Zamel ROW-01 controller - light on all the time, module resets the settings
lukpio3 1119 5
  • Incorrect ROW-01 wiring causes reset and stuck light
    #1 20829086
    lukpio3
    Rate: 169
    Maybe someone of you can guide me to the solution of my problem. Zamel ROW-01 controller connected to a bistable light switch. The connection diagram is as follows:
    IN1 - empty
    IN2 - to the switch, to the wire on which voltage appears when the light is switched on and when it is switched off, there is no current
    11 - to the phase wire in the lamp
    14 - bridge with L pin
    N - to the neutral at the lamp
    L - to the phase at the switch
    Effect I have after connecting. The controller has started up correctly. It was also configured correctly. When the light is switched on using a traditional switch, the light stays on all the time, it is not possible to switch it off. No response to the switch. Once switched on, the light remains on at all times. When I try to switch it off using the module, the light starts to flash 3 times, then switches off and the module resets itself as if in the meantime. It switches off, switches on again and loses all settings and has to be configured again. Is anyone able to suggest what has gone wrong?
  • #2 20829111
    sosarek
    Help: 9320
    Rate: 15541
    Well, take the switch off and just short-circuit the cables - does it work? then fit a bell switch.
    Z
    Pka, Poznań, 60-850
  • #3 20829116
    lukpio3
    Rate: 169
    But this controller on the IN2 output is just configured for a bistable switch. Monostable is on IN1. Besides, the inputs can be rearranged so there shouldn't be any problem with it, or at least I think so.
  • #4 20829125
    sosarek
    Help: 9320
    Rate: 15541
    lukpio3 wrote:
    But this driver on the IN2 output is just configured for a bistable switch. The monostable is on IN1.
    Fact, I was typing quickly from memory. Disconnect input two and check that by energising the first it works properly.
    Z
    Pka, Poznań, 60-850
  • #5 20829131
    lukpio3
    Rate: 169
    In the sense that I should disconnect IN2 and connect this cable to IN1?
