Alternatives for the double WiFi busbar relay with signal switching
faber 924 1
  • Need a double relay with low-current signal switching
    #1 19217211
    faber
    Help: 49
    Rate: 36
    I'm looking for a way to make a double box relay however with signal switching, exactly like the sonoff mini has (GND + GPIO). From what I have found all double are phase switched. I need to control this with a micro switch with a load capacity of 0.05A/24V.
    The Sonoff mini is ideal but it is single.
    From what I have read e.g. Shelly 2.5 has GPIO leads but from what I have found they are connected under N and cannot be used during normal operation.
    Do you have any advice ? two sonoff mini's i can't squeeze in....
