Integration of the Sonoff SV with the Satel CA6: Concept, security and relay minimisation
grabar123 1266 5
  • Proposed Sonoff SV integration using OC alarm output
    #1 19201724
    grabar123
    Welcome colleagues
    I have this thought on the integration of sonoff with sateel ca6 and since I am not an electronics engineer I would like to know if I am thinking correctly and if I have forgotten anything in this solution ;)
    I have uploaded supli software to the sonoff sv with thermometer and open sensor and isolated the relay output. I'd like to get an alarm notification so I figured I'd power the sonoff from the control panel and connect the opening sensor input via a low current OC type output on the control panel and program it as an alarm. The sonoff output will be connected to the control panel input and programmed as an arming/disarming mode. What do you think of this solution? Do you see any weaknesses in the protection against some kind of overvoltage? I know I could do it with external relays, but I would like to keep the number of them to a minimum.
    Regards
  • Using an OC output as alarm input feedback
    #2 19202199
    Rysiek2
    CCTV and Stationary Alarms specialist
    Help: 447
    Rate: 659
    Aside from the obvious disadvantage of (in my opinion) exposing your system to the network, there is one more,
    that you don't have feedback on the status of the control panel when it is remotely armed/disarmed. In my opinion, a 'bowel'.
    grabar123 wrote:
    I will connect the opening sensor input via a low current OC type output on the control panel and program it as an alarm.
    Do you only have one alarm input?
  • #3 19202295
    grabar123
    Yes, there is only one in the sonoff, besides, it is an alarm on the plot and I care most about the remote deletion of the alarm after checking on the cameras that it is only a mouse.....a not to digress at night 120 km so that the neighbors can send. :-)
  • Sonoff powered from panel with OC alarm input
    #4 19202415
    Rysiek2
    Help: 447
    Rate: 659
    grabar123 wrote:
    I am most interested in remote alarm reset after checking on the cameras
    It makes all the difference that the system status indicator could be an LED in the camera range controlled from an output like an arming indicator.
    grabar123 wrote:
    Yes there is only one thing in sonoff,
    So I didn't really understand how you plan to connect it?
    grabar123 wrote:
    I will power the sonoff from the control panel and I will connect the opening sensor input via a low current OC type output on the control panel and program it as an alarm.
    I thought you were referring to the input on the control panel and not on the Sonoff
  • #5 19207787
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    Instead of the Sonoff, you can use, for example, the Wemos D1 mini board where more GPIOs are available for use. Instead of relays, optoisolators can be used. Please note that no more than 3.6V can be applied directly to the GPIO esp82xx
  • #6 19213318
    grabar123
    I have ordered and will be testing ;) .
