Smart Home - A universal system for your new home: Fibaro vs Home Assistant
afgi82 4350 15
Should I choose Fibaro or Home Assistant as the basis for a reliable, versatile smart home in a new house, and can Fibaro connect third-party Wi‑Fi or Z-Wave devices?
If you want the broadest future flexibility, Home Assistant is the better base; Fibaro is a more commercial ecosystem that works well, but it keeps you much closer to Fibaro’s own stack [#19365828][#19365936] Fibaro can still connect third-party Wi‑Fi/Ethernet and Z-Wave devices, especially when there are ready-made templates/plugins or when the device uses an open protocol that you can control with LUA or by parsing its web interface [#19365936] The trade-off is that Home Assistant gives you integration with many devices from many companies, but you must manage updates, automations, and troubleshooting yourself, while Fibaro is easier to install and more “supported” as a commercial product [#19366733][#19368434] For a new build, the thread also suggests considering wired or mixed commercial systems such as Grenton, Ampio, Loxone, KNX, or Deimic if you want something more structured from the start [#19366733][#19366326]
  • Fibaro supports third-party Wi-Fi and Z-Wave devices
    #1 19364528
    afgi82
    Hi
    I am building a new house. I would like to choose a system that is reliable but also quite versatile. I am not an electrician, but I can program. However, I would like the application to be operated by my wife. I also want to be able to develop and connect new devices in the future, not necessarily from the same company.
    I would like to connect everything I need at home: garage door, cameras, underfloor heating, sprinklers in the garden, lighting in the garden, weather station, etc.
    I was thinking of Fibaro or Home Assistant.
    P.s. Can I connect third party devices operating via wifi or z-wave to Fibaro?
  • #2 19364543
    sosarek
    Help: 9320
    Rate: 15539
    Well, haven't you thought about basing it on an alarm system?
    Z
    Pka, Poznań, 60-850
  • #3 19364551
    afgi82
    I don't know if I understood correctly, but yes, of course. An alarm system in the broadest sense would fit in as well.
  • #4 19364563
    sosarek
    Help: 9320
    Rate: 15539
    So even on such an Integra you are able to create the logic responsible for the aforementioned functions.
    Z
    Pka, Poznań, 60-850
  • #5 19365828
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    By choosing Fibaro you are condemning yourself almost exclusively to Fibaro. If you choose Home Assistant as the basis, then you integrate with almost everything.
  • Fibaro supports third-party Wi‑Fi and Z-Wave devices
    #6 19365936
    GanzConrad
    Help: 67
    Rate: 203
    nonsense, you can even integrate modules based on ESP
    From what I found out, quickly, about home asistant:
    https://en.wikipedia.org/wiki/Home_Assistant
    I conclude that comparing it to Fibaro makes absolutely no sense.
    Fibaro is a commercial product, while HA is only hobby software.
    I would sooner compare HA to domoticz , open hub etc.
    Yes, both.
    Quite a few third party devices already have templates/plugins ready in Fibaro (wifi/eth).
    Smart Home - A universal system for your new home: Fibaro vs Home Assistant .
    As for Wifi/Eth: if the device in question has an open communication protocol then you can write a program (LUA) to control it or use ready-made plugins (pioneer, denon, TV sat "n" etc).
    You can parse the web page of some service or device and extract the necessary data from the HTML code and then use it. (e.g. wind speed from a weather station located on a ring road/highway).
    The first question you should ask yourself is whether it should be cheap in cash but expensive in your own man-hours (hobbyist project), or more expensive to buy but peace of mind when it comes to reinventing the wheel (commercial product).
    Have a look at other commercial ones:
    - Fibaro (you can buy a control panel + a few modules even without installation and decide on further development)
    - Grenton (wired and wireless modules, supposedly good in terms of later development)
    - Ampio - I don't know the details
    - Deimic (wired only and requires every point and design to be thought through at the house building stage)
    -blebox
    - supla
    and many others
    and as I mentioned hobby:
    - domoticz
    - open hub
  • #7 19365977
    xury
    Help: 878
    Rate: 1498
    Nonsense.
    I wrote "almost exclusively".
