Selection of ESPEasy software for the ESP8266 ESP-01 5V WiFi control relay module
unky 1689 4
  • #2 19473352
  • 5v relay conversion and firmware compatibility check
    #5 19474558
    starob
    Help: 128
    Rate: 137
    unky wrote:
    Is this module compatible with LCTech relays, e.g. this:
    I'm a bit confused about what with what?
    Generally the conversion from 12V to 5V involves replacing the relay with a 5V relay and shorting out the place marked R5 on the board - that's all.
    Maybe the 12V relay will work on 5V? - check.
    As for software, the two relays pictured have different procs (Nuwoton/STC) - so see which one you have and apply the appropriate soft. As they describe in the link about Tasmota.
