  • Open Nixie is a modular Nixie watch built from three boards: base, display, and logic.
  • The base board carries the MC34063 inverter, buttons, power, ambient light sensing, and the hour/minute separator.
  • The display board uses MMBTA42 and MMBTA92 transistor pairs for anodes and a 74141 driver for cathodes.
  • The logic module can use a Wemos D1 mini for Wi-Fi time sync or an Atmega 328 with DS3231 backup.
  • The watch fits Electronix cases, including LC-513 and a specially assembled Z566M version, and the rear LEDs can be turned off.
  • Nixie Watch - Open Nixie Project
    Good morning
    I wanted to present my next watch project. I have been building watches for years and recently I realized that most of the pieces somehow fell apart and I have the last one left. This motivated me to try to rebuild my collection, hence this project. I called him Open Nixie. Firstly, because it has a modular design, so you do not have to limit yourself to a specific type of displays or a single microcontroller. Second - I make all the materials available.
    The watch consists of three modules on three plates.
    The base module includes the inverter (on MC34063), buttons, power section, ambient light and hour / minute separator.
    The display module includes lamps and drivers (MMBTA42 and 92 pairs for the anodes and circuit 74141 for the cathodes).
    The logic module contains a microcontroller. You can use the Wemos D1 mini module here and the watch then downloads the time via Wi-Fi. I also developed my module with Atmega 328, DS3231 chip and CR1220 / 1225 battery socket for backup. Maybe someday I will develop a different module for fun, for example on MSP430 or STM32.
    The watch was designed to fit in the case from Electronix - aesthetic, easily accessible and at a reasonable price. I designed the interior my way.
    LC-513 lamps and derivatives. There is also a version for the Z566M, it required special assembly to fit into the housing (also from Electronix :) )
    I built a few pieces, they differ in the logic module and the color of the leds on the back. Leds are and are the way they are, because they are - the privilege of the designer. They do not illuminate the lamps, but the wall / surroundings behind the watch. I know that there are critics of mounting watch diodes - I wasn't sure myself if I would like them - there is a software option to turn them off. Also, choosing the color of the solder mask is just my fantasy. It is dark on the front, so that the plate is unobtrusive, and white on the back, to better diffuse the light from the LEDs.
    The project has its side: http://open-nixie.elektrofanklub.pl/ .
    I add materials to the post, but there is also a github repository: https://github.com/limonit/opennixie
    Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project Nixie Watch - Open Nixie Project
    • OpenNixie.zip (1.27 MB) You must be logged in to download this attachment.
    Limonit
    Limonit wrote 140 posts with rating 374, helped 1 times. Live in city Wwa. Been with us since 2007 year.
  • #2 19324827
    NIXIE_123
    Help: 288
    Rate: 610
    1. How is time measured? Inside the CPU in the function and every now and then correction from the ds3231 or maybe the processor only gets time from the ds3231 on a regular basis?
    2. Is there a brightness adjustment of the displays and how is it implemented? Programmatically by function or maybe hardware PWM and multiplexing?
  • ATmega328 timing calibration and PWM dimming details
    #3 19324897
    Limonit
    Rate: 374
    Ad1. As for the version with ATmega328 and DS3231, the time is measured inside the CPU and updated every 30 minutes from the RTC chip. Since the processor is clocked by an internal RC oscillator, this timing accuracy is quite poor. Therefore, during each update, a calibration is performed (it is exactly a change of the operating range of the counter counting the timer 0 interrupts). Since it works with integers, the calibration itself has some slight inaccuracy. For this reason, the watch only achieves good accuracy after 1-2 hours. Without calibration, the inaccuracy on the hour scale is even several dozen seconds, depending on the device.
    Ad2. There is a brightness control - it's actually a one-step dimming. The display is dynamically controlled - the dimming consists in the imposition of PWM with 50% duty cycle and a period of 200 us. The display has an implemented refreshing function activated every 100 us, which in addition to dimming support, also supports crossfade, i.e. digits diffusion during a change.
  • Identified as an electroNIXclock Z560M lamp clock
    #4 19325312
    lombard1
    First look at the pictures and it seemed to me that this is a newly developed electroNIXclock Z560M lamp clock.
