Inexpensive system to start with - Seemple/Homematic/Fibaro and others
Nix 5040 43
Will a low-cost wireless smart-home system based on Seemple/Z-Wave be reliable for a retrofit detached house with radiator heads, sensors, lighting, relays, valves, and cameras?
For this kind of retrofit, the thread points much more to Homematic/CCU than to a cloud-dependent starter system like Seemple/Fibaro: it can work without cloud, supports direct device-to-device communication, and CCU2/CCU3 still support older HM devices as well as HMIP [#18231299][#18232036][#18234281][#18238699] The Homematic IP Access Point is not a full controller: it only pairs/configures devices, connects to the cloud, and does not create scenes or freely control relay outputs, so boiler/relay logic needs a CCU2/CCU3 or a dedicated relay solution [#18235959][#18251849][#18242596] If you mix HM and HMIP, they can coexist on one CCU, but direct HM↔HMIP scenes do not work, so keep one protocol per room when a heating group must react directly [#18234281][#18260878][#18262343] Camera integration exists only in a limited way, and motion detection/RTSP support was described as problematic, so several replies recommend keeping cameras as a separate IP subsystem rather than making them part of the core automation [#18234674][#18235086] Smoke detectors work on their own locally; you mainly program the notification, not the alarm sound itself [#18347882]
Treƛć zostaƂa przetƂumaczona polish » english Zobacz oryginalną wersję tematu
  • Need for Z-Wave compatibility with thermostats and sensors
    #1 18231097
    Nix
    Help: 17
    Rate: 189
    I'm considering a low-cost smart home system to start with for a detached house and was interested in the Seemple system, on Z-wave technology.
    The house is already standing, no installation for a smart home, so only a wireless system comes into play.
    To begin with, I need:
    -control of the thermostatic radiator heads
    -motion camera
    -smoke detectors, opening detectors
    -motors/ infrared
    -lighting
    - it would be nice to have control of a valve ( with actuator ) something like this:
    https://digitalhome.co/zipato-valve-controller-inteligentny-kontroler-z,3,178983,37337
    Will the Seemple system pass the test ? It seems comparable to e.g. Fibaro (Home Center Lite control unit), and should in theory work with all supported
    z-wave components, but is it really so rosy ?
    kind regards Nix
  • Cloud-free HomeMatic chosen for offline reliability
    #2 18231299
  • HomeMatic CCU valve actuator support question
    #3 18231525
    Nix
    Help: 17
    Rate: 189
    I don't know the capabilities ( at the moment ) of any system.... I think a Z-wave based system does not work without the cloud, but z-wave is a popular standard I see and someone could confirm this.
    And what capabilities does HomeMatic have at a glance? And which control unit -CCU2 or perhaps CCU3 ?
    For example, does it have the option of controlling an additional valve actuator? Because, as you know, it controls thermostatic heads.
  • HomeMatic direct actor-to-actor communication advantages
    #4 18232036
  • #5 18232086
    sosarek
    Help: 9320
    Rate: 15532
    I'll put it this way - although Fibaro works on Z-Wave it has a closed protocol and doesn't work with other devices, as far as cameras are concerned only a few models used to work, as far as integration with Satel and DSC alarm system is concerned.
    I haven't moved in a year so maybe something has changed but I don't suspect too much.
    Z
    Pka, PoznaƄ, 60-850
  • Fibaro compatibility with third-party Z-Wave devices
    #6 18232607
    Nix
    Help: 17
    Rate: 189
    sosarek wrote:
    I'll put it this way - although Fibaro works on Z-Wave it has a closed protocol and doesn't work with other devices, as for cameras at one time only a few models worked, ...
    And what do you mean by "others" ? Does Fibaro work ONLY with Fibaro devices, it does not work with Z-wave devices from other manufacturers ? Or is it a lottery whether it works with a particular device from another manufacturer or not ?
  • Z-Wave interoperability depends on parameter support
    #7 18232732
  • Clarifying direct actuator communication and CCU3 compatibility
    #8 18234252
    Nix
    Help: 17
    Rate: 189
    Erbit wrote:
    ...Of significant advantages
    - it is the only system I know of that has the ability to communicate directly between actors. This means, for example, that by snapping a flicker radio it sends an action to the actuator bypassing the CCU.
    It has the possibility ... what do you mean "possibility" ? It just always communicates directly or does the user decide whether to communicate or not ?
    And could you write a little more about this system ? For example, what is the prognosis for
    software/system updates?
    Supposedly, the CCU3 works, for example, with 'normal' thermostatic heads of the old/old type and with the newer 'IP' type...? But is it possible to have several such heads and several newer ones in one system ?
  • Homematic direct device-to-device scene control explained
    #9 18234281
  • #10 18234593
    Nix
    Help: 17
    Rate: 189
    This I will ask specifically about camera operation.
    Do you have one connected? One with rotation in 2 planes?