    Fibaro with its integration base can at most clean HA's shoes. And you can do cheaply and just as fast similar to a commercial system. And even with non-standard integrations you need to work with Fibaro.
    It is also possible to go into KNX, which is difficult and very expensive - who can forbid a rich person from doing so?
  • Fibaro offers working support and custom integrations
    #8 19365979
    GanzConrad
    Help: 67
    Rate: 203
    and is it possible to do heating schedules on this?
    or select a channel on the t.v. or change the volume/source on the receiver?
    or connect a humidity sensor, light intensity?
    xury wrote:
    Nonsense.
    As I wrote: comparing the two systems is pointless. I'm not going to get into the system crap because I don't know HA, but what would you recommend to someone who calls a repairman when their light doesn't work?
    xury wrote:
    And with custom integrations this and with Fibaro you have to sit down.
    just like with any other, but it is possible.
    With ordinary scenes you also need to sit down and test, but you have a system that works, and if something does not work, you have a phone call to service and support in Polish.
  • Asking about Home Assistant integration and reliability
    #9 19366197
    afgi82
    I'm looking for something well tuned, with a good app and reliable. Something to which I can also easily connect the control of underfloor heating and garden irrigation.
    I can lay cables at this stage, but ultimately mesh is the ideal solution in my opinion. I wouldn't quite want to rely on wifi alone, as it may or may not work.
    In addition, I can handle some intermediate programming, but not much electrical.
    Therefore, from what I found out on the internet, I think Fibaro is the optimal solution, it allows for trickiest programming, but is developed enough to be easily integrated with other devices.
    Has anyone had experience with HA?
  • Fibaro modules allow easy rewiring and relocation
    #10 19366326
    GanzConrad
    Help: 67
    Rate: 203
    Under these assumptions, I would go for some kind of commercial system: you outsource everything you don't do yourself or don't like, and play around with reconfiguration and programming. The only time a problem might arise is if you want to make a claim/warranty, and the contractor will know that it has been "rummaged around".
    Fibaro has the advantage that it requires practically no adjustments to the wiring and even if you want to resign from some point or lighting, you dismantle the module and install it somewhere else, and the previous point will operate without control - the old way.
    Apart from that, Fibaro can be used like a cable system: by mounting modules in a switchboard on a DIN rail. (using a star topology in the wiring).
    I've always wanted to delve a little deeper into grenton, as it is supposedly wired/wireless, but somehow the time is not there.
    On the other hand: if you are at the construction stage and able to plan everything, and finances are not a key parameter then you might consider Deimic: it will come out cheaper on a single point, because you buy "in bulk". Extensions are possible, but quite expensive because they don't have single output/input modules on offer. Unfortunately, in recent days prices in construction have gone terribly crazy and cables have become more expensive, so this aspect is starting to be significant.
  • Commercial smart home systems versus Home Assistant tradeoffs
    #11 19366733
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Of the commercial ones, you still have, for example, Ampio, Loxone, Grenton, KNX. They can be distributed, central, radio and mixed systems. You can, for example, do part of the installation in a star and install the devices in a switchboard, part of it connected by bus and installed in boxes, part of it connected by radio. There are training videos on the Grenton/YT website - you can see what is available, how to connect, configuration, automation, etc.
    HA is an open system - this has advantages and disadvantages. The advantage is that you can use multiple devices, multiple companies. When it comes to wired devices there is not much choice. For that you have Zigbee and thousands of devices from different companies (in Mesh topology), Wifi, z-wave. But you have to control it yourself. You don't know what surprises an update might bring. If there is a problem - you solve it yourself. There is an app, but without a fixed external IP it costs money (Nabu Casa) or you need e.g. DuckDNS (which can be unreliable - if e.g. the IP changes you lose access).
    Personally, I wouldn't choose Fibaro.
  • Alarm system should be the automation backbone
    #12 19367193
    sosarek
    Help: 9320
    Rate: 15539
    GanzConrad wrote:
    sosarek wrote:
    Well haven't you thought of basing it on an alarm system?
    and is it possible to do heating schedules on it?
    or select a channel on the TV or change the volume/source of sound on the receiver?