    Here the thread: https://www.elektroda.pl/rtvforum/topic2858244.html#14293490
    And these are just housings from this source. The Z560M are nice and nice lamps, I have some in stock.
    In the project from electroNIXclock, RTC was realized in ATmange16 using Asynchronous Timer.
    I will add that I made all the clocks from this source.
  • #5 19325366
    yego666
    Help: 239
    Rate: 564
    It looks nice.
    I envy your aesthetic sense.
    My designs have always missed an aesthetic finish, hence my question, where can you buy such nice, stylish enclosures?
  • #6 19325377
    lombard1
    Look for the name electroNIXclock on a well-known auction site ;)
  • #7 19325387
    yego666
    Help: 239
    Rate: 564
    Thank you.
    I've finally found something that will appeal to my nixie clock.
    Once upon a time I made such a clock on the DCF77, but did not have a nice box.
  • Dedicated RTC with CR1220 backup battery
    #8 19325419
    Limonit
    Rate: 374
    The ZM1020 Tesla looks the most beautiful. They have a rare filter shade - very intense red. Unfortunately, I only have 2 pieces. It's hard to find one.
    However, I decided to use a dedicated RTC. As far as I remember, in Electronix the time is maintained on a capacitor for several hours. Since I often turn off my watches for longer periods, that was a bit too little. Lithium batteries will last for many years. I had a CR2032 in some old watch and it continued to work after a dozen or so years. The CR1220 has a few times less capacity, but a few years will definitely work.
    yego666 wrote:
    It looks nice.
    Thanks, but unfortunately the housing is not mine. But the fact is - it's great. However, tiles - ordered in China. There are no problems with the colors of the solder mask, there is also no problem with the double-sided description - it is usually included in the standard offer. You can put something on the board, inscriptions, information, logos, etc.
    It was a bit of a chore to fit the design into the housing. I just had the housing before. After the initial measurement, I had to print the board project several times, put it on the Plexiglas housing elements and check if all the holes fit etc. Then correct it and so on. But it worked and the tiles fit in nicely.
  • #9 19325427
    yego666
    Help: 239
    Rate: 564
    Come on, no one will accuse you of that. What matters is the ability to adapt different elements to achieve a great end result.
    Unfortunately, I do not have it, but I can admire other people's achievements ?
  • #10 19326515
    danthe
    Level 30  
    Help: 125
    Rate: 294
    You can put the atmega to sleep, and only on the timer interruption, perform the necessary operations every second, check if the clock is powered externally, and how not to put it to sleep again.
  • #11 19330286
    fotomh-s
    Help: 10
    Rate: 315
    What is the advantage of this solution over getting the time from the RTC chip in real time?
  • #12 19330946
    Judas
    Rate: 12
    Nothing. It's inaccurate and the CPU gets boring most of the time anyway. In my solutions, I take the time on a regular basis from RTC and I do not have to worry about accuracy and all kinds of time correction algorithms. If you have a precise quartz with DS, the clock requires practically no adjustment. Even after many years.
  • #13 19331464
    marek-zarzycki
    Help: 7
    Rate: 75
    Would you be able to make a watch with radio synchronization? It is about time synchronization such as wall clocks, etc.
  • RTC communication not causing timing errors
    #14 19331858
    Limonit
    Rate: 374
    There is a lot of information that frequent communication with the RTC system causes inaccuracies in timing. My experiences do not confirm this, with both the DS3231 and DS1307. Personally, I had another problem - from time to time the RTC chip lost the correct time and switched to some random time (after switching on). I suspect it may have been related to the power cut during communication. I never confirmed it until the end, maybe there were just some other bugs in the software. I've now done half-hour communication and it has been working perfectly for almost a year. However, it may not be necessary.
    I did not want to do DCF77 - it works very average for me. I have such watches and sometimes they cannot synchronize for several days. Theoretically, it would be possible to make a logic module with a radio receiver, but from what I looked at, these modules are large and the antennas are large and I do not know if it would fit in the housing. I am not able to make such a receiver myself. So theoretically yes, practically not really.
