[Solved] Legrand Netatmo configuration: input/output switch connection error after reset
jacekdebski 3306 4
  • Reset leaves gateway and switch unable to pair
    #1 19905529
    jacekdebski
    Hello. I have a problem with a Legrand Netatmo gateway. The whole kit is working fine; however, when it was not visible in the home kit application, I decided to do a device reset instead of a router reset, which was a mistake. Now I cannot connect the switch input output to the gateway on which a red LED is blinking after the reset (I held the reset for about 8 seconds). It is not possible to connect to the switch input output on which a green LED blinks for a few seconds, then ends the signalling with a red LED. (Also, it was reset).
  • #2 19967285
    tomekdomagalski123
    I have the same
  • #3 19969337
    jacekdebski
    After a thorough analysis of the problem, I conclude that in this case the device is suitable for rubbish. The device has even been to a service center in Wrocław. A reset should never be performed.
  • #4 19969348
    tomekdomagalski123
    So it is probably the same for me.
    The input gates which are mounted in the switchgear went through a reset without any problems.
    Well, unfortunately you will have to buy a new module.
    Thanks for the information ℹ
  • #5 20072268
    jacekdebski
    Purchase a new device
