DETA Grid Connect Smart LED Single Gang Touch Dimmer Switch - 6910HA
sebowers 1557 2
  • DP IDs 1 and 3 are not mapped
    #1 20631821
    sebowers
    Hi All,
    Have some troubles with the Deta 6910HA Dimmer.
    So far i have flashed the Device, Connected to wifi. Updated openbeken to the lastest firmware.
    If i move the dimmer(channel 2) slider the light turns on, tho the button led remains off - need to fix this
    if i turn on the button (channel 1) the light turns on and show does the led on the button
    I have applied the following to the device
    startDriver TuyaMCU
    setChannelType 1 toggle
    setChannelType 2 dimmer
    tuyaMcu_setDimmerRange 280 1003
    linkTuyaMCUOutputToChannel 2 2 2
    Below is the output from MCU trace
    Info:T
    uyaMCU:TUYAMCU received: 55 AA 03 07 00 05 01 01 00 01 00 11
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 7 (State) with 12 bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 1, dataType 1-DP_TYPE_BOOL and 1 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 1 byte:
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 1 with value 0 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 08 03 02 00 04 00 00 00 BE D8
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=3]: processing command 7 (State) with 15 bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 3, dataType 2-DP_TYPE_VALUE and 4 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 4 int: 190
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 3 with value 190 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 08 02 02 00 04 00 00 00 0A 23
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 2, dataType 2-DP_TYPE_VALUE and 4 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 4 int: 10
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 2 with value 10 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 07 00 08 06 02 00 04 00 00 00 00 1D
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 6, dataType 2-DP_TYPE_VALUE and 4 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 4 int: 0
    Debug:TuyaMCU:TuyaMCU_ApplyMapping: id 6 with value 0 is not mapped
    Info:TuyaMCU:TUYAMCU received: 55 AA 03 00 00 01 01 04
    hoping someone can help
  • #2 20632488
    sebowers
    Hi Team,
    this is the working config for the Deta 6910HA
    startDriver TuyaMCU
    linkTuyaMCUOutputToChannel 1 1 1
    linkTuyaMCUOutputToChannel 3 2 2
  • #3 20696942
    theslydog
    Level 4  
    sebowers wrote:
    Deta 6910HA
    How did you flash this dimmer?
    I am struggling to get it to go into flash mode.
    All other Deta Grid Connect devices have flashed fine but this one is being stubborn for me.
