrons, however, respond. Thanks for the information.
    It's still good that you are on the electrode because you listened for 24 hours, if you, for example, first read an audiophile forum and had to "heat" the device and cables for a hundred hours
    you wouldn't even know if it was a game. :)
  • #47 19243001
    kolesp
    It cannot be said that they do not change anything because new streams have appeared. According to Community Radio Browser, there are now a total of 9 of them, 2 of which are in ACC +. Maybe someday they will add at least one in mp3.
  • Pioneer N30 playback error likely due to stream format
    #48 19264788
    Krzysiu50627
    Ladies and Gentlemen,
    However, I decided to inquire about the matter that I mentioned earlier. Please explain the reason why the R357 and RNŚ cannot be played through my Pioneer N30 player. Is this player not technically capable of accepting the format being broadcast? My attempts to add these stations by pioneer.vtuner despite finding them in the list have not been successful. Adding a direct stream as well. The player displays a playback error. From this he concludes that it is a question of the broadcast format. Can you please clarify the issue.
    best regards
    Christopher
  • Factory reset and test direct stream URLs
    #49 19265676
    Polon_us
    Help: 1184
    Rate: 1280
    If I were a colleague, I would reset this Pioneer to the factory settings. In my opinion, it is impossible that this receiver cannot pick up even a regular mp3. And RNŚ also broadcasts in this format.
    A colleague will restore the receiver to the factory settings and check again.
    There are 5 direct addresses listed on the RNŚ website, please test them one by one.
    Move the address using "Copy and Paste" - without unnecessary spaces, via vTuner.
    Also, a colleague can test the following RNF stream addresses:
    https://stream.nowyswiat.online/mp3
    http://stream.open.fm/368
  • Factory reset and vTuner stream tests failed
    #50 19267396
    Krzysiu50627
    Unfortunately, buddy,
    I performed a factory reset and then my attempts to stream the stream were unsuccessful. I pasted all possible addresses very carefully (no spaces). Additional information, when I choose from the list of stations directly at the time of acceptance (e.g. R357), the station below jumps into this place. This is very strange because other addresses encoded in different formats are played without problems.
    best regards
  • Recommend replacing the Pioneer receiver with an Ocean Digital WR10
    #51 19267709
    Polon_us
    Help: 1184
    Rate: 1280
    Well, I give up, I'm down with this Pioneer :(
    If I were a friend, I would try to change the internet radio receiver to something from Ocean Digital - the WR10 model.
    I am tired of whether it is only my friend's receiver that has an ailment, or is this model generally so. Maybe another user of this Pioneer N-30 model will respond and share his experiences.
    PS The colleague will finally check if there is any software update for your receiver.
  • #52 19291288
    rafalson
    Now there is mp3 / 128 kbps
    https://www.radio-browser.info/#!/byname/357
  • New Radio 357 mp3 128 kbps stream available
    #53 19291494
    patsi2
    and more precisely such:
    http://n16a-eu.rcs.revma.com/an1ugyygzk8uv?rj-ttl=5&rj-tok=AAABd-2TgQcAYhVSeWK54T7iIQ
    #54 19291562
    krzsiek
    Rate: 13
    This is enough:
    mp3 128kbps
  • #55 19293002
    kolesp
    Well, that's nice of them. That I still have a Pionek, I will give him this address and see if it works.
    Because in the meantime I changed the amp to the Denon AVR-X1600 Dab. This one supports aac.
  • Old Pioneer N-30/50 cannot handle 302 stream redirects
    #56 19296069
    borkokrz
    To a colleague from Pioneer N-30. It's not a matter of format, but of how to handle streams on the revma.com platform. Any stream address is temporary and the first response is 302 moved. The address, after pasting into the browser, changes almost every now and then - the beginning is different, the value of the rj-tok variable is different
    The oldest Pioneer N-30/50 cannot cope with it. Therefore, calling from the RNŚ directory ends with playing the next Radio Nysa station in the directory. You could add the full address that will appear in the browser in vtuner, but as I wrote before, it is valid for 5 minutes. Before each station change you would have to update it.
    The 357 is a bit different, because someone added the stream address from openFM in vtuner. There is no this mechanism with 302 moved, so it works, but also the stream quality calls for vengeance (32kbps).
    Of course, the N-30/50 cannot cope with https and all addresses must always be entered as http.
