[Solved] SUPLA SLW 01 - How to connect an additional LED strip without overloading?
mirko4 729 5
  • #1 21090844
    mirko4
    I wanted to attach an additional LED strip to the SUPLA SLW 01. Too much load and the controller goes into On/Off mode.
    What can be done to control more strips with one controller?
  • #2 21090893
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    Either an amplifier (if zamel has it), possibly a second, same module. or "do it myself" - four resistors + four transistors, some knowledge and work.
  • #3 21091420
    mirko4
    If I knew how I would be happy to do it.
    Does a colleague have a diagram of how this would work?
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    The easiest way to do this is to type "RGB amplifier" into the allego or google search and offers will appear : for 19 zloty 12A and twenty pair for 30A you don't even want to draw a diagram....
    If you have a problem connecting everything then write.
  • #5 21092026
    mirko4
    Thank you, the advice helped.
    The subject is now settled.
  • #6 21321314
    mirko4
    I purchased the suggested device