    And a second question like this: The Homematic brand is also Eq-3.... will the system handle e.g. relay modules ( e.g. such a module of 12 digital inputs and 12 relay outputs) ?
  • #11 18234674
  • #13 18235086
  • #14 18235120
    Nix
    Help: 17
    Rate: 189
    Why do I need a camera... the system is intended to be versatile and multifunctional and is meant to control everything in the house :)
    When I am away, I want to see what is going on at home, and if the camera could detect movement (in an empty house, for example), it would be able to send an alert, etc etc etc.
    I do not want to have several control systems at the same time, I would expect just the integration of many functions in one system ...
    So what is the real situation with camera operation - is it supported or not?
  • #15 18235161
  • #16 18235688
    Nix
    Help: 17
    Rate: 189
    Erbit wrote:
    This is a serious mistake. What do you think will happen when you have everything in one and just happen to have the one and only 'fall'?
    I don't consider it a bug, much less a "serious" one ;-) ))))
    It won't be everything, but a few things as I wrote above.
    But back to the topic- what in general are the Homematic devices -central units and their capabilities ( in brief) ?
    I see that popular on the secondary market are HmiIP-HAP PBXs, which, although similar to CCU3 PBXs in terms of their external appearance, are completely different (and much cheaper) devices... what are these Homematic IP Acces Points worth? Do these Acces Points sit between the CCU2 and CCU3 in terms of capabilities? And are they from the UK market?
    This is what the individual units look like
    Inexpensive system to start with - Seemple/Homematic/Fibaro and others Inexpensive system to start with - Seemple/Homematic/Fibaro and others
  • #17 18235698
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    I, on the other hand, have decided that I am going to make my own home automation system at low cost. At the same time, I want it to be stable and for everything to continue to function smoothly in the event of a breakdown.
    Therefore, I decided to combine Integra 128, Domoticz, Node-Red, Influxdb, Grafana, Tasman, Espeasy, Espurna, Arduino, OpenWrt, RaspberryPI, Sonoff, Google Home. Cheap ESP8266 and ESP32 modules, or cheap Chinese Sonoffs, but reprogrammed with alternative software, are usually used as actuators.
    I try to make it so that even if the server with Domoticz goes down, the system still functions. The system is in constant production, but it works well.
    Currently I have, control of lighting, heating, gates, gate,TV, etc. using switches, smartphones, voice, and recently I have been working on using gestures using OpenCV.
    Measurements of temperature, pressure, humidity. PM measurement will also be coming soon.
    Autonomous decisions made automatically, that is so much more 'smart' than those pseudo systems for which 'smart' means being able to be controlled by a smartphone and some sort of schedule. Behind this is Domoticz, Node-Red, Lua. So far it has cost me something a little over PLN1,500, where the most expensive components are the miniPC and the RPi3.
    The most expensive part has been the time spent on it, but as it's also what I like to do it doesn't count.
  • #18 18235714
    Nix
    Help: 17
    Rate: 189
    @xury - I envy you, but it's unthinkable for me, if only because of the notorious lack of time.... I have to have something ready, which can be efficiently installed, possibly easily extended, and should work :) .
  • #19 18235959
  • #20 18238632
    Nix
    Help: 17
    Rate: 189
    I have done a bit of reading about the different systems and their UNreliability.... now I understand what you meant
    assuming, as a priority, that the whole system should preferably be from one manufacturer....
    Can you confirm( because I read that you have experience) that the reliability of Homematic is really recommendable ?
    Because I have read, for example, about the capriciousness of the operation of fibaro systems, e.g. that the radiator thermostat suddenly opens to the maximum, or that the smart socket has to be taken out of the contact and put back in (several times a day at intervals anyway), or that the smart lighting switch "hangs up".... If it's supposed to work like this, I thank you....
    In summary- what is the actual, empirical, not theoretical reliability of the system's operation ( I understand you now have a CCU#?) vs.
    other systems?
    Second question- the actuator for the homematic system valve.... I found one, quite cheap:
    https://www.reichelt.com/gb/pl/nap-281-d-230-...-p253457.html?&trstct=lsbght_sldr::228195
    But the problem is that it's a normally ( voltage free) closed valve, and I need the same one, but normally open
  • #21 18238699
  • #22 18238790
    Nix
    Help: 17
    Rate: 189
    I need this valve to control the distribution of the water flow in the central heating between the two circuits (the small and the large circuit, where the large circuit would heat at weekends and other trips with power limited only to the antifreeze temperature, and the small circuit constantly).
    The installation of the two circuits is not yet done, I am waiting for the expert.
  • #23 18238800
  • #24 18242545
    Nix
    Help: 17
    Rate: 189
    Erbit wrote:
    With electronic heads, I don't see the slightest point in making such a circuit.
    I am making a second ( small) circuit because I am simply attaching a part of the house previously heated in another way, not in connection with saving or with the planned automation.
