[Solved] Connection of FAAC 740 limiters to Sonoff SV and integration with Satel CA6
krisb10 3354 5
  • #1 18397667
    krisb10
    Drive faac 740 + sonoff SV
    1. what software to upload to make the two limiters work.
    2. how to connect to the original limiters
    The limiters on the 748D control panel drive board are given a supply of 18.5V, the current flowing in the active state is short-circuited to ground with 20mA (relays are out).
    Is it possible to connect these limiters directly to the IO inputs. ESP8266 The maximum current that can be drawn from a single GPIO pin is 12mA.
    Theoretically using a 30K resistor the maximum current at this voltage would be under 10mA. The theoretical voltage does not matter as long as it is above the high state.
    If this solution does not work then I would consider using a PC817 optocoupler but separating the circuits with a common ground?
    similar problem
    Using sonoff sv for notification, control panel satellite (CA6).
    Central on low current outputs puts out 10.85V shorted to ground in inactive state,
    1. what should I upload in order to be able to receive notifications from as many inputs as possible and to control the outputs.
    Is it possible to separate the inputs in this case too.
    Unless you have other ideas for wifi notification from CA6 control panels.
    Notification .
    Please see tutorials, featured topics, articles, on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on. Security Systems
    If you do not find an answer to your question in the above topics, please visit the forum:
    We also encourage you to visit the General Guides section, where you will find material from the other sections of the forum, including for those starting out in electronics:
    General Guides.
  • #2 18397985
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    krisb10 wrote:
    1. What software to upload to make the two extremities work.
    I don't understand the question. Please elaborate a bit on what you want to achieve.
    krisb10 wrote:
    2. How do you connect to the original endcaps
    Similarly here. I don't know for what purpose to connect the sonoff' to the curbs?
    krisb10 wrote:
    The theoretical voltage doesn't matter as long as it is above the high state.
    Voltage does matter and I would rather not connect anything that has more voltage than Vcc+0.5V.
    An optocoupler is recommended as much as possible.
    krisb10 wrote:
    What to upload so that you can receive notifications from as many inputs as possible and also control the output.
    No matter what, because it will still be a sculpture. I recommend Tasmota for everything. Almost everything can be realised on Tasmota. In combination with Node-red it is also possible to integrate almost everything.
    Of course, there are also alternatives such as ESPeasy, Espurna. There is also Arduino with dozens of projects.
  • #3 18398211
    krisb10
    I want to be able to control the gate with wifi. The limiters give me information about the status of the gate. I have some undisciplined users in the house who leave the gate open all day and the auto close option is not an option, small children. Equally they forget to switch on the alarm. I was thinking of supli Gate to sonoff safe voltage
  • #4 18476745
    sjotka
    Have you solved the problem? I have the same controller and wonder if it will hulk with the PC817? What resistor did you put in front of the PC817?
  • #5 18476890
    krisb10
    I have solved
    Finished module from PLN4 Connection of FAAC 740 limiters to Sonoff SV and integration with Satel CA6
    into sonoff sv uploaded supla converted by SLAVEK from the supla forum.
    input
    On IO 4 - into the extremity of the FAAC 740 drive connected via PC817.
    (when it reaches the cut-off it puts the gate to power in the other it short-circuits to ground, etc)
    IO 5 - into the FAAC 740 drive limiter connected via PC817.
    IO14 - thermometer for the beeper
    Inputs set to 5k high for 3.3v supply
    PC 817 - diode side 2.9k for 24v
    Supla shows gate status (3 states)
    temperature
    Opens closes, tests - all for PLN20 and an hour's work,
    • sonof sv brama supla.rar (306.48 KB) You must be logged in to download this attachment.
  • #6 18476906
    krisb10
    Connection to SATEL identical as for the gate
    closing
