Control of the power supply to the circulation pump via wifi from the fireplace controller
m35sie2 1335 2
  • #1 17647769
    m35sie2
    Welcome,
    I have this situation: a CTA fireplace with a water jacket has an Aria controller that, above the set temperature, gives voltage to a cable that goes to another room where the circulation pump is located at the heat buffer. Unfortunately the cable has broken somewhere in the wall (not to be located). I am looking for a solution like this: connecting a wifi module to the Aria fireplace controller, which will transmit a signal (drive) to a second wifi module, which will give voltage to the pump after receiving this signal. Both modules can be powered independently from power sources at their locations.
    That is, when one module gets voltage on its input, it transmits a signal to the other module, which feeds voltage to its output. Does anyone know of such a solution?
    Piotr
  • #2 17647873
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    Does it necessarily have to be wifi? I understand that it is about 230V.
    Can't it be wireless? For example a set of Elmes RP501 plus 2 12V power supplies and 2 relays one with a 12V coil the other with a 230V coil.
  • #3 17660845
    m35sie2
    As much as it can. With that said, I'm looking for some simple "plug and play" kit and wifi sounded easiest to me here.