    Well, what's the point of changing the channels if they take everything out of the house because you base the whole house on toys without thinking about securing it?
    The author's assumptions i.e.
    afgi82 wrote:
    I would like to connect there generally what is needed in the house: garage door, cameras, underfloor heating, sprinklers in the garden, lighting in the garden, weather station
    can be integrated with the alarm system and managed remotely - the rest are typical gadgets, but the basis should be a well-chosen and configured alarm system which will take over some of the automation.
    Z
    Pka, Poznań, 60-850
  • Smart home systems lack security certification
    #13 19367736
    GanzConrad
    Help: 67
    Rate: 203
    sosarek wrote:
    Well, what good is it to you to change the channels if they take everything out of the house because you base the whole house on the toys without thinking about securing it?
    This is a fact and (I think) every 'smart home' manufacturer stresses: these systems have no security certification and should be treated as gadgets. Some manufacturers do a one-way integration with the alarm system: from the "smart home" you can arm the alarm (e.g. with the "I'm leaving" scene), but you cannot disarm it.
  • #14 19367770
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Integration of the BMS with alarms can range from unidirectional control panel - BMS (e.g. use of control panel in/out states) to bilateral (including disarming). With more automation, control panels are not the optimal choice - especially if you want to make changes yourself - the logic of control panels is not particularly intuitive.
  • Fibaro criticized for poor automation flexibility
    #15 19368409
    afgi82
    sk1977 wrote:
    There are training videos on the Grenton/YT website - you can see what is available, how to connect, configuration, automations, etc.
    Do you happen to know how this differs to Fibaro?
    sosarek wrote:
    Well, what's the use of changing the ducts if they take everything out of the house because you base the whole house on the toys without thinking about securing it?.
    I saw somewhere that in case of a break-in, Hubert saves the last hours automatically in the cloud
    Added after 1 [minute]:
    sk1977 wrote:
    Integration of the BMS with alarms can range from unidirectional control panel - BMS (e.g. use of control panel in/out states) to bidirectional (including disarming). With more automation, control panels are not the optimum choice - especially if you want to make changes yourself - the logic of control panels is not particularly intuitive.
    So what do you suggest is different?
    Added after 51 [seconds]:
    sk1977 wrote:
    Personally, I would not choose Fibaro.
    Why?
  • Grenton is mainly wired, Fibaro mainly wireless
    #16 19368434
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    afgi82 wrote:
    Do you perhaps know how this differs to Fibaro?
    dramatically :) . Grenton is primarily a wired system (central, distributed, mixed). Z-wave is complementary. Fibaro conversely - mainly wireless. Fibaro is easier to install - even by people who have not had much contact with the BMS., Grenton, Ampio, Loxone, KNX - here you need more planning, thinking - but the possibilities are completely different.
The discussion revolves around selecting a smart home system for a new house, comparing Fibaro and Home Assistant. Users express concerns about reliability, versatility, and ease of use for non-technical family members. Fibaro is noted for its commercial nature and ease of integration with third-party devices, while Home Assistant is recognized for its open-source flexibility and extensive compatibility with various devices. Users highlight the importance of a well-configured alarm system as a foundation for home automation. The conversation also touches on the potential for integrating devices like underfloor heating, garden irrigation, and security systems, with some users advocating for wired solutions like Grenton, Ampio, and KNX for more complex setups. The need for a user-friendly app and the ability to connect various devices without extensive programming is emphasized.
TL;DR: For new builds, “HA is an open system” and, with Zigbee’s thousands of devices, integrates many brands; you handle updates and remote access (paid Nabu Casa or DuckDNS). [Elektroda, sk1977, post #19366733]
Why it matters: New‑build homeowners comparing Fibaro vs Home Assistant get a clear path to reliable, expandable control.
What’s the best smart‑home base for a new build: Fibaro or Home Assistant?
Choose by time, budget, and support. Fibaro is a commercial, turnkey product. Home Assistant is hobby software, comparable to Domoticz or OpenHAB. Commercial systems give vendor support and less wheel‑reinventing. DIY platforms trade money for your time and flexibility. [Elektroda, GanzConrad, post #19365936]
Can Fibaro control third‑party Wi‑Fi and Z‑Wave devices?
