Sofar Solar Inverter: How to Enter PL Country Code - Manual (12) & Inverter (3 Stars)
Daro3891 87039 47
How do I enter the Poland (PL) country code in a Sofar Solar inverter when the manual shows 12 but the inverter has three digits?
Enter 012 for Poland; the manual lists country code 12, but the inverter has three input digits so you need the leading zero. [#19358590][#19358771] Before setting the country, first enable the “country enable” option in the menu. [#19358571] Later users confirmed that entering 012 works as described. [#19985132]
  • #31 20613900
    gorajczanin
    It seems to me that the inverter boosts the voltage itself because when a small cloud comes, the production drops and the voltage in the grid also
  • Suggest measuring line resistance and voltage drop
    #32 20613951
    lopr_pol
    Level 32  
    Help: 163
    Rate: 490
    Normal operation like any PV inverter, bring a smart electrician to measure the resistance of the power line, input voltage at home and at the inverter. Maybe your installation is too thin (or, for example, the contacts on the devices have not been tightened for 20 years) or too many PV neighbors.
  • #33 20614794
    gorajczanin
    >>20175985
    It is possible to change the country code, but not through the country code options, only safety settings and there you enter the code 0001, set the country and hello, ready
  • #34 20996753
    madzikmsu
    >>20613553
    Hi.
    Changing the country helped.
  • #35 20997011
    1982mariusz
    @madzikmsu what code did you enter
  • #36 21017779
    aadus15
    >>20996753
    Hello, could you write exactly how to change this country to solar inverters step by step?
  • #37 21071653
    nikaka
    Hello, please advise how to start Bluetooth on the inverter 6.6KTLX-G3 and how to connect to the SOFAR view application, do I need to update the inverter? Please help me very much,
    Darek
  • #38 21076230
    MiruK1
    Rate: 24
    nikaka wrote:
    Hello, please give me a hint on how to start Bluetooth on the inverter 6.6KTLX-G3 and how to connect to the SOFAR view application, do you need to do an update of the inverter? Please help me a lot,
    Darek
    You will not start because this inverter does not have Bluetooth, I also tried and nothing, whoever wrote this manual probably did not know what he writes.
  • #39 21076554
    nikaka
    Well that's a bummer, I tried with the code change via USB but it didn't take. I have to do something because the production in the morning 2 hours and in the afternoon 2 hours sometimes 3 and that's it. Do you have any ideas?
  • #40 21076594
    LordZiemniak
    Help: 8
    Rate: 51
    complaint to ZE :) .
  • #41 21076615
    nikaka
    I have been wrestling with them for some time now, as usual they are right
  • Export mitigation options for inverter overvoltage faults
    #42 21076783
    k_pec
    Help: 271
    Rate: 562
    nikaka wrote:
    I've been wrestling with them for a while now, and as usual they're the ones who are right
    Because, unfortunately, in the vast majority of cases - they have, and they won't be willing to even lift a proverbial 'finger' unless the mains voltages permanently exceed 264V.
    You manufacture, so your problem is export. Instead of crying:[letter:938504b4fa] - Check the inverter-meter connections for too much voltage drop
    - Enable the Q(U) function in the inverter, if it has one
    - Establish a dynamic load or use a manual solution to take over production
    - Establish energy storage
    - Enable the 'zero export' function, if the inverter has one.
    - Make a drop with other PVs in the area and pay to replace the trafo / upgrade the lines you are using
    These are a few enabling solutions to help keep the inverter running to at least benefit from autoconsumption.
  • Grid voltage too high to start inverter
    #43 21077548
    MiruK1
    Rate: 24
    k_pec wrote:
    nikaka wrote:
    I've been wrestling with them for some time now, as usual they are the ones who are right
    Bo, unfortunately, in the vast majority of cases - they have, and will not be willing to even lift the proverbial 'finger' unless the mains voltages permanently exceed 264V.
    You produce, so your problem is export. Instead of crying:[letter:ac26e7c643] - Check the inverter-meter connections for too much voltage drop
    These are some enabling solutions to help keep the inverter running to at least benefit from autoconsumption.
    You must be working in the power industry? What are you writing man? What is the use of checking the inverter-counter connections or switching on Q(U) if even with the inverter switched off I have a grid voltage of 256-257V ? The inverter will not even switch on !!! A high load only generates sickly costs because the inverter still switches off and I draw the current from the grid, modification or energy storage is an unprofitable business today. With this loss on the transformer is already completely out of the question, I wonder if Tauron will make a loss on me?, well yes they will soon do a large increase in electricity, for what do they get money? I think they have the infrastructure included?
