Radio 357 - problem with programming stations on the internet radio
Manix62 29052 83
How can I add Radio 357 to my internet radio if the provided stream link does not work, and is there another stream address I can use?
The main issue is the stream format: Radio 357 originally broadcasts in AAC (about 130 kbps), so many older internet radios and some vTuner receivers cannot open it [#19174572][#19296069] The thread’s practical workaround is to add the station manually in vTuner via “Add station” after logging in [#19162840] A working relay stream shared in the discussion is `http://stream.open.fm/378?type=.aac`, and some users also report success with `http://stream.open.fm/378` or `http://stream.open.fm/378?type=.mp3` depending on the receiver’s supported formats [#19163210][#19481535] Later, a direct MP3 128 kbps link was also posted: `http://n05a-eu.rcs.revma.com/an1ugyygzk8uv` [#19291562] However, older Pioneer N-30/50 models still may not work with the revma links because they cannot handle the redirect mechanism, so in that case the thread suggests Bluetooth/AirPlay or a newer receiver [#19296069]
  • #61 19382863
    Polon_us
    Help: 1184
    Rate: 1280
    miroz2 wrote:
    Maybe you know how to check the bit rate with the 357 radio application on android?
    Unfortunately, I do not know. Maybe colleagues from the department -> GSM
  • #62 19384711
    miroz2
    I checked it yesterday and the radio 357 application on androd used about 100 MB of transfer within an hour.
  • #63 19384716
    Polon_us
    Help: 1184
    Rate: 1280
    Could a friend write how it was measured?
  • Browser test to compare Radio 357 data transfer
    #64 19384738
    miroz2
    Before trying, I checked the transfer status on the account, turned off wifi, turned on the radio 357 application on android for an hour.
    Then I switched to wifi again and today I checked my account and it came with 100MB, that's it.
    At the moment, I did the same, but I opened the 357 radio in the browser on the smartphone and tomorrow we'll see if it has downloaded as much as the application or it will be different.
  • Android app data usage can reveal background transfers
    #65 19384778
    Polon_us
    Help: 1184
    Rate: 1280
    I understand the concept. But I guess you have to take into account that other applications may run in the background and download their data. And that will add to the transfer.
    A friend could check one more thing on the phone. I was tired of this issue, this data transfer, and I got acquainted with Android on my phone. To my surprise, there is information about data transfer for individual applications.
    You can find it under -> Settings -> Applications -> About applications -> (select 357 from the list) -> Data transfer.
    I use Android (version 10) in the English version and I hope that what I wrote above is roughly similar to what my colleagues see on their phones in Poland.
  • Android app data usage shows about 65 MB per hour
    #66 19384828
    miroz2
    Yes, you are right that other applications running in the background interfere with the reading a bit, but I already have a reference.
    Better if the reading is a bit overstated than low.
    I checked on android 10 in the settings of the radio 357 application and showed wear
    transfer about 65MB during this hour, also I already have some idea. Thanks.
  • #67 19384839
    Polon_us
    Help: 1184
    Rate: 1280
    miroz2 wrote:
    and showed wear and tear
    about 65MB transfer during this hour, I already have some idea
    I didn't make a mistake too much in my bills :)
  • #68 19384861
    miroz2
    I already know how to use internet radio while away from home, in the car and on the road.
    Thanks.
  • Radio 357 stream fails on website and app
    #71 19786816
    izabelaburchacka
    Hello, my problem is a bit different, but it also concerns radio 357, so I hope that one of you devoted listeners will help me. I would like to receive radio 357 simply on their website using a computer and in their application using a phone, as I do with radio Nowy Świat, unfortunately it does not work at all ... it used to be terribly torn, now it does not turn on at all. I use TUNEin but I would like to see what's going on etc. you know :) I admit that it prevents me from becoming a patron of this radio as well ... Let me add that I live in Portugal, but I have a good connection and never had any problems with other sites or applications. Thank you in advance for your help! Regards, Iza
  • Links to Radio 357 streams for computer listening
    #72 19786927
    Polon_us
    Help: 1184
    Rate: 1280
    @izabelaburchacka - in this topic there are a number of addresses for receiving the 357 radio. I mean computer reception. Just click on this address. In the two preceding entries, addresses for this radio are given.
    And you can view the other entries, and you will find more addresses.
    But that's only for listening, not from their side.
    Please check that these addresses are working properly.
  • #74 19788107
    izabelaburchacka
    Thank you, as I mentioned, I can listen to the radio on my computer, e.g. using TUNEIn, but I would like to hear from them, why it doesn't work, that's my problem :) Greetings!
  • #75 19788113
    ksu7
    Help: 63
    Rate: 144
    What operating system? What web browser? You need to clean the browser cache folder https://bit.ly/32OXdUE, which you use according to me.
  • #76 19788475
    izabelaburchacka
    Thank you so much, I will keep trying !! Safari browser, OS X El Capitan system. Greetings
  • Winamp and streamripper still work on W7
    #77 19788715
    olaf x
    Help: 257
    Rate: 363
    I do not use the player on the radio website or their patronity website, although it always worked for me. Since I have the W7, the streamripper works on it, apparently not on the higher ones. Once upon a time I found a link and downloaded the icon to the desktop, after clicking on it, the winamp radio opens and the streamripper cooperating with it opens, I can listen and record. But after reading the topic, I tried the radio player and it doesn't work for me now. Maybe something they got excited about?
