DS18B20 temperature sensor based on NodeMCU v3 ESP8266, compatible with tuya
howito 3087 3
  • NodeMCU and DS18B20 for 100°C cloud sensor
    #1 19869684
    howito
    Good afternoon.
    I have made buffers in the basement to store hot water for heating. The buffers are heated with heaters that run on "cheap" current tariffs. The heaters are switched on via smart life sockets. I would need to make some cheap temperature sensors with a range of up to 100st C. which will send me data to the Smart live cloud (with the sensors I do not need a display). The sensors available on the market are up to about 60st C. or they are expensive. I have purchased a NodeMCU v3 ESP8266 and DS18B20 sensors. Is it possible to combine these without using an Arduino? I'll add that there is a lot of this on the web mostly relay control and I'm a bit lost on this. Maybe someone has some ideas or links?
  • #4 19869968
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Unfortunately, I am not familiar with either Tuya or SmartLife. Generally you have to send the received results to tuya API or something like that.
    I don't use cloud solutions so I don't know anything about it.