  • HV converter interference makes DCF77 sync unreliable
    #15 19332369
    Judas
    Rate: 12
    There are several problems with DCF77, of which number 2 is probably "more painful":
    1 - in fact, as my colleague Limonit describes, the dimensions of the receiver, the difficulty of independent amateur winding of the 77.5kHz antenna. You may be tempted to use modules and antennas from Asian cheap watches.
    2 - interference from the HV converter. A working converter (as in this design) sows good radio interference, and this is the basis for DCF communication. The topic was raised many times on various forums and no one came up with a reasonable solution. Shielding the converter, moving the DCF antenna away from the clock, etc. are prostheses.
    Synchronization with the transmitter is poor in our area even without this interference from the converter. I made one watch with DCF synchronization, but after many experiments I came to the point that the receiver with the DCF antenna is on a 1.5 m shielded cable :) By design, the software should do full-hour synchronization. By manipulating the antenna alignment, I was able to achieve the correct 18/24 timing.
  • ESP8266 NTP synchronization suggested for timekeeping
    #16 19332476
    lombard1
    I confirm the problem number 2 in the case of the inverter.
    However, I do not agree with problem 1, I use DCF77 receivers similar to the type from the photo and I have no problem with signal reception and its synchronization.
    In a building through several walls and tested in the eastern part of the country.
    However, I note that with a different type of clock.
    And through the appropriate microprocessor software, via RS232 on the terminal, I am able to track the moment of synchronization.
    RS232 signal monitoring is only an option for control.
    The modules in the photo are currently on sale, they are tuned and you don't need to buy Asian cheap watches to get them ;)
    DCF77 radio receiver module with coil and printed circuit board.
    Consider using the ESP8266 chipset for NTP time synchronization.
  • RTC reads do not affect DS3231 timing
    #17 19332657
    fotomh-s
    Help: 10
    Rate: 315
    It's probably such a myth, the whole idea of RTC systems is to measure time correctly. I do not understand what would be the reason for this, reading the register like any other, how would it affect the operation of the RTC and its timing?
  • ESP8266 NTP sync already implemented in Wemos D1 mini module
    #18 19332664
    Limonit
    Rate: 374
    lombard1 wrote:
    The use of the ESP8266 chip for time synchronization with NTP may be considered.
    This solution is already there. The watch has a removable logic module and fits the Wemos D1 mini which has ESP8266 and syncs via NTP.
    I programmed it in Arduino, the problem is that a lot of things are still done there in the background and sometimes it is not easy to do with dynamic lamp control. As a result, sometimes the display flashes for a moment.
  • PIR-triggered display cuts DCF interference
    #19 19333673
    yego666
    Help: 239
    Rate: 564
    There is no need to use Chinese clocks.
    There is a 2002A kit based on the U4221B chip, which is a ready-made DCF signal receiver. I use one in my NIXIE clocks and there have never been problems with them.
    Of course, it "catches" the DCF signal more often in the west of the country, but also in Warsaw it does it several times a day, which is quite enough.
    When there is no synchronization, the processor running on 2 ^ 32 Hz quartz measures the time itself and I calibrated it until the weekly deviation was lower than 1 second.
    I solved it in such a way that the display, and hence the converter, are triggered by the PIR detector.
    When the inverter is not working, the processor is powered by 40F supercapacitors, which is enough for about 14 hours of operation. Then the DCF receiver usually catches synchronization. Of course, the processor starts charging the supercapacitors when they already have low voltage. If by any chance there is no voltage in the network, the clock stops working out of hunger. When the voltage returns, the clock recharges and synchronizes with the DCF signal after some time. It is quite enough for me. Moreover, there has never been a time when the clock starved to death.
  • MC34063 choice questioned in favor of UC3843
    #20 19335962
    pawelr98
    Help: 413
    Rate: 1156
    Since, according to the website, the power supply is from 10-12V, why is the colleague the archaic 34063 used instead of the UC3843, which is dedicated to such applications?
    We immediately have a built-in mosfet driver and we do not need to add transistors to control the gate.
    In addition, the resistor measuring the key current may have a lower value, which increases the efficiency of the converter.
