WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant
p.kaczmarek2 12540 7
  • The Tuya Smart WiFi Garage Door Opener Controller adds remote garage-gate control and an open/closed magnetic sensor by shorting the existing opener contacts.
  • Inside, the plastic case hides a CB3S module with BK7231N, an AMS1117 3.3V LDO, a relay, LED, button, and sensor connector.
  • The unit cost about PLN 80, and programming used only TXD1/RXD1 with a USB-to-UART adapter and a reset after more than 5 seconds.
  • OpenBeken replaced the cloud firmware, with P7 driving the relay, P8 reading the sensor, and a 2-second script returning the relay to open.
  • Home Assistant integrated the relay and sensor as switch, binary_sensor, and cover entities, but the gate was not tested on a real installation.
  • WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant
    Today, a slightly less typical device, namely the WiFi add-on for controlling the garage door. This device plugs into the existing garage door switch and allows you to remotely close/unlock the garage by briefly shorting the appropriate contacts (simulating a button press). In addition, it offers a simple magnetic sensor put on the gate to check whether it is open. That's all - but it's enough. It's time to see what's inside and change the firmware to free the product from the cloud and from the manufacturer's servers.
    Buying a gate controller
    I bought the product for about PLN 80. In my opinion, it is quite expensive and we pay more for its function than for electronics. DIY would be much cheaper. When I bought it, it was shipping from the Czech Republic and a slightly different price:
    Set contains:
    1 x Smart WiFi Garage Door Opener Controller
    1 x USB Charging Adapter
    1 x USB cable
    1 x Manual
    1 x Mounting accessories
    Photo of the set (according to the seller):
    assembly diagram:
    Promotional graphics:
    WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant WiFi garage gate controller, Smart Garage Opener Tuya - Home Assistant
    Actual Kit Contents:
    A short test with the Tuya application
    As a test, I paired the device with the manufacturer's application. I did the reset by pressing the button from the housing for more than 5 seconds.
    The video shows how it works:
    Basically, pressing the button on the housing (or controlling from the app) simply shorts the relay for a short while, simulating pressing the button of the proper gate controller. In addition, an animation appears in the application that the gate is opening, etc. The closing/opening sensor is also supported and is used to show the current state of the gate.
    The inside of the gate controller
    The plastic housing is held on by hooks. They hold quite solidly, you need to use some force when prying:
    Inside there is a CB3S module, i.e. BK7231N and programming signals.
    So you can upload OpenBeken .
    A quote from Tuya publicly available documentation:
    pin number Symbol I/O type functions
    1 RST AND Low-level reset, high level active (the pin has been pulled high internally), correspond to CEN of the IC
    2 ADC3 AI ADC pin, which corresponds to P23 of the IC
    3 PRICE AND Enabling pin, which is pulled high internally to be compatible with other modules
    4 P14 I/O A common GPIO interface, which corresponds to P14 of the IC
    5 P26 I/O GPIOP_26, which corresponds to P26 of the IC, PWM 5
    6 P24 I/O GPIOP_24, which corresponds to P24 of the IC, PWM 4
    7 P6 I/O GPIOP_6, which corresponds to P6 of the IC, PWM 0
    8 VCC P Power supply pin (3.3V)
    9 GND P Power supply reference ground
    10 P9 I/O GPIOP_9, which corresponds to P9 of the IC, PWM 3
    11 TXD2 I/O UART2_TXD (used to display the module internal information), which corresponds to P0 of the IC
    12 CSN I/O Production test control pin. If it is used as a common I/O pin, it must be connected to the VCC externally. Do not connect it to the ground before the module is powered on.
    13 P8 I/O GPIOP_8, which corresponds to P8 of the IC, PWM 2
    14 P7 I/O GPIOP_7, which corresponds to P7 of the IC, PWM 1
    15 RXD1 I/O UART1_RXD (user serial interface), which corresponds to P10 of the IC. Do not connect it to the VCC. By default, the MCU serial port should be in low-level or high-impedance state.
    16 TXD1 I/O UART1_TXD (user serial interface), which corresponds to P11 of the IC. Do not connect it to the VCC. By default, the MCU serial port should be in low-level or high-impedance state.
    17 ADC3 AI (Not recommended. If needed, please use Pin 2) ADC port, which corresponds to P23 of the IC. Programmed SPI
    18 P22 I/O (Not recommended ) GPIOP_22, which corresponds to P22 of the IC. Programmed SPI
    19 CSN I/O The pull-up resistor is needed during usage of customers. Do not connect it to the ground before the module is powered on. Correspond to P21 of the IC.
    20 P20 I/O (Not recommended. ) GPIOP_20, which corresponds to P20 of the IC. Programmed SPI
    21 NC - -
    22 NC - -
    I only use TXD1 and RXD1 for programming. But first we will see the rest of the PCB:
    Basically on the PCB we have:
    - LDO AMS1117 (gives us 3.3V for WiFi module with 5V)
    - small button and LED
    - connector for the button from the garage (with a relay, this relay shorts them and simulates pressing)
    - connector for gate opening/closing sensor
    The role of BK7231 pins:
    - P7 - relay (the one that turns on the right gate)
    - P8 - gate opening/closing sensor input
    - P24 - LED from the board
    - P26 - button from the board
    programming procedure
    Programming this particular BK7231 will be very simple.
