Integration of Blebox wLightBox devices and Tuya RM switches via Tuya SmartLife Zigbee 3.0 gateway
arekszg1 3657 4
  • Asking whether Tuya Zigbee can control wLightBox scenes
    #1 19881294
    arekszg1
    Hi guys,
    I have bought switches Tuya RM to control traditional chandeliers, but I would also like to be able to switch on/off one scene on wLightBox using one of these switches. As far as I can see, I won't have this possibility from the Tuya app, and the same with Google Home :/.
    I assume that my need will be met by some Hub, but here I have no experience.
    Do you know if the wLightBox can be handled via e.g. the Zigbee 3.0 Tuya SmartLife, or do I need to use something else here?
    Do you have any experience regarding Blebox and Tuya/Zigbee devices in one integrated system?
    Thanks in advance for your help and have a good day ;) !
  • wLightBox uses μWiFi, not Zigbee
    #2 19882391
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    bb560fa3b Do you know if the wLightBox can be handled via e.g. the Zigbee 3.0 gateway Tuya SmartLife , or do you have to use something else here?
    - no zigbee gateway will handle it, because it is not on zigbee (it is on μWiFi).
    You could try adding to google home and see if you can see the scene there or if it's possible to create a scene (not sure what exactly you mean by writing about a scene and one device).
    Maybe write what effect you want to achieve - it would be easier that way - e.g. when I turn on a chandelier the LEDs should turn on with a given brightness/colour, and when I turn off the chandelier the LEDs should turn off.
  • Need a non-Zigbee trigger for wLightBox brightness control
    #3 19883173
    arekszg1
    Maybe write what effect you want to achieve - it would be easier that way - e.g. when I turn on the chandelier the LEDs with a given brightness/colour should turn on, and when I turn off the chandelier the LEDs should turn off.
    Thanks for your reply.
    When I wrote about the stage, I meant setting the wLightbox brightness to 0%, i.e. making the button something like a remote control. I don't want to power down the wLight completely, because I could do that from a normal switch, and after such an operation I won't be able to run the module from the app. Of course, I can run the switch and after that wait for the wbox to connect to the network and turn on the scene, but each time the action requires me to take 2-3 more steps and wait time. On top of that the wlightbox won't always connect to the network and has to be switched off /on again (I have 2 wlights connected on this circuit).
    As far as I can see, Google Home does not have scenes or a function that will allow me to create a typical trigger.
    I am looking for something (not necessarily ZigBee) that can handle this need. I also don't want to change the switch, as there is a 3pc set bought here along with the frame, and unfortunately I haven't found anything similar that meets these requirements :/.
    Thanks in advance for your help and have a good day ;) .
  • #4 19883204
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    See Home Assistant or AI-Speaker - you can combine the operation of devices from different companies and it gives you a lot of freedom to control them.
  • #5 19889614
    arekszg1
    Ok, thanks :) I'll check ;)