Yes. Fibaro supports Z‑Wave and can integrate Wi‑Fi/Ethernet devices via ready plugins or custom LUA code. If a device exposes an open protocol or web endpoint, you can script it. Users even parse HTML to extract values for automations. [Elektroda, GanzConrad, post #19365936]
Should I base my smart home on an alarm panel like Satel Integra?
Often yes. Your listed functions—garage doors, cameras, heating, irrigation, weather—can integrate with an alarm and be managed remotely. Treat the alarm as the backbone, then layer “smart” features on top. This prioritizes security while still enabling convenience. [Elektroda, sosarek, post #19367193]
How does a BMS talk to my alarm—one‑way or two‑way?
Integration ranges from simple panel I/O status into BMS to full two‑way control, including disarming. As automation grows, alarm panels are not optimal logic engines. Their rule logic feels unintuitive if you plan to tweak it yourself. [Elektroda, sk1977, post #19367770]
Can my smart home disarm the alarm?
Often no. Some vendors allow only one‑way links from smart home to the alarm. You can arm from a scene, but cannot disarm for safety. These systems lack security certification and should be treated as gadgets alongside the certified alarm. [Elektroda, GanzConrad, post #19367736]
How do Grenton and Fibaro differ in practice?
Grenton is primarily wired (central, distributed, or mixed). Z‑Wave complements it. Fibaro is mainly wireless and aims for easier installation. “Fibaro is easier to install,” while wired systems demand more planning but unlock different capabilities. [Elektroda, sk1977, post #19368434]
Zigbee, Z‑Wave, or Wi‑Fi—what should I use for sensors?
For breadth, Zigbee offers thousands of devices across brands in a mesh topology. HA also supports Wi‑Fi and Z‑Wave, but you must manage the stack. Choose Zigbee for dense sensor networks; mix in Wi‑Fi or Z‑Wave as needed. [Elektroda, sk1977, post #19366733]
What wiring strategy fits Fibaro during construction?
You can centralize modules on a DIN rail in the switchboard and pull star‑topology runs. Fibaro needs minimal wiring changes, and you can reassign modules later. Remove a module and the old point can keep working in a conventional manner. [Elektroda, GanzConrad, post #19366326]
How do I add a third‑party Wi‑Fi device to Fibaro?
Use this 3‑step flow:
  1. Confirm the device exposes an open protocol or HTTP API.
  2. Install a ready plugin, or write a short LUA script for control and status.
  3. Test endpoints; parse responses (even HTML) to extract values for scenes. [Elektroda, GanzConrad, post #19365936]
How do I choose between a commercial system and a DIY platform?
Ask one question: cash now or time later. Commercial systems cost more but deliver support and stability. DIY platforms cost less in hardware but consume your time for integrations and upkeep. HA aligns with hobby platforms like Domoticz or OpenHAB. [Elektroda, GanzConrad, post #19365936]
What other platforms should I consider besides Fibaro/HA?
Ampio, Loxone, Grenton, and KNX are credible options. Topologies vary: distributed, central, radio, or mixed. You can combine bus wiring with in‑box devices and radio links. This lets you tailor reliability, latency, and expansion across your home. [Elektroda, sk1977, post #19366733]
Can I relocate Fibaro modules later without breaking things?
Yes. You can dismantle a module and install it elsewhere. The previous point can continue operating in the traditional way without smart control. This supports phased deployments during and after construction. [Elektroda, GanzConrad, post #19366326]
Is Home Assistant stable enough for non‑technical family members?
HA offers flexibility and supports many devices, but you own maintenance. Updates can introduce surprises that you must resolve. For reliable remote access, use paid Nabu Casa or accept DuckDNS limitations. Plan for occasional tinkering between updates. [Elektroda, sk1977, post #19366733]
Am I locked into Fibaro’s ecosystem if I start there?
Not strictly. You can integrate ESP‑based and other third‑party devices via Wi‑Fi/Ethernet when they expose open protocols. Fibaro also supports Z‑Wave and community/official plugins, which broadens device choices without replacing the hub. [Elektroda, GanzConrad, post #19365936]
