ESP8266 to Arduino Uno and USB-UART converter connections: TX to RX or TX to TX?
byash 1491 4
  • #1 19404698
    byash
    I am looking through the wiring diagrams of ESP8266 to Arduino Uno and ESP8266 to USB-UART converter. And I see that sometimes TX is connected to RX and sometimes also to TX . The same applies to the RX . I mainly see this when connecting ESP to Arduino. What is the relationship ie when TX to RX and when TX to TX . Does it have something to do with the Arduino reset to GND ?
  • TX must connect to RX, not TX to TX
    #2 19404750
  • #3 19404795
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    The bottom line is that if the voltage levels are compatible then you can go wrong at will and nothing will burn.
  • Uno board labels are swapped; ESP8266 labels are correct
    #4 19404826
  • #5 19404864
