Hello everyone and I have a request if anyone can help. I have installed myself a WiFi curtain module in the box and everything has gone smoothly, I have control from both monostable buttons, which when connected with the module work both as monostable and you could say also as monostable with hold. I can also control using the TUYA app on android. The problem occurs when I close the roller shutter all the way or more than 50% and want to open, it opens somewhere around 95% and this is probably due to the different opening and closing times. IOW the roller shutter runs about 29 sec down and 32 sec up. The app assumes that these 29 secs are the range from 0 to 100% and therefore when opening it stops after 29 secs which is about 95% open. How to solve this problem of two different times The only thing I can add is that I changed the time to a longer time via tuya cloud in the debugging option, but this does not change the fact that when I have the roller shutter open at 100% and switch it to close, the software counts down the closing time and probably the same time when opening, except that it opens slower due to the weight of the roller shutter and therefore does not reach the end. This happens when I close it more than 50%. When the roller shutter is slightly closed, the different times of opening and closing do not make that much of a difference. I don't know enough about it to be sure, but it seems to me that there should be two times in the software, one for opening and one for closing, but how to do it or you would have to remove the percentage indication of the position, which is not so cool because it loses a lot of its usefulness.
stalman1
stalman1
Level 4