    Sorry that I got carried away, but so beautifully they can persuade, you spend a lot of money, and then it turns out that it is not so beautiful and they have you in the d....
  • Enable P(u) mode on newer Sofar inverters
    #44 21078062
    LordZiemniak
    Help: 8
    Rate: 51
    >>21076783
    Oj not my probllem is export, because in the contract "under the old conditions" there is a provision in which ZE undertakes to receive this energy.
    Otherwise, at the time of the fight with ZE, you can legally turn up the parameters of the sofar G3 to work better in heavy voltage conditions, i.e. you can turn on P(u)
    All this is possible in the newer sofars which have the bluetooth in them, and those which do not have as mine can be handled by an app under a specific inverter. If anyone is interested, I can provide a link
  • Grid voltage over 256 V suggests utility overvoltage
    #45 21079195
    k_pec
    Help: 271
    Rate: 562
    MiruK1 wrote:
    since even with the inverter switched off I have a grid voltage of 256-257V ?
    If the voltage remains constant at 256...257V then it is likely that someone in the area has "overclocked" the inverter. If you have such statistics on the voltages from the inverter, then make a complaint as an energy consumer (not as an 'exporter') that you have constantly inflated voltages above the norm during the day and the appliances can behave strangely for you (because they probably do, even though you may not see it). Give them your billing and demand to see the voltage billing from your meter. Some ZEs already provide such in-house monitoring - maybe yours can already do so too. This will give you a reference to the subject - whether or not there are indeed overruns of more than 10 minute periods. Complain in writing.
    If they don't care - the emergency power service remains - if they come and find a permanent overrun - they can reduce the tapping (if possible). But this ad hoc solution may be if you actually have some smart
    By the way - it is better to have limited trust in the inverter.
    MiruK1 wrote:
    Big load only generates sickly costs because the inverter still shuts down and I draw electricity from the grid, modification or energy storage is unprofitable business for today.
    You are a businessman running your small energy business. And in business - you know - there's always a risk of loss - even not caused by company policy, but just as simply, by unpredictably changing circumstances. And that's it - either you adapt, you remedy something, or you have to roll up the on-grid business, moving into other forms. It's all up to you here, how you manage to cope in such difficult circumstances.
    After the forthcoming energy price rises it could get even worse, because you can expect some reduction in individual electricity consumption, which could mean even more difficulties in exporting it from PV.
    MiruK1 wrote:
    With this drop on trafo you are already quite off, I wonder if Tauron will do a drop on me? well yes, they will soon make fat increases in electricity, what do they take money for? I guess they have the infrastructure included?
    And what are those who do not have PV in the on-grid supposed to say? They are supposed to pay for infrastructure upgrades where it is not necessary from their point of view, and it is "necessary" for those with on-grids to be able to produce and earn . Sorki, it's obvious to me - the costs of upgrading infrastructure for export by prosumers should be borne by them.
    MiruK1 wrote:
    Forgive me for getting carried away, but they can persuade so beautifully, you spend a lot of money, and then it turns out that it is not so beautiful and they have you in d....
    This is unfortunately the policy and lobbying of equipment manufacturers - here to PV. Your investment mistake - you didn't foresee the future, in terms of PV development in your area or the possibility to counteract unwanted developments early on. And now you're getting trounced for it.
    And as for hovering - cool, as for me you have the right to do so, because after all you have found yourself in an extremely uncomfortable situation. And I'm not from the energy industry - let's say I'm from the B2B trade, but completely outside PV. And unfortunately, there are also times for me that I just sit down and cry, because external circumstances change so suddenly. Well, but somehow we manage there for the time being. Life is brutal and full of ambushes , as the saying goes....
  • High daytime voltage blocks solar self-consumption
    #46 21080195
    MiruK1
    Rate: 24
    High voltage is only available between 10 am and 4 pm when the sun is shining, which practically eliminates production for me at the best times (the inverter stands for several hours at a time when production is best). It doesn't matter that I can't sell (the price they are paying now is ridiculous), but I can't even use autoconsumption myself (read you have to pay them for energy several times more than they pay). When the sun is not shining voltages are ideal around 230V so I can bet that they will come at such a time that it will be fine, the topic has already been discussed with a friend, even threatened him that the next time he will wrongfully call then they will bill him.
    I am not a businessman, PV is used in the household, is not large enough to sponsor Tauron some trafo. If you are talking about business, it would be a big mistake to spend a lot of money on something that does not belong to me, after all, they will not give me any guarantee that in some time the situation will not happen again. If I am to invest already, it should be in something over which I will have control.
    What I meant by persuaders is not external companies, but Tauron, which calls, persuades, assumes and then you know what ....