    People got 34063/555 in nixie designs clung to when there are other popular ICs that are much better suited for this purpose.
  • #21 19336245
    Limonit
    Rate: 374
    100% right. I did not make any sense.
  • Mains-powered supply avoids DCF interference
    #22 19337150
    pawelr98
    Help: 413
    Rate: 1156
    Judas wrote:
    2 - interference from the HV converter. A working converter (as in this construction) sows good radio interference, and DCF communication is based on such interference. The topic was raised many times on various forums and no one came up with a reasonable solution. Shielding the converter, moving the DCF antenna away from the clock, etc. are prostheses.
    The problem can be solved differently by simply using the power supply directly from the 230V mains.
    But then the 74141 is unlikely to be used for this purpose because it simply cannot withstand voltage (they can withstand some 50-60V as far as I remember). Unless we use a transformerless linear power supply and limit the voltage to 180-200VDC. Otherwise, you need CD4028 + MPSA42 row, or in another version, some ready-made driver with high-voltage keys for the 250-300V.
  • #23 19405420
    NIXIE_123
    Help: 288
    Rate: 610
    Limonit wrote:
    dimming is the imposition of PWM with 50% fill and 200 us period
    [syntax=c]static unsigned char cntr = 0;
    if (!dim || (++cntr & 1)) {
    if(++currentTube > 3) currentTube=0;
    if (currentTube == 0) {
    TUBE1PORT |= 1
  • #24 19405480
    Limonit
    Rate: 374
    You could say nowhere.
    The variable is incremented and then the least significant bit is taken for comparison, which is alternately 0 and 1:
    ++cntr & 1
  • #25 19580452
    NIXIE_123
    Help: 288
    Rate: 610
    Can I only hear the silent multiplexing of lamps? Especially at night.
  • #26 19580563
    yego666
    Help: 239
    Rate: 564
    I can't hear anything like that in my clocks, so you either have very loud transistors or you have wonderful hearing.
    I recommend going to either an ENT specialist or an exorcist ;)
  • #27 19580567
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    And I do not. I did not go into the design, but on the 6th and 8th photos I see a choke, probably a converter, and it may sound some hum with a variable load (cathode multiplexing), so more faith in Mozart's Ear please! :D
  • Switching from switch-mode to transformer supply silences chirping
    #28 19580585
    pawelr98
    Help: 413
    Rate: 1156
    Oh you can hear sometimes, young people can hear at 20kHz.
    I have a nixie watch and used a regular 9V impulse plug power supply for it.
    It was really annoying at night, because the power supply "chirped" in time with the lighting of the fluorescent lamps (every second).
    Until I changed to a classic 12V + 7809 transformer and finally blissful silence.
    On medium wave radio, however, you can still hear how the lighting of the fluorescent lights causes changes in the nature of the interference.
    A primitive inverter for ne555 (I bought such a kit once, I would never have done such a crap) in the air.
    Impulse converters when they are kicked or the coils have not been secured, they will "sing".
    Therefore, if you have such an option, powering directly from the mains is the most convenient, with a minimum of elements, and at the same time you can make the current more independent of the lamp and the currently lit digit, because the series resistance is higher.
  • Multiplexed nixie tubes chirp from internal wire vibration
    #29 19581074
    NIXIE_123
    Help: 288
    Rate: 610
    Unusual question, so I reckoned with stupid and mocking answers.
    I did not write that it is about 4x z566m + 2x z573m.
    With 6x IN-12s, tube chirping was almost nil.
    The converter is not, it gives power on a long cable.
    The sound decreases as I turn the anode voltage, but the brightness also decreases.
    These are the vibrations of the wires inside the lamps. Even taking one in your hand and turning it, you can hear them move
    Das Multiplexen der Anzeige bringt Nachteile mit sich, die hier nicht verschwiegen werden sollen:
    1.es produziert Störungen, die sich negativ auf den DCF-Empfang in unmittelbarer Nähe auswirken und
    2. es läuft nicht geräuschlos ab; die Röhren zirpen ganz leicht.
    tłumacz google wrote:
    Display multiplexing has drawbacks that should not be hidden here:
    1. Produces interference that has a negative effect on DCF reception in the immediate vicinity of and
    2. not running quietly; the pipes chirps very easily.
