DIY project: Heat buffer controller with ESP, DS18b20, TFT LCD 1.4, air sensor, NodeMCU v2/v3
szaryczlowiek831 1044 4
  • CO/CO2 sensor recommendation and ESP power-supply concerns
    #1 19995249
    szaryczlowiek831
    All in all I have a few questions for those versed in ESP and sensors.
    As in the topic, all the controllers I have found that have e.g. wifi connectivity and some other useful and useless features cost their own. I therefore decided to make my own.
    Nodemcu v2/v3 board
    3 or 4 DS18b20
    Tft LCD 1.4"
    Air sensor
    Probably 4 relays but I can do without that and make on esp-01s as a separate board for on/off pump control.
    Everything packed into an airtight box e.g. PK-0 EP-LUX IP55 with a cut-out for the display. Everything will stand either on esp-easy or supli, unless something else is recommended.
    I'm looking for an air sensor of the kind with no water features in total just to detect CO and CO² and to be essentially small. What do you guys recommend?
    DS18b20 does anyone know from what length of wire you need to solder a resistor?
    And lastly, it is known that the board itself can be powered by a regular phone charger. Do you recommend something instead? I wanted to put the power supply in the box with everything but I am afraid of the heat
  • Recommend SCD30, DS18B20 pull-up, and 230VAC/5VDC supply
    #2 19995267
    czareqpl
    Help: 196
    Rate: 580
    szaryczlowiek831 wrote:
    it only has to detect CO and CO² and be essentially small. What do you recommend?
    I have a SCD30 for sale
    From each, it is an OD type signal.
    And last, it is known that the board itself can be powered by an ordinary phone charger. Do you recommend something instead? I wanted to put the power supply in the box with everything but I'm afraid of the heat
    Any sensible quality 230AC/5VDC power supply. Can be open frame.
  • #3 19995303
    szaryczlowiek831
    I have an SCD30 for sale
    A bit of an expensive event personally I was thinking PMS7003 or MQ-07 or MP503
  • #4 19995531
    czareqpl
    Help: 196
    Rate: 580
    Since it's expensive without even knowing the price it's OK :)
  • Cheaper CO and CO2 sensor alternatives suggested
    #5 19996021
    szaryczlowiek831
    I searched online and found the cheapest (SCD30) at majfrend for 144PLN and 160PLN in Polish shops the cheapest stands at 230PLN but out of stock. So I don't think you will want 100 zł. and I don't intend to spend more because I can solve this problem in another way (cheaper) but not "smart". Well unless I'm wrong and you want to sell it for less than a hundred, but then correct me.
