Uploading programs on the ESP C3 S32 NodeMCU: Tips and solutions
koperplay 888 5
  • #1 20028848
    koperplay
    Hello can any of you know how to upload programs to this board? I think I've tried everything
  • #2 20028898
    Interval
    Level 32  
    Help: 186
    Rate: 435
    Please write how you tried it and what happened during the upload.
  • #3 20029000
    koperplay
    Hi I have tried all possible ESP32 libraries every time I try to upload the program to the board I get an error that either it was not found or it took too long to do so
  • #4 20029008
    xury
    Automation specialist
    Help: 876
    Rate: 1486
    What environment are you using. Logs from the programmer would be useful.
  • #5 20029420
    koperplay
    ARDUINO IDE and probably all esp32 library versions.
    Arduino:1.8.19 (Windows 10), Board: "ESP32C3 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 160MHz (WiFi), QIO, 80MHz, 4MB (32Mb), 921600, None".
    In file included from C:nUserspireDocumentsArduinon_blynk_blynk.ino:1:
    No such file or directory
    #include <ESPAsyncWebServer.h>
    compilation terminated.
    Found multiple libraries in "WiFi.h"
    Used: C:UsersAppDataLocalArduino15packages32hardware2.0.3 WiFi libraries.
    Unused: C:Program FilesArduinolibrariesWiFi.
    exit status 1
    Compilation error for ESP32S3 Dev Module board.
    This report should contain more information if in
    File -> Preferences the option "Show
    detailed information during compilation"
  • #6 20029481