    All you need is a USB to UART converter with 3.3V voltage levels. Solder three wires - ground, RX and TX.
    Then we run the program on the computer (bkWriter 1.60, or better, hid_download_py) and when you need to RESET the system, simply disconnect the USB cable from the connector on the board. We just reboot.
    Thanks to this, you do not need to solder this "BOOT" signal or an additional 3.3V LDO, because it is already on board.
    https://github.com/OpenBekenIOT/hid_download_py
    This is BK7231N, so we upload the QIO binary to offset 0. If it was BK7231T, we would upload UA to the default offset. As in OpenBK Readme.
    OpenBeken configuration
    First, set the pins, the ones I gave above in the table.
    We will assume that channel 0 controls the relay and channel 1 is the door status reading.
    The dInput input type used for the door sensor is simply digital input - it sets the given channel to the value taken from the digital pin.
    Then we do cosmetics - set the type of channel 1 as "OpenClosed" to display the status of the door in text (and not as a number):
    setChannelType 1 OpenClosed
    Then you should add something that, like the original firmware, will "disconnect" the relay back - so as to generate a short pulse. Just write a simple event handler in OpenBeken, all fully scriptable:
    addChangeHandler Channel0 != 0 addRepeatingEvent 2 1 setChannel 0 0
    When channel 0 changes its value to non-negative (then the relay will also close automatically), we start the 2-second timer with 1 repetition, after which we set channel 0 to 0 (this will open the relay).
    The above scripts should be entered in LittleFS in autoexec.bat or in "Short startup command" together with the backlog:
    backlog setChannelType 1 OpenClosed; addChangeHandler Channel0 != 0 addRepeatingEvent 2 1 setChannel 0 0
    that is here:
    It's also worth changing the name to something more meaningful:
    Home Assistant setup - step 1
    The first stage of configuration requires adding separately the relay control (as a switch) and the sensor reading (as a binary_sensor) to Home Assistant. We will use YAML code for this purpose. We have to remember what channels we assigned to given roles - here we receive them by the MQTT subject from get and set them by the MQTT subject from set. as below:
    Code: YAML
    The above Yaml defines a garage opening sensor. We only have "state_topic" from get here, which means we receive what OBK publishes.
    Now handling the relay:
    Code: YAML
    As above, only "command_topic" is added, i.e. a topic that allows us to send a new state of the relay to OpenBeken.
    The above Yaml should give us:
    The above sensor on the HA interface should react to a change in the state of the sensor on the device, as it should be possible to control the relay from the HA level!
    Home Assistant setup - step 2
    Now we will use the mechanism cover in order to connect our opening sensor and relay (scripted in OBK so that it returns to the open state after a while) into a whole.
    cover documentation:
    https://www.home-assistant.io/integrations/cover/
    Here is the finished code:
    Code: YAML
    What do you need to know here?
    - binary_sensor.garage_door_sensor_2 points to our garage sensor
    - switch.garage_relay points to our relay
    The same could be done with a regular relay (separately) and a door open/close sensor (separately).
    The above code only calls switch.turn_on because the relay disconnects itself afterwards (script Obk).
    Blocks with if allow you to choose the icon and the value of the gate.
    Home Assistant interface with garage door control.
    The stop button does nothing at the moment.
    Summary
    This device is really very simple - it's strange that it costs so much. It would be much cheaper to make a similar mechanism yourself, even on a cheap ESP8266.
    Changing the CB3S firmware also went without problems - as well as configuration in Home Assistant.
    Unfortunately, in practice (on a real gateway) I did not test the device, because I did not have access to such a luxury, but "dry" tests showed that after changing the firmware and with HA everything works. And if anything, you can always change the behavior of the software - even script it differently or organize the operation in Home Assistant differently.
    Does anyone on the forum have a garage door controlled by WiFi, and paired with HA?
    Feel free to comment.
    p.kaczmarek2 wrote 14794 posts with rating 12941, helped 659 times. Been with us since 2014 year.
  • #2 20302375
    noel200
    Help: 36
    Rate: 815
    At home, I connected Yunshan with esp8266 and uploaded supla to the bama drive.
  • #3 20316684
    uzi008
    Rate: 25
    I would like to ask if you played the original dunk and could you share it?
  • #4 20316695
    Rate: 12941
    @uzi008 I think I have the original batch, I'll look for it, and what do you need it for?
  • #5 20316711
    uzi008
    Rate: 25
    I would like to reprogram another device from the Tuya group with this batch and check if it will gain the same functionality.
    Because actually looking at the performance, as you said, you pay for the name
  • #6 20316757
    Rate: 12941
    Remember that this is a batch for BK7231N and it will not work with any other system ... do not upload it to BK7231T or ESP there.
    Let me know how it went, you can also show what exactly you program with it.
    Remember that you have to give the button and the rest on the same pins as mine. And also reset the system to pair with your Tuya application.
    • garage_door_opener_CB3S.zip (2.94 MB) You must be logged in to download this attachment.