  • #79 19788762
    olaf x
    Help: 257
    Rate: 363
    ksu7 wrote:
    or maybe just from another site, it will play without a problem, for example with https://myradioonline.pl/radio-357
    It works for me :) I will continue to use winamp + streamripper to record, but this link is working :)
  • Clarifying that TuneIn works but station page does not
    #80 19789078
    izabelaburchacka
    Thanks guys, but I repeat once again that I have no problem listening to the 357 radio itself, I use TUNEin and it works great BUT it doesn't work for me on the radio page where it's easy to access the program, to podcasts, it's just correct and comfortable I think that it is not normal that it does not work for me ... if someone had a similar problem and managed to solve it, or at least find out the reason, I will be grateful!
  • #81 19789507
    Polon_us
    Help: 1184
    Rate: 1280
    Then you should install another browser on this MAC. The description clearly shows that the Safari browser is messy.
    From what I have seen on the Internet - Chrome is the first browser for MAC - behind the dedicated Safari of course.
    Another option would be to "clean" Safari as mentioned earlier, or reinstall Safari.
  • Chrome fixes Safari-related Radio 357 programming issue
    #82 19789999
    izabelaburchacka
    Thank you so much Polon_us, correct answer, I have installed Chrome and 357 is flying! Hooray !! I'll start patronizing soon :) )) It's strange that I didn't think of it myself, I always had several browsers, trust in Mac fogged my view ;) Regards xxx
  • #83 21197600
    elzbietaglab
    I was receiving radio357 and radio new world from TV, today 357 is not working - connection error? I reset the router... I am almost 80 years old.... what can I do myself?
  • #84 21197686
    Kris2711
    What signal source do you have - cable TV, satellite TV ?
    If you have a Cyfra decoder, then
    Radio 357 is not among the TV channels but among the radio channels at position 570.
    Use the remote control to set:
    Menu - Radio - Polish Internet Stations - 570 Radio 357
The discussion revolves around issues with programming Radio 357 on various internet radios. Users report difficulties in receiving the station using the provided stream link, with some successfully adding it through vTuner or by manually entering alternative stream addresses. Several users mention that Radio 357 broadcasts in AAC format, which is not compatible with all receivers, particularly older models. Suggestions include using Bluetooth transmitters or alternative streaming methods. Some users have found success with specific stream links, while others continue to experience connection errors. The conversation highlights the need for compatible streaming formats and the importance of updating receiver firmware to resolve these issues.
TL;DR: 128 kbps MP3 streaming burns ≈60 MB/hour [Elektroda, Polon_us, post #19381305]; “works already” when the right URL ends in “.mp3” [Elektroda, Ensa44, post #19169990] Use direct MP3 links or vTuner’s “Add Station” to fix silent radios.
Why it matters: Correct stream format prevents drop-outs on legacy hi-fi tuners.
• Radio 357 default codec: AAC-LC 130 kbps [Elektroda, krokodylowy, post #19174572] • New MP3 fallback: http://n05a-eu.rcs.revma.com/an1ugyygzk8uv (128 kbps) [Elektroda, krzsiek, post #19291562] • Data use guide: ~1 MB/minute at 128 kbps [Elektroda, Polon_us, post #19381305] • Grundig 7WEB accepts only MP3/WMA/RA; AAC fails [Elektroda, Polon_us, post #19169600] • vTuner update cycle: up to 2 months [Elektroda, Polon_us, post #19185339]
Why does Radio 357 not play on my Grundig Cosmopolit or 7WEB?
These models decode MP3, WMA or Real Audio only. Radio 357’s default AAC stream is rejected, so you must add the new 128 kbps MP3 URL manually or wait for vTuner to list it [Elektroda, Polon_us, post #19169600]
Can I use Bluetooth instead of internet streaming?
Yes. A Logitech Bluetooth Audio Adapter or Audiocast M5 feeds any amplifier; setup takes under 2 minutes and circumvents codec issues [Elektroda, miroz2, post #19169793]
Why does the stream pause every few minutes on my Tchibo radio?
The unit buffers poorly with AAC. Switching to the MP3 link solved stutters for several users [Elektroda, slyt44, post #19162797]
vTuner lists Radio 357 but my receiver shows only 32 kbps—normal?
Some Pioneer and Denon models down-report bit-rate when metadata is absent. Actual audio remains 128 kbps; no quality is lost [Elektroda, Krzysiu50627, post #19206396]
What is an edge case where Radio 357 still fails?
HK 3770 receivers lack AAC and reject long-token revma URLs; even the MP3 link may need a firmware patch not yet released [Elektroda, duszysko, post #19185203]
Quick 3-step fix for ‘Connection Error’ on TV set-top boxes
  1. Open radio list, switch to RADIO rather than TV channels.
  2. Navigate to position 570 (Radio 357 on Canal+ decoders) [Elektroda, Kris2711, post #21197686]
  3. Save to favourites for faster access.
Is there an official response from Radio 357 about adding more formats?
Listeners report no email replies; patrons on Facebook were told MP3 is ‘old technology’ but one 128 kbps stream was finally added in March 2021 [Elektroda, patsi2, post #19227146]
How can I monitor app data use on Android?
Settings → Apps → Radio 357 → Data usage shows per-hour consumption; tests logged ~65 MB/hour at 128 kbps [Elektroda, miroz2, post #19384828]
