Dimming LED lighting in the mirror with a non-contact switch - is it possible?
Ciacho30 771 1
  • #1 20534329
    Ciacho30
    Hi.
    I would like to dim the LED lighting in the mirror because it is far too bright.
    The LEDs are switched on with a non-contact switch soldered into the LEDs.
    Can I use such a controller to dim the lighting around the mirror and will the non-contact switch still work.
    Link .
  • #2 20534456
    sigwa18
    Help: 1195
    Rate: 3361
    Yes just plug in before the leds and after the touch switch. Alternatively, omit the touch switch.
