Wemos D1 mini ESP8266 how to connect two sensors BMP280 and BME280
vanzan1 3966 6
  • #1 19741237
    vanzan1
    Hi
    Like the subject
    I have a Wemos D1 mini ESP8266 and would like to connect 2 temperature sensors to it.
    Is it possible?
    The sensors are
    BMP280 and BME280
    Individually they work without problem I would like them both to work at once :).
    thanks for your reply.
  • #2 19741257
    Slawek K.
    Help: 259
    Rate: 1303
    Both sensors can operate over I2C, so as much as possible, you connect to one bus and differentiate the sensors (communication) over different addresses, or over the SPI bus.
    Greetings
  • #3 19741572
    vanzan1
    and you could write me how to do it because I am just starting this adventure :) .
    thanks.
    on the Internet I found such a diagram for the connection, after over SPI
    but what to do next :)
  • #5 19741637
    vanzan1
    I have a Wemos D1 mini ESP8266 and would like to connect 2 temperature sensors BMP280 and BME280 to it.
    ESP with one sensor works as expected.
  • #6 19741671
    tos18
    Help: 1113
    Rate: 1870
    with i2c, you connect the sensors together and change the address of one of them, referring to it by its address
    with spi you select the sensor using the csb pin
  • Set BMP280 and BME280 to different I2C addresses
    #7 19742518
The discussion revolves around connecting two sensors, BMP280 and BME280, to a Wemos D1 mini ESP8266. Both sensors can operate over I2C, and it is possible to connect them on the same bus by assigning different I2C addresses. The BMP280 and BME280 typically have I2C addresses of 0x76 or 0x77, depending on the SDO pin configuration. Users are advised to verify the addresses and ensure that both sensors have distinct addresses when connected to the same I2C bus. Additionally, SPI can be used by selecting the sensor via the CSB pin. Resources and diagrams for wiring and programming are shared to assist beginners.
