Zoned Heating with Vaillant Ecotec Pro and Auraton 2025 RTH for Two-Storey Flat
Lowell 1365 12
Can I use ZigBee thermostatic radiator heads and app-based automation to control temperatures separately in each room and save gas in an existing two-storey flat with a Vaillant Ecotec Pro boiler?
Yes, but only if you treat the flat as real thermal zones: thermostatic radiator heads can regulate individual rooms, and lowering the setpoint in unoccupied rooms will reduce heat loss because the temperature difference is smaller [#19790093] [#19790221] However, it will not work well if doors are not kept closed and reasonably airtight, because air temperatures mix very quickly and you cannot beat basic heat-flow physics with electronics [#19789901] [#19790221] One reply also stresses that you should start from the building layout, insulation, windows, ventilation and radiator sizing before expecting meaningful zoning savings [#19790221] The original poster later tested cheap ZigBee heads and found them flimsy, with poor adapters, weak valve feel and little smart-home history, so he abandoned that route [#19796693] He instead planned to replace the Auraton 2025 RTH with a Volt Polska Comfort WT-20 Wi‑Fi radio thermostat for simple boiler-level automation and to adjust bedroom radiator heads manually when needed [#19796693]
  • Questioning ZigBee radiator heads for room-by-room zoning
    #1 19789869
    Lowell
    Rate: 9
    Hi, I have a Vaillant Ecotec Pro boiler (non-condensing combi), this is controlled by a wireless Auraton 2025 RTH. I have a large two-storey flat, 11 radiators, each with a dial (the kind where you set a number from 0 to 6), a Danfoss type valve. As the whole family likes to sleep in the cold I have the temperature set to 20st during the day and 17st at night. Unfortunately, this arrangement has stopped working since the pandemic started and the householders started staying in the house at different times, plus occasionally someone works at night (and either sits in the cold or raises the temperature for all the householders). In addition, it is increasingly the case that all household members leave the house for 8-9 hours and the cooker continues to heat. My needs:
    - the ability to set the temperature independently in each room (and the minimum is zones: ground and ground floor)
    - in view of the upcoming gas price increases – gas savings achieved by means of a lower temperature when no one is home
    I did a long research in the archives and on google and here is what I found. I'm asking for your opinions on whether this would work and possibly suggestions on whether it could be done better but at a similar cost:
    - I buy ZigBee radiator heads for each radiator, e.g. like this: https://allegro.pl/oferta/inteligentna-glowica-termostat-tuya-zigbee-wifi-9827598944
    - a ZigBee gateway and controller, e.g. such as: https://allegro.pl/oferta/sterownik-przekaznik-zigbee-tuya-beznapieciowy-10125878413 and https://allegro.pl/oferta/sonoff-zigbee-bridge-inteligentna-centralka-bramka-9764058608
    - in the app on the phone I program the schedule for the radiators, plus automation based on location (if my wife and I are 1km away from the house, reduce the temperature, when we get closer, increase it)
    - if someone wants to work at night in the warmth, the app switches on a higher temperature in a particular room and not in the whole house
    Will this work? Thank you in advance for your help.
  • Need airtight room zones with closed doors
    #2 19789901
  • #3 19790093
    bhtom
    Help: 446
    Rate: 604
    Welcome,
    Well, someone invented thermostatic heads on radiators to regulate the temperature in a particular room individually, depending on your needs.
    Regards.
  • Suggesting thermostatic heads with app control
    #4 19790178
    Lowell
    Rate: 9
    Well, this is where I have a problem - the children upstairs go to bed and my wife and I want to sit still on the ground floor. At the moment I have a choice - either the kids sleep in 20 degrees C and we are comfortable, or we sit in the cold, or I run around the flat and turn the valves, only I still have to remember to set them back properly before going to bed. It's pointless, I'd like to embrace it with an app/screen.
  • Heating zones need building-level thermal planning
    #5 19790221
  • Heating should be designed around room heat loss
    #6 19790252
    WojtekRav
    Help: 29
    Rate: 64
    AlfaCentauriss wrote:
    Do you know how long radiators take to cool down? Turning the radiator on an hour before bedtime does nothing. The other thing is that in a country of IT/technology exploitation in which 90% of equipment that does not work is sold .... combinations are pointless. It would be quicker to use a well-thought-out ventilation system (additional ventilation grilles) and to play around with "sealing" doors, seriously. Electronics can't beat physics, any toy will be a waste of money. You need to start with a plan of the building (windows, doors, ventilation shafts, heating, heating efficiency, ventilation efficiency, circulation directions, thermal transmittance, thermal loss, insulation (doors, windows, roof)) and on the basis of all this put together a plan for heating specific (zoned) rooms. In my opinion, the whole thing should be thought out and designed in such a way that the taps at the radiators are never touched. This can be done by knowing the size of the rooms and the energy efficiency of the radiators, pump and cooker. There is a lot of calculating, planning and testing, but it is easy to do with the size of the radiators, very large ones downstairs and smaller ones upstairs, and so on and so forth. I saw a house being built two years ago in Finland, put up by a technician/builder (Polish), everything thought out from A to Z and do you know what he installed there? He has two isntalations (separate, independent) on one cooker. He can close/open them separately or together, the two systems work separately and he doesn't have one radiator in each room, but two (a large and a small one) and at the moment (I wrote him an e-mail 1h ago) outside the window it's about -4, in the basement +10, on the ground floor (where the kitchen, living room, 1 bedroom, 1 wc, 1 corridor) +22C and upstairs (3 rooms + 1 bathroom + 1 corridor) +18C. On top of this, my daughter lives in the rooms upstairs who likes it cold so she is around +16C but in the room next door at my cousin's house it is +19C. From this example I took the information about circulation, doors and even windows with 3 panes.