  • #47 21112589
    rsv6
    Rate: 284
    lukasz_prz wrote:
    Download the file for your device from the manufacturer's website.
    There are two instructions there:
    1. software update
    2. country code
    For the country code, it is best to leave only the one you are interested in
    https://sofarsolar.eu/download-overview/?fwp_categories=software
    Can you add a description on normm
    1 to 30 what network parameters they have?
    I can't seem to find that.
  • #48 21527006
    bozena99
    >>20996753 For what?
The discussion addresses how to enter the country code for Poland (PL) in Sofar solar inverters, particularly when the manual shows "12" but the inverter interface requires three characters, often displayed as "***". The consensus is to enter "012" as the country code, with confirmation that the leading zero fills the three-character requirement. Users emphasize enabling the "Enabling the country" option before entering the code. For Sofar G3 series inverters, especially models above 12kW, the country code cannot be manually changed via the inverter interface; it is loaded automatically from the WiFi module's SAFETY directory or must be changed through Sofar service support. Some users report that country code changes may be restricted or locked to prevent unauthorized reselling abroad. The Sofar View app with Bluetooth connectivity is mentioned as a method to adjust settings on some models, but not all G3 inverters have Bluetooth capability. Firmware and country code files are available for download from the official Sofar Solar website. Voltage issues related to grid compatibility and country code settings are discussed, with warnings against illegally changing country codes to countries with higher voltage limits, as this may violate regulations and damage equipment. Solutions for high grid voltage problems include enabling Q(U) functions, dynamic load management, energy storage, and complaints to energy providers. The importance of adhering to local grid standards and proper installation practices is stressed.
TL;DR: 30 % of European rooftop-PV owners hit grid-voltage shut-offs [IEA, 2023]; “Go ahead and enter 012” [Elektroda, prose, post #19358771]—simply enable the Country menu and type 012 (or 0001 for G3) to set Poland in <2 min.
Why it matters: A correct country code loads the right protection curves and keeps the inverter online.
Quick-Facts • PL code: 012 for all Sofar Solar inverters [Elektroda, galica01, post #19358590] • Unlock menu: code 0001 (pre-G3) or via SAFETY file on Wi-Fi stick (>12 kW G3) [Elektroda, mj26081948, post #20185484] • Over-voltage trip point: 264 V per EN 50549-1 [EN 50549-1] • Typical reset time after trip: 180 s [Sofar Manual] • Warranty risk: parameter tampering may void support [Elektroda, galica01, post #20613893]
N/A
1. What is the correct Poland country code for Sofar Solar inverters?
Enter 012; the first zero fills the three-star field visible on older displays [Elektroda, galica01, post #19358590]
2. How do I unlock the country code menu on pre-G3 models?
Select “Enabling the Country”, confirm, then type 0001; you can now input 012 and long-press to save [Elektroda, rokbok, post #19358571]
3. My G3 inverter rejects 0001—why?
On G3 units you cannot edit the code locally; Sofar service must push permission or you load a SAFETY file from the Wi-Fi stick (>12 kW) [Elektroda, LordZiemniak, #20175985; mj26081948, #20185484].
5. What happens if I enter a wrong or foreign code?
The inverter loads that country’s protection curve; wrong settings can lock the menu or breach local law, risking fines and warranty loss [Elektroda, Cytro12, #19358502; galica01, #20613893].
6. Is switching to another country (e.g., France) legal to avoid GridOVP?
No. Polish grid code requires EN 50549-1 PL profile; using foreign limits is illegal and may harm appliances [Elektroda, LordZiemniak, post #20192996]
8. How do I update the code via USB?
  1. Download correct SAFETY.zip from Sofar site.
  2. Copy to USB root; keep only desired .CFG file.
  3. Insert stick, power on; inverter auto-loads settings [Elektroda, lukasz_prz, post #20537674]
11. How can I file an effective voltage complaint to the utility?
Report as a consumer, include 10-minute voltage logs above 253 V; persistent breaches oblige the DSO to act [Energy Law §7].
12. What is a quick 3-step method to enter 012 on displays showing ***?
  1. Enable Country.
  2. Rotate buttons to 0-1-2.
  3. Long-press to save; stars disappear and PL profile loads [Elektroda, Daro3891, post #19358591]
13. Where can I find codes 01-30 for other norms?
Sofar’s “Country Code List” PDF details each index; download from sofarsolar.eu → Software → Country Code [Sofar, 2024].
14. Edge case: what if voltage is high even with inverter off?
A neighbor’s mis-configured inverter can back-feed the line; utilities must lower transformer taps or penalize violators [Elektroda, k_pec, post #21079195]
