Can Doepke SIDI 1 Dimmer Work with LED Bulbs Instead of Incandescent?
Frredd 495 1
  • #1 19818087
    Frredd
    Rate: 23
    Good Morning,
    I have a dimmer for a ceiling lamp at home based on the component as above. And a regular bulb has burned out. Is it possible, with this dimmer, to replace the bulbs with some LEDs so that the dimmer and the bulbs work? Do only incandescent bulbs work with this SIDI?
  • #2 19823899
    Frredd
    Rate: 23
    Is anyone familiar with the above Doepke devices? Have these gone out of fashion and need to look in museums?