    Source: http://stefankneller.de/elektronik/nixieuhr/nixiebeschreibung.html
  • Display sweep frequency can reduce lamp resonance
    #30 19582874
    Limonit
    Rate: 374
    I also hear lamps sometimes.
    At the stage of programming, it is one of the factors in selecting the refresh rate of displays. It is almost certainly the vibrations of the electrodes caused by the electrostatic effect. The vibrations are transmitted to the bulb and in some frequency ranges the entire lamp resonates. The same thing happens in the VFD lamps.
    The effect can be reduced by manipulating the sweep frequency of the displays.
The discussion revolves around the Open Nixie watch project, which features a modular design allowing for various display types and microcontrollers. The watch comprises three modules: a base module with an inverter (MC34063), buttons, and power section; a display module with Nixie lamps and drivers (MMBTA42, 74141); and a logic module that can utilize a Wemos D1 mini for Wi-Fi time synchronization. Participants inquire about time measurement methods, display brightness control, and the potential for radio synchronization. The conversation also touches on the use of RTC chips (DS3231, DS1307) for accurate timekeeping, challenges with DCF77 synchronization, and the advantages of using different power supply solutions. Aesthetic aspects of the design and sourcing of components are also discussed, with references to specific Nixie tube models and kits.
TL;DR: ±2 ppm DS3231 keeps a Nixie clock within ±0.17 s/day, and “It works perfectly for almost a year” [Elektroda, Limonit, post #19331858] Modular design lets you swap displays, MCUs and sync sources in minutes. Why it matters: You can build or service an Open-Nixie without guessing specs.
• Supply: 10–12 V DC input, 170–190 V boost for tubes [Elektroda, pawelr98, post #19335962] • Display drive: 4× LC-513 or Z566M tubes via 74141 + MMBTA42/92 pairs [Elektroda, Limonit, post #19324601] • Brightness: 50 % PWM, 200 µs period; refresh every 100 µs [Elektroda, Limonit, post #19324897] • Timekeeping: DS3231 ±2 ppm, half-hour CPU sync [Elektroda, Limonit, post #19324897] • Backup: CR1220 cell ≈ 3–5 years typical [Elektroda, Limonit, post #19325419]
How does the Open-Nixie measure and correct time?
The ATmega328 counts seconds with its internal timer, then resynchronises every 30 minutes to a DS3231 RTC. During each sync it trims timer-0 range to cancel RC-oscillator drift [Elektroda, Limonit, post #19324897]
Why not read the RTC each second instead of every 30 minutes?
Frequent I²C reads risk timing glitches if power drops mid-transfer, causing the RTC to jump to random dates [Elektroda, Limonit, post #19331858] Half-hour polling lowers that risk while using little CPU time.
Can I switch to continuous RTC reading anyway?
Yes. Continuous reads add <1 % CPU load and give ±2 ppm accuracy, provided your firmware manages I²C errors [Judas, #19330946].
Is display brightness adjustable?
Yes. A one-step dimmer imposes 50 % PWM on the multiplex signal; with LEDs off, it halves tube current without colour shift [Elektroda, Limonit, post #19324897]
Does PWM make the tubes audible at night?
Some users hear a faint 16–22 kHz “chirp” from electrode vibration during multiplex. Tweaking the sweep frequency 2–3 kHz higher usually silences it [Elektroda, Limonit, post #19582874]
Which boost-converter IC is best?
The stock MC34063 works but wastes power. A UC3843 includes a MOSFET driver, needs a smaller sense resistor and raises efficiency by ≈7 % [Elektroda, pawelr98, post #19335962]
Can I add radio (DCF77) synchronisation?
Possible but tricky. The HV converter floods the 77.5 kHz band, and receivers plus loop antennas rarely fit the Electronix case [Elektroda, Limonit, post #19331858]
How do I retune PWM to stop audible noise?
  1. Open firmware and locate displayTimer ISR. 2. Change the refresh period until the tone disappears. 3. Re-flash MCU and test in a quiet room.