    Erbit wrote:
    Do you have / intend to have underfloor heating?
    What do you fuel it with?
    I do not have underfloor heating at all and will not. I fire with a gas boiler
    single-function gas boiler, without water storage tank, Termet Ecocondens silver 20KW.
  • #25 18242555
  • #26 18242565
    Nix
    Help: 17
    Rate: 189
    Yes, I know I could stop at just the heads, without the valve, but
    I plan to put the valve on the "main" i.e. large circuit, not the small circuit.
    https://www.elektroda.pl/rtvforum/topic3624222.html#18231517
    Here is my thread on the valve issue
    The thing is, for this season I don't think I'll have enough money for 8pcs ( plus extra for small circuit) heads + smart system, so I'll probably end up with 1pc, max 2pcs heads, which I'll add to the future.
    smart, so I'll probably end up with 1pc, max 2pc heads, which I'll top up for next season....
  • #27 18242596
  • #28 18251821
    Nix
    Help: 17
    Rate: 189
    I think I will decide on the Homematic system (and it will probably be a cheap version of the AP control unit, mainly because there is a simple program to operate/configure it and my system will not be very extensive), so I have additional questions:
    -what is the difference ( practically ) between the heads - HmIP-eTRV-B, and HMIP-eTRV-2 ?
    The latter is more expensive, but in general all, all Hm "IP" type components will work in this system with AP ?
    When you wrote about the price of the heads-usages, did you mean the well-known in PL auction portal ( and usually auctions) ?
    -Wouldn't such an AP type control panel allow "freely" controlling a 1-channel relay/switch which could serve as an on/off controller for the central heating furnace ?
    Is it necessary to look for a "double" control unit such as the one linked above?
  • #29 18251849
  • #30 18255565
    Nix
    Help: 17
    Rate: 189
    Erbit wrote:
    Not so fast! What about the camera ?
    Well the camera I can get over possibly (read - install a regular IP, outside the system) because the original costs baaaaavery much....
    Erbit wrote:
    ... you have received a barrage of information but it seems to me that you do not understand what I wrote a
    I have written clearly and very much so:
    - HMIP-HAP is not a switchboard
    - HMIP-HAP only has the ability to configure devices and pair them with each other
    - HMIP-HAP does not have the ability to create scenes.
    Yes, a lot of information :) You're right, you wrote quite explicitly about this above, apparently in the sentence that "APs aren't even considered PBXs" - well you were right, but after reading some of the conrad instructions I decided that maybe it could be done after all....
    That is, it is the case that the AP is (simplistically) just an advanced programmer, yes, it supposedly controls the actors, but only through a pre-planned schedule, so in real time you can't even give it any, even the simplest, simplest, single command, let alone create scenes....
    And in conrad they write differently (these instructions are probably written by secretaries, or salespeople, humanists, not engineers, or even people with a technical education at the level of vocational school - and I do not mean to offend anyone here :) )))
    The question of naming a PBX vs an AP is apparently a minor issue, but the Polish conrad calls an AP a PBX, which is effectively misleading to a fresh, unfamiliar potential buyer. In addition (and perhaps above all), the Polish conrad "manual" contains so many generalities and vague, non-specific, imprecise and misleading data that your head hurts "....
    For example, conrad writes:
    - "Homematic IP - the next generation of the smart home". - this suggests that it's a development of older smart home systems, yet the system from AP shouldn't be called a smart home at all, as for me it's an automated programmable controller for heating and a few extras with remote programming.
    - "The AP connects your smartphone via the Homematic IP cloud to all Homematic IP devices and sends configuration data and app control commands to all Homematic IP devices. With Homematic IP, you can simply adapt your air conditioning solution to
    your personal needs anywhere, anytime."
    -Also a misleading description, because what about the fact that the system connects your smartphone to all devices, if you can no longer control them?
    But there is also an interesting fact in the aforementioned AP manual from conrad-according to the description
    "In the app, tap the room and then the recharge symbol or ... to activate the recharge function / "turbo" mode is more appropriate here.
    If this is the case, in this case it is a direct command issue, so in simple terms it is however the execution of a simple scene ?
The discussion revolves around selecting a low-cost smart home system, particularly focusing on the Seemple system based on Z-Wave technology, and comparing it with alternatives like HomeMatic and Fibaro. Users express concerns about the reliability and compatibility of these systems, especially regarding the integration of various components such as thermostatic radiator heads, motion cameras, smoke detectors, and valve actuators. HomeMatic is highlighted for its ability to operate without cloud dependency and direct communication between devices, while Fibaro is noted for its closed protocol limiting compatibility with non-Fibaro devices. Users also discuss the importance of having a reliable control unit, with mentions of CCU2 and CCU3, and the implications of using older versus newer components. The conversation emphasizes the need for a versatile system that can manage multiple functions effectively while considering future expandability and the potential for technological obsolescence.