    And they have no panels, no electronics, everything in "analogue", as it were.
    The last thing is the insulation of the building. Draw examples and methods only from the northern parts of the globe and not from Poland! Northern Canada, Alaska, Scandinavia, Russia and so on. There, they already have well-thought-out and specifically tested methods for cheap heating, because what they offer here in Poland, for example, is useless. Ordinary insulation, such as that used by 98% of builders in Poland, has failed to pass the test in northern Finland, where, in a good winter, you can even reach -40C on the thermometer. Windows and doors are also different; windows should have at least 3 panes and doors should be double-glazed. Circulation is also important, which means knowing your building so that you don't let heat out into space, which means you can't do without thermal imaging in winter, because no building is the same. So my uncle has electric roller shutters which automatically close the windows when the wind blows (direction) or the temperature drops. Apparently frivolous, but they paid about 1800 euros for the entire winter of 2020 (gas heating) when other people paid 3800-4500 euros per season.
    It's one thing to save money, it's another to be comfortable with the heat. Without automation, it is difficult to adjust the comfort to one's current needs, and one has to get used to the needs that someone thought up at the stage of building the house because the heads at the radiators cannot be turned.
    A colleague asked what he could do to save money in his current state without demolishing and building a new house next door.. Turning down the heating in unoccupied rooms will result in savings, after all, physics tells us that heat loss depends on delta T, and if delta T is smaller, there will be less loss.
  • Rising energy costs make home heating unaffordable
    #7 19790360
  • ZigBee radiator heads rejected as too flimsy
    #8 19796693
    Lowell
    Rate: 9
    Next winter on the basis of the new prices of gas, electricity and all the rest the mate will start demolishing and remodelling, seriously, you'll see. Then, he'll be very, very sorry that he didn't start today, after all, new thermal windows with 4 panes are still at quite decent prices, so guess how decent they'll be when a few hundred thousand people start looking for them.
    Here mate you have swum a bit :) My annual heating expenditure is around 2000-2500PLN. Even assuming a 50% increase in gas prices, it does not make economic sense to carry out a major refurbishment. I just want to improve comfort without a major refurbishment and save on gas at the same time.
    Added after 16 [minutes]: .
    Lowell wrote:
    buys ZigBee radiator heads for every radiator
    Thank you for all your advice.
    I have tested these heads and find that this product, for me, is pointless (maybe for a small flat with district heating it would be ok, but when you have 10 radiators and your own boiler, no more):
    - Workmanship - for me it's cheap Chinese plastic, the adapters made of such material that potentially after a few screwings and unscrewings the threads will break off. According to Murphy's Law, the head will of course damage itself when I'm away and the family is left with either a cold or perpetually hot radiator or radiators. The cap that closes the lid - I'm afraid to unscrew it so as not to damage it.
    - The valve, when screwed on at 100%, still has some play, unlike traditional valves with a 0-6 knob. This does not give the impression of robustness.
    - Smart home - the head's "smart" options are very poor. Above all, any kind of history preview is missing. I was hoping for something like a WiFi smart outlet, where we can see the current consumption, plus we can track consumption for the past days. It would be useful to have a history of the temperature or opening over time. I know that this can be done by connecting the heads to a more advanced smart home system, but I was hoping for this kind of functionality already in Tuya.
    In the end, I decided to replace my Auraton 2025 RTH with a "Volt Polska Comfort WT-20 radio thermostat Wi-Fi power supply". Here I will be able to do simple automation, e.g. when both my wife and I are away from home then, change the temperature to night time, and in turn when I want to sit at night in the warmth, I will fire up the daytime temp and simply turn the :) heads in the bedrooms by hand and that's it.
  • #9 19796913
  • Questioning whether the post is an advertisement
    #10 19797134
    Lowell
    Rate: 9
    Well, it smelled of silent crypto-advertising to me anyway, so I'll be quiet, it's a waste of words, my colleague knows perfectly well what kind of pumps, valves and is super knowledgeable about it, personally I think that the post is not a "problem" but an "advertisement", therefore I end my participation, I have already been through the "ads" on the electrode :)
    Hmm, an advertisement for what?
  • #11 19797144
  • Kitchen window draft likely causing heat loss
    #12 19797162
    Lowell
    Rate: 9
    This miracle electronics which breaks down the laws of physics and the rest, I wonder if via wifi there is already a chance to seal windows, maybe it would be cheaper than gaskets and even full doors...
    Mate, how can I advertise something if I have just written that it is, in my opinion, crap? :)
    And as for simple physical measures, thanks for the suggestion, I just checked at the weekend and I actually have something wrong with one window in the house. In the kitchen the temperature at the window handle and at the window sill is noticeably low (at the other windows this problem is not present) also I am checking what the issue is. I'll repeat the test when it's really cold, for the moment it's 7 degrees C in Gdynia. External doors to the stairwell - I hadn't thought of that, also to be checked.
  • #13 19797259
The discussion revolves around optimizing zoned heating in a two-storey flat using a Vaillant Ecotec Pro boiler and Auraton 2025 RTH thermostat. The user seeks a solution to independently control temperatures in different rooms due to varying schedules of household members, which has led to discomfort and inefficient heating. Suggestions include the installation of thermostatic radiator valves for individual room control, ensuring airtight zones with solid doors to minimize air circulation, and considering a comprehensive heating plan that accounts for building layout and thermal efficiency. Concerns about the quality and reliability of thermostatic heads were raised, with some participants advocating for a more thorough approach to heating management rather than relying solely on electronic solutions.
