Integration of Somfy drive and Yoda roller shutter with Sonoff gateway - control via eWeLink
Ariel N. 3444 8
  • #1 19593438
    Ariel N.
    Rate: 62
    I have a somfy operator door and a yoda garage roller shutter. All on 433mHz remote controls with a variable code.
    Is there any way to rip the remote code to a bamka e.g. sonoff and control by ewelink? I have tried with a black sonoff and nothing :( .
  • #2 19596140
  • #3 19596262
    Ariel N.
    Rate: 62
    As far as the drive for the entrance gate is concerned, there are two contacts there whose short-circuit acts as an impulse from the remote control - I can deal with that.
    The roller shutter in the garage is on a YODA radio motor, I've been in touch with the vendor - blindsalu and apparently it's not possible to do the control over wifi. I'll take the cover off and see what's in there. There are 3 wires going inside, N F and Pe. It opens closes by remote control.
    I want to control everything from the ewelink app.
  • #4 19596408
  • #5 19596612
    Ariel N.
    Rate: 62
    This soldering into the remote control stays?
    Is there anything on ewelink apart from the sonoff 4ch pro that closes the circuit instead of releasing the phase?
  • #6 19597528
  • #7 19597588
    starob
    Help: 128
    Rate: 137
    Erbit wrote:
    Since Tasmota goes in there I'm sure Ewelink does too but you'll have to check.
    Only Ewelink cannot be simply "uploaded" and you have to buy a ready-made one titled "Sonoff voltage-free Wi-Fi relay switch".
  • #8 19597628
    Ariel N.
    Rate: 62
    I missed the word tension-free - thanks :) .
    I already know what to look for.
    As a curiosity I will say that the seller of the roller shutter offers me:
    DC315 transmitter which is supposed to copy the settings from the remote control. You do not program the transmitter into the roller shutter, but make a copy of the remote control into the transmitter. A remote control with a variable code.
  • #9 19610963
    Marek J.
    Help: 526
    Rate: 948
    Ariel N. wrote:
    The DC315 transmitter which is to copy the settings from the remote control. You do not program the transmitter into the roller shutter but make a copy of the remote control into the transmitter. remote control with variable code
    Either you have misunderstood something or change your dealer....
✨ The discussion revolves around integrating a Somfy operator door and a Yoda garage roller shutter with a Sonoff gateway for control via the eWeLink app. The user inquires about the possibility of copying the variable code from the 433MHz remote controls to a Sonoff device. Responses indicate that Sonoff devices typically support fixed codes, making it challenging to replicate the variable code. Suggestions include using a relay to short-circuit the control contacts for the entrance gate. However, the Yoda roller shutter, which operates on a closed circuit, may not be compatible with Wi-Fi control. The user learns about a DC315 transmitter that can copy settings from the remote control, but concerns about the reliability of the dealer's information arise.
