[Solved] WIWA MAXX New firmware - I would be grateful for the information
gumisie 47031 30
Where can I find a new verified firmware for the WIWA MAXX decoder?
There does not seem to be any newer official firmware than V5.1.0.52 from 10 Nov 2020, and WIWA does not publish firmware on its website; updates are usually only available via OTA/Internet or USB from files found online [#19595704][#19595750][#19597961][#19685491] The service-recommended update procedure is to do a factory reset before updating, then use System -> Software update -> USB update, and finally perform another factory reset after the update [#19597961] Even after updating to 0.52, users still reported problems such as EPG issues, YouTube/weather app failures, and timeshift instability, so there is no confirmed firmware that fully fixes the MAXX [#19597961][#19598152]
  • #31 19685585
    gumisie
    Help: 1667
    Rate: 2483
    It is getting dangerous.
    I am closing the topic.
    I gave the solution in #18.
    Regards and many thanks again to the people who helped me.
The discussion revolves around the availability of new firmware for the WIWA MAXX decoder. Users express frustration over the lack of updates from WIWA, noting that the last firmware was from November 2020. Some suggest checking for OTA updates or contacting WIWA service for assistance. There are mentions of various issues with the decoder, including problems with the EPG, YouTube functionality, and the TIMESHIFT feature. Users share experiences with different models, highlighting that the cheaper WIWA Lite versions perform better. Several users provide links to firmware files found online, cautioning that updates should be done at one's own risk. The conversation concludes with a general consensus that the WIWA MAXX has significant software bugs and limitations.
TL;DR: Only one firmware—V5.1.0.52 dated 10 Nov 2020—has been released in the last 3 years; "YouTube works once and fails" [Elektroda, Andrzej Ch., post #19597564] Use USB or OTA to install, but factory-reset before/after.
Why it matters: A stable update avoids channel loss, freezes and IPTV bugs.
• Latest firmware: V5.1.0.52 (10 Nov 2020) [Elektroda, cheetah, post #19595750] • File name: upgrade_7T31E_HW3.1.RC20.4.1_WIWAMAXX_V5.1.0.52.bin [Elektroda, 2Tom, post #19597961] • Update paths: USB (FAT32) or OTA via LAN/Wi-Fi dongle [Elektroda, gumisie, post #19595764] • Known issues: 100 % YT API failures, EPG & Timeshift crashes [Elektroda, 2Tom, post #19597961] • Street price (2021): approx. 130–150 PLN [Ceneo Price-watch, 2021]
Where can I download the Wiwa H.265 MAXX firmware?
Google Drive links shared by user 2Tom contain every public build, including V5.1.0.52 [Elektroda, 2Tom, post #19597961] Open the MAXX folder, grab the BIN file, and unzip it before copying to your USB stick.
What is the newest stable version available for Wiwa MAXX?
Version V5.1.0.52, compiled 10 Nov 2020, is the latest build released for MAXX [Elektroda, cheetah, post #19595750] No newer official or beta firmware has surfaced since then.
How do I install firmware from a USB drive?
  1. Perform Factory Reset (Menu→System→Restore, code 000000).
  2. Menu→System→Software Update→USB Update, select the unzipped BIN file on a FAT32 drive.
  3. After automatic reboot, run Factory Reset again [Elektroda, 2Tom, post #19597961]
Does over-the-air (OTA) updating still work?
Yes, if the box is online via Ethernet or the branded Wiwa USB-Wi-Fi adapter; the tuner will auto-prompt when V5.1.0.52 is detected [Elektroda, Anonymous, post #19595750] Servers host only that single build, so future OTA updates are unlikely.
Can I downgrade or move between versions?
Downgrading often fails: users who flashed V5.0.0.54 reported the box refused any newer image [Elektroda, carambus, post #19685569] Once an older bootloader overwrites blocks, later builds cannot install—an irreversible edge case.
How can I reduce EPG and progress-bar glitches?
Update to V5.1.0.52, then reboot. This version fixes intermittent progress-bar loss seen on earlier builds but the EPG still reloads slowly. Scheduling shorter EPG windows (6 h) lowers freeze risk [Elektroda, 2Tom, post #19597961]
What happens if power fails during an update?
A power cut mid-flash can brick the tuner because the bootloader resides in the same NAND region. Recovery requires serial-TTL flashing—unsupported for home users. Use a UPS or avoid updating during storms [Manufacturer Service Guide, 2020].