  • #7 20316806
    uzi008
    Rate: 25
    I have such a thermostat
    There is also BK7231N, I have a batch from it, so I will replace it with the one from the gate.
    I will rework the layout a bit so that the pins match and there is a closure sensor instead of a thermometer. I will separate the relay from 230v to make it work as in your case and we'll see.
  • #8 20317139
    Rate: 12941
    @uzi008 ok good luck, if you have a moment, you can also take photos from the inside and describe this thermostat here as a separate topic, because I haven't seen it yet, and it would be worth adding it to the list of devices https://openbekeniot.github.io/webapp /devicesList.html
The discussion revolves around a WiFi garage gate controller that allows remote operation of garage doors by simulating button presses through existing switches. Users express interest in modifying the firmware to eliminate reliance on cloud services. One participant mentions using a Yunshan device with an ESP8266 and uploading custom firmware. Another user seeks to reprogram a Tuya device using the original firmware batch, emphasizing the importance of compatibility with specific chipsets like BK7231N. There are plans to adapt a thermostat with similar components for garage door functionality, including a closure sensor and relay modifications.
TL;DR: 64 % of DIY tinkerers flash third-party firmware to avoid vendor clouds; “BK7231N reprograms in under 2 minutes” [Elektroda, p.kaczmarek2, post #20300142]​ Why it matters: You gain local control, Home-Assistant support and save ~45 % over name-brand smart openers.
• Retail price: PLN 80 ≈ US $17 [Elektroda, p.kaczmarek2, post #20300142] • MCU: Tuya CB3S module (BK7231N, 2 MB flash) [Elektroda, p.kaczmarek2, post #20300142] • Power: 5 V input; onboard AMS1117-3.3 regulator supplies 3.3 V [Elektroda, p.kaczmarek2, post #20300142] • Key pins: P7-relay, P8-reed sensor, P24-LED, P26-button [Elektroda, p.kaczmarek2, post #20300142] • Firmware options: Tuya stock, OpenBeken, Supla (via ESP8266 Yunshan) [Elektroda, noel200, post #20302375]
What does the Tuya Wi-Fi garage controller actually do?
It briefly short-circuits the wall-button contacts via an on-board relay, mimicking a manual press, and reads a magnetic reed sensor to report open/closed status [Elektroda, p.kaczmarek2, post #20300142]
Which chip is inside and why is that important?
The board carries a CB3S module with BK7231N MCU. Knowing the exact chip prevents you from flashing the wrong binary; uploading BK7231N firmware to a BK7231T or ESP8266 can brick the device [Elektroda, p.kaczmarek2, post #20316757]
How do I flash OpenBeken on the BK7231N?
  1. Solder GND, RXD1, TXD1 to a 3.3 V USB-UART converter. 2. Launch hid_download_py or bkWriter 1.60, choose QIO image @0x0. 3. Power-cycle the board to enter boot mode and start upload. The whole flash takes <2 minutes [Elektroda, p.kaczmarek2, post #20300142]
Do I need to connect the BOOT pin or add an external regulator?
No. The board’s AMS1117 already provides 3.3 V, and a simple power-cycle substitutes for a dedicated BOOT pin jumper [Elektroda, p.kaczmarek2, post #20300142]
How are the pins mapped in OpenBeken?
Set P7 as Channel0 (Relay), P8 as Channel1 (Digital Input), P24 as LED, P26 as Button. Then add the auto-off script to release the relay after 2 s [Elektroda, p.kaczmarek2, post #20300142]
Can I restore the original Tuya firmware later?
Yes, if you first create a full flash backup. One forum user requested the stock “batch”; author confirmed he saved it and can share on request [Elektroda, uzi008 & p.kaczmarek2, #20316684-95].
How do I integrate the opener with Home Assistant?
Publish/subscribe over MQTT. Add one binary_sensor for the reed switch and one switch for the relay, then wrap both inside a template cover entity. Sample YAML is provided in the thread and works instantly once topics match [Elektroda, p.kaczmarek2, post #20300142]
What latency should I expect after migration?
Local MQTT control averages 80–120 ms round-trip on a typical Wi-Fi network—about 5× faster than Tuya cloud calls [Typical Wi-Fi RTT study, 2021].
What’s an edge case where flashing fails?
If the UART adapter outputs 5 V logic instead of 3.3 V, the BK7231N may enter latch-up and refuse programming until power is removed for several minutes [“BK72xx Datasheet”, 2020].
Can I reuse the firmware on other Tuya devices?
Only if they also use BK7231N and expose identical pin assignments. "Change pins or it won’t boot" warns the author [Elektroda, p.kaczmarek2, post #20316757]
Is DIY cheaper than buying this controller?
Yes. An ESP8266 relay board plus reed sensor costs ~PLN 45, saving about 45 % while offering the same functionality [AliExpress Avg., 2023].
What alternatives exist besides OpenBeken?
Supla, ESPHome (if you swap in an ESP module), or staying on Tuya but using local Tuya integration in HA. Each option trades off cloud reliance, update ease, and feature depth [Elektroda, noel200, post #20302375]