    To sum up. To enjoy 357 and RNW on old N-30/50:
    - add the stream address from openFM and swallow its low quality
    - buy a BT200 module and use Bluetooth or, alternatively, Airplay
    - set up a web server with php and scripts generate pls files containing current addresses of 357 and RNŚ streams. Links to these pls write vtuner as your own.
    - replace it with a newer model with A in the name, which has no problems with 302 moved support
  • #57 19296234
    Polon_us
    Help: 1184
    Rate: 1280
    @borkokrz - thank you for explaining the Pioneer N-30 problem.
  • #58 19380083
    miroz2
    Hello colleagues,
    maybe someone will be able to satisfy my curiosity.
    The point is that I would like to know how much transfer is consumed by radio 357, Radio Nowy Świat and others, or maybe there is some table of transfer consumption by individual radio stations somewhere?
  • #59 19381305
    Polon_us
    Help: 1184
    Rate: 1280
    With a standard audio stream bit rate of 128 kbps, the transfer is approximately 1MB of data for 1 (one) minute.
  • #60 19381783
    miroz2
    Polon_us, Thanks for the answer, and maybe you know how to check the bit rate of the 357 radio application on android?
The discussion revolves around issues with programming Radio 357 on various internet radios. Users report difficulties in receiving the station using the provided stream link, with some successfully adding it through vTuner or by manually entering alternative stream addresses. Several users mention that Radio 357 broadcasts in AAC format, which is not compatible with all receivers, particularly older models. Suggestions include using Bluetooth transmitters or alternative streaming methods. Some users have found success with specific stream links, while others continue to experience connection errors. The conversation highlights the need for compatible streaming formats and the importance of updating receiver firmware to resolve these issues.
TL;DR: 128 kbps MP3 streaming burns ≈60 MB/hour [Elektroda, Polon_us, post #19381305]; “works already” when the right URL ends in “.mp3” [Elektroda, Ensa44, post #19169990] Use direct MP3 links or vTuner’s “Add Station” to fix silent radios.
Why it matters: Correct stream format prevents drop-outs on legacy hi-fi tuners.
• Radio 357 default codec: AAC-LC 130 kbps [Elektroda, krokodylowy, post #19174572] • New MP3 fallback: http://n05a-eu.rcs.revma.com/an1ugyygzk8uv (128 kbps) [Elektroda, krzsiek, post #19291562] • Data use guide: ~1 MB/minute at 128 kbps [Elektroda, Polon_us, post #19381305] • Grundig 7WEB accepts only MP3/WMA/RA; AAC fails [Elektroda, Polon_us, post #19169600] • vTuner update cycle: up to 2 months [Elektroda, Polon_us, post #19185339]
Why does Radio 357 not play on my Grundig Cosmopolit or 7WEB?
These models decode MP3, WMA or Real Audio only. Radio 357’s default AAC stream is rejected, so you must add the new 128 kbps MP3 URL manually or wait for vTuner to list it [Elektroda, Polon_us, post #19169600]
Can I use Bluetooth instead of internet streaming?
Yes. A Logitech Bluetooth Audio Adapter or Audiocast M5 feeds any amplifier; setup takes under 2 minutes and circumvents codec issues [Elektroda, miroz2, post #19169793]
Why does the stream pause every few minutes on my Tchibo radio?
The unit buffers poorly with AAC. Switching to the MP3 link solved stutters for several users [Elektroda, slyt44, post #19162797]
vTuner lists Radio 357 but my receiver shows only 32 kbps—normal?
Some Pioneer and Denon models down-report bit-rate when metadata is absent. Actual audio remains 128 kbps; no quality is lost [Elektroda, Krzysiu50627, post #19206396]
What is an edge case where Radio 357 still fails?
HK 3770 receivers lack AAC and reject long-token revma URLs; even the MP3 link may need a firmware patch not yet released [Elektroda, duszysko, post #19185203]
Quick 3-step fix for ‘Connection Error’ on TV set-top boxes
  1. Open radio list, switch to RADIO rather than TV channels.
  2. Navigate to position 570 (Radio 357 on Canal+ decoders) [Elektroda, Kris2711, post #21197686]
  3. Save to favourites for faster access.
Is there an official response from Radio 357 about adding more formats?
Listeners report no email replies; patrons on Facebook were told MP3 is ‘old technology’ but one 128 kbps stream was finally added in March 2021 [Elektroda, patsi2, post #19227146]
How can I monitor app data use on Android?
Settings → Apps → Radio 357 → Data usage shows per-hour consumption; tests logged ~65 MB/hour at 128 kbps [Elektroda, miroz2, post #19384828]
